Entry Step problem
04-28-2008, 06:40
Entry Step problem
Is this happening when you open the door or when you throw the extend switch?"
Mine acted weird a couple of years ago. After chasing around mercury and door switches, I finally found a wire in the upholstery door strap that was partially broken. I corrected that and it has worked ok since. My access was gained by carefully taking the seam out of the upholstery strap and then hand sewing it back up. I don't have any idea if yours is wired the same way. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Pete Masterson
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
04-28-2008, 07:00
Entry Step problem
Leroy, you may have hit the nail squarely. Thanks
Ernie Ekberg 83PT40 Livingston, Montana Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. |
04-28-2008, 07:02
Entry Step problem
I know that Joe Losh' coach had his changed to an electric step. His coach is just 2 numbers away from mine on the build list.
04-28-2008, 07:55
Entry Step problem
Brad, one other thing I remember when messing with my step was the speed adjustment screws on the bottom of the valve. I tried to decrease the speed by screwing them down and found the step did not lock in properly. When I cleaned them and opened them up it locked perfectly.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA brad barton <bbartonwx@...> wrote:
04-28-2008, 08:31
Entry Step problem
Brad:
One or two ideas; 1. The in door, door step switch located behind the naughide covering of the door hinge. There are three switches, the center one is for the step. To go with that is the wiring in the strap restraint where the door wires pass as well. 2. The ribbon switch being flaky and that should be located under the edge of where the step retracts. Cut one wire to remove this ribbon switch from the circuit. There is a relay that controls the direction of the step and is activated or turned off by the 2 step switches for in/out. That is about all that I can think of off hand. Oh, a flaky lock out switch can cause this too, but that also goes with the in door switch circuit. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 12:38 PM 4/28/2008 -0500, you wrote: >To Ralph or anyone w/ experience on this: > >Ryan can't make my entry step misbehave. It comes out (psst) stutters >(clunka clunka) goes back in (psst) then comes back out (psst) and finally >locks (clunka-clunk). First noticed it in cold weather, but problem >persisted two months later on our trip through AZ, CA and NV. Step is >well lubed and frequently. Now it won't do it..and he can't find anything >wrong with the valves or the switches. Any other causes? I'd like to get >this fixed before Wed if possible. Thanks. > > >Brad Barton 00LXiDFW bbartonwx@... > > > |
04-28-2008, 10:10
Entry Step problem
Ernie,
Mine comes out, goes back in and comes out again..pretty dangerous if you're stepping down. That's what I'd like to fix. Brad Barton 00LXiDFW bbartonwx@...
Make i'm yours. Create a custom banner to support your cause. |
04-28-2008, 10:16
Entry Step problem
Thanks to all for the ideas. I've passed them along.
In a rush? Get real-time answers with Windows Live Messenger. |
04-28-2008, 10:18
Entry Step problem
I have a theory about cold weather step ops. Maybe good, maybe bad. The air control valve has two adjustable exhaust ports that are exposed to dirt, snow and rain and if moisture is present in winter it will freeze the exhaust ports and not allow air to escape, hence the step will not operate. As well, if any moisture is present in the actuator it will not work correctly. Just my theory, because if it works in summer what else could it be. Bluebird disease!
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion erniecarpet@... wrote:
04-28-2008, 10:22
Entry Step problem
I've had only three coaches, an 84 FC with an air-step, an 86 Newell with an elec-step and this LXi..and all three had step issues. I think Prevost is onto something.
Express yourself wherever you are. Mobilize! |
04-28-2008, 10:34
Entry Step problem
So what does Prevost do? Their coach is so low to the ground maybe not needed? lol
User(s) browsing this thread: 13 Guest(s)
