Extender Rally
04-29-2008, 03:37
Extender Rally
Good morning, we stopped at Sequin Diesel service Tx for Clyde to
change our fluids and what a wonderful surprise. Our rearend on the bus that is was on its last leg. There was a bolt laying in the botton of the housing and metal shavings in the oil. Had to pull the axles and the chunk and found bolts on the ring gear were lose and one was broken. When pulled apart to clean the spider gear cross was also broken. We are now homeless and looking for a rearend. The only good parts are the ring gear and pinion. Oh lets not forget the airbag and air hose challenge. Spent a wonderful week with friend, a great evening parked at Slyvia and Jeff's and are now living in Clyde and Sara's BB.(Dakota Traveler) Thank God for Texas friends. Joyce and Tony have offered their home to us and you know I have enough food on board for a month, as long as we have a can opener. We have put out the donation can. My poor new Basset Hound will probably not know us when we pick her up from thr Vets. Ms. Patticake 90PT 40Ft WB SB Jus Chillin (Mardi Gras Circus Wagon) |
04-29-2008, 04:41
Extender Rally
Queen Patticake and Steven (the butler),
How do you guys have such good luck? After the Land-all fiasco and fuel pump stories, I'd have thought you were in for some trouble-free years. Come to think of it, Steve's rearend was looking pretty bad at Quartsite in January. Kind of saggy, maybe a few leaks now and then!! Glad that he only lost one nut and not all of them. LOL --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@...> wrote: > > Good morning, we stopped at Sequin Diesel service Tx for Clyde to > change our fluids and what a wonderful surprise. Our rearend on the > bus that is was on its last leg. There was a bolt laying in the > botton of the housing and metal shavings in the oil. Had to pull the > axles and the chunk and found bolts on the ring gear were lose and > one was broken. When pulled apart to clean the spider gear cross was > also broken. We are now homeless and looking for a rearend. The only > good parts are the ring gear and pinion. Oh lets not forget the > airbag and air hose challenge. > > Spent a wonderful week with friend, a great evening parked at Slyvia > and Jeff's and are now living in Clyde and Sara's BB.(Dakota > Traveler) Thank God for Texas friends. Joyce and Tony have offered > their home to us and you know I have enough food on board for a > month, as long as we have a can opener. > > We have put out the donation can. My poor new Basset Hound will > probably not know us when we pick her up from thr Vets. > > Ms. Patticake > > 90PT 40Ft WB SB Jus Chillin (Mardi Gras Circus Wagon) > |
04-29-2008, 04:48
Extender Rally
At least you are in capable hands, Pat.
Ernie Ekberg 83PT40 Livingston, Montana Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. |
04-29-2008, 09:13
Extender Rally
Patticake,
I know it is upsetting, BUT it is much better to find it on Clyde's pit than to have it grenade on the IH-10 bridge going back into Louisiana. I'd be *very* thankful for that. Mike Bulriss - hoping I'm in Clyde's parking lot if I ever break down 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@...> wrote: > > Good morning, we stopped at Sequin Diesel service Tx for Clyde to > change our fluids and what a wonderful surprise. Our rearend on the > bus that is was on its last leg. There was a bolt laying in the > botton of the housing and metal shavings in the oil. Had to pull the > axles and the chunk and found bolts on the ring gear were lose and > one was broken. When pulled apart to clean the spider gear cross was > also broken. We are now homeless and looking for a rearend. The only > good parts are the ring gear and pinion. Oh lets not forget the > airbag and air hose challenge. > > Spent a wonderful week with friend, a great evening parked at Slyvia > and Jeff's and are now living in Clyde and Sara's BB.(Dakota > Traveler) Thank God for Texas friends. Joyce and Tony have offered > their home to us and you know I have enough food on board for a > month, as long as we have a can opener. > > We have put out the donation can. My poor new Basset Hound will > probably not know us when we pick her up from thr Vets. > > Ms. Patticake > > 90PT 40Ft WB SB Jus Chillin (Mardi Gras Circus Wagon) > |
04-29-2008, 10:07
Extender Rally
Heavens, how did a bolt get in the bottom of the rear end? Did you have any noise to indicate this?
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA patticake592000 <sgureasko@...> wrote:
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
04-29-2008, 16:37
Extender Rally
Leroy I'm with you on what was the cause? wonder if the driveline is
out of balance, and it shook the bolts loose or they were never torqued or casteled or wire tied. sounds like vibration worked the bolts loose and one of the harden bolts sheered off with the found torque lag??????????? Or was it an issue with wrong ride hight and the u joint geomentry??????? would be nice to know to keep it from happening again or have the mechanice drill and wiretie the ring gear if possible????? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Heavens, how did a bolt get in the bottom of the rear end? Did you have any noise to indicate this? > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > patticake592000 <sgureasko@...> wrote: Good morning, we stopped at Sequin Diesel service Tx for Clyde to > change our fluids and what a wonderful surprise. Our rearend on the > bus that is was on its last leg. There was a bolt laying in the > botton of the housing and metal shavings in the oil. Had to pull the > axles and the chunk and found bolts on the ring gear were lose and > one was broken. When pulled apart to clean the spider gear cross was > also broken. We are now homeless and looking for a rearend. The only > good parts are the ring gear and pinion. Oh lets not forget the > airbag and air hose challenge. > > Spent a wonderful week with friend, a great evening parked at Slyvia > and Jeff's and are now living in Clyde and Sara's BB.(Dakota > Traveler) Thank God for Texas friends. Joyce and Tony have offered > their home to us and you know I have enough food on board for a > month, as long as we have a can opener. > > We have put out the donation can. My poor new Basset Hound will > probably not know us when we pick her up from thr Vets. > > Ms. Patticake > > 90PT 40Ft WB SB Jus Chillin (Mardi Gras Circus Wagon) > > > > > > > --------------------------------- > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. > |
04-30-2008, 05:38
Extender Rally
A while back on Dupree's Wanderlodge forum there was a discussion about broken ring gears on late mode 8V92 equipped Wanderlodges. The fundamental issue seemed to be that the rearend is too weak for the 8V92's torque... Something about ring gears breaking. David Brady '02 LXi, NC Gregory OConnor wrote:
