8v92 will not crank
04-19-2008, 04:49
8v92 will not crank
Scott, if all else fails, check your remote start switch box for a wire that is loose. A few years ago, at a rally, we were getting ready to leave and nothing from up front. It was the switch that decided to give up the ghost. I'm glad that a member knew about the switches and got us going.
Ernie Ekberg 83PT40 Livingston, Montana Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. |
04-19-2008, 04:58
8v92 will not crank
My bus will not crank. Batteries are fine, when I turn the key,
nothing. Battery gauges do not drop like they normally do when key is turned to 'start'. Just drove the bus 2 days ago with no problems. I suspect a loose/corroded connection, where should I begin looking? Where is the starter solenoid? Scott Forman 86 PT38 Memphis |
04-19-2008, 05:04
8v92 will not crank
Scott: I had the very same happen on my Regards 96 42’ WBSD From: My bus will not crank. Batteries are fine, when I turn the key, nothing. Battery gauges do not drop like they normally do when key is turned to 'start'. Just drove the bus 2 days ago with no problems. I suspect a loose/corroded connection, where should I begin looking? Where is the starter solenoid? Scott Forman 86 PT38 Memphis |
04-19-2008, 05:42
8v92 will not crank
Scott,
Check the battery grounds, both at the batteries and the frame. Gary SOB ----- Original Message ----- From: "Scott Forman" <sforman@...> To: Sent: Saturday, April 19, 2008 12:58 PM Subject: [WanderlodgeForum] 8v92 will not crank My bus will not crank. Batteries are fine, when I turn the key, nothing. Battery gauges do not drop like they normally do when key is turned to 'start'. Just drove the bus 2 days ago with no problems. I suspect a loose/corroded connection, where should I begin looking? Where is the starter solenoid? Scott Forman 86 PT38 Memphis E-mail message checked by Spyware Doctor (5.5.0.178) Database version: 5.09660 http://www.pctools.com/spyware-doctor/ |
04-19-2008, 07:37
8v92 will not crank
In a message dated 4/19/2008 5:04:07 P.M. Central Standard Time, sforman@... writes:
I do not have a key that Scott, I don't think I had a key for that switch, either- but it was a wire that had come apart that stranded me in that switch.
04-19-2008, 08:24
8v92 will not crank
Scott, Gregg may be on to something there. Check all grounds, engine and battery. I don't know about the 8V92, but my 8V71 solenoid is attached to the starter. I had a small wire,(not the cable) on the solenoid,that burned through and was hard to see and get to. I used a can of brake parts cleaner to remove the oil/sludge that had gathered in that area. Ha! Imagine a leaking Detroit. That solved my problem. You also may have a bad solenoid, or a starter gone bad. Ck. to see if you have power at the solenoid, and jump across if the former suggestions don't work. Good Luck, and hope you don't have to pull it. They are very heavy, and tough to get at. Regards, George Burke 1977 FC31 Charlotte
On Sat, Apr 19, 2008 at 12:58 PM, Scott Forman <"sforman@renasant.com"> wrote:
04-19-2008, 10:48
8v92 will not crank
Will it start from the rear starting position? Another possibility
is the starter neutral switch. This is a shot in the dark. I had fueled up my PT36 and it would not It would not crank. I played with it for a couple hours sitting in the fuel-up island. I was about to call a towing service. "I'll try one more time". I looked at the gear selecter and saw it was not in neutral! You did check the A/T switch(anti theft switch)? That switch is in the start ckt. I hope your's is as simple. Art Weatherly Riverside Ca. '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > My bus will not crank. Batteries are fine, when I turn the key, > nothing. Battery gauges do not drop like they normally do when key is > turned to 'start'. Just drove the bus 2 days ago with no problems. > > I suspect a loose/corroded connection, where should I begin looking? > Where is the starter solenoid? > > Scott Forman > 86 PT38 > Memphis > |
04-19-2008, 11:03
8v92 will not crank
It's in neautral. A/T is not switched. I do not have a key that
fits the rear ign switch. When I went out this morning, the starter cranked initially, but engine did not fire off. When I tried to crank again, it was dead. Scott --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > Will it start from the rear starting position? Another possibility > is the starter neutral switch. > > This is a shot in the dark. I had fueled up my PT36 and it would not It > would not crank. I played with it for a couple hours sitting in the > fuel-up island. I was about to call a towing service. "I'll try one > more time". > I looked at the gear selecter and saw it was not in neutral! > > You did check the A/T switch(anti theft switch)? That switch is in the > start ckt. > > I hope your's is as simple. > > > Art Weatherly > Riverside Ca. > '85 PT36 > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > My bus will not crank. Batteries are fine, when I turn the key, > > nothing. Battery gauges do not drop like they normally do when key > is > > turned to 'start'. Just drove the bus 2 days ago with no problems. > > > > I suspect a loose/corroded connection, where should I begin looking? > > Where is the starter solenoid? > > > > Scott Forman > > 86 PT38 > > Memphis > > > |
04-19-2008, 11:39
8v92 will not crank
Depending on symptoms, there could be a fault in the rear start switch as well (at least that's what I've heard).
My own experience with a non-starting engine eventually led to the ground strap on the back wall of the engine compartment. The bolt had worked loose just a little bit, but was not obvious. We (a road service employee) and I discovered it when trying to start from the rear switch while observing the engine area... a slight sparking gave the fault away. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Apr 19, 2008, at 3:48 PM, amweath wrote:
04-19-2008, 11:59
8v92 will not crank
Clean all your cable connections and then put a charger on the coach
for an hour. Try starting then. It will not start if the engine does not spin at a good rate and it sounds like your batteries are down. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > It's in neautral. A/T is not switched. I do not have a key that > fits the rear ign switch. > > When I went out this morning, the starter cranked initially, but > engine did not fire off. When I tried to crank again, it was dead. > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "amweath" > wrote: > > > > Will it start from the rear starting position? Another possibility > > is the starter neutral switch. > > > > This is a shot in the dark. I had fueled up my PT36 and it would > not It > > would not crank. I played with it for a couple hours sitting in the > > fuel-up island. I was about to call a towing service. "I'll try one > > more time". > > I looked at the gear selecter and saw it was not in neutral! > > > > You did check the A/T switch(anti theft switch)? That switch is in > the > > start ckt. > > > > I hope your's is as simple. > > > > > > Art Weatherly > > Riverside Ca. > > '85 PT36 > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > wrote: > > > > > > My bus will not crank. Batteries are fine, when I turn the key, > > > nothing. Battery gauges do not drop like they normally do when > key > > is > > > turned to 'start'. Just drove the bus 2 days ago with no > problems. > > > > > > I suspect a loose/corroded connection, where should I begin > looking? > > > Where is the starter solenoid? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > |
