Brush gobbler
06-01-2008, 17:02
Brush gobbler
What would cause my generator (12.5kw Yanmar powered Kohler) to eat
through brushes at a rapid rate?
Some time after buying my coach last year, the generator quit working.
I found the rear brush to be worn all the way down and the wire popped
off. The front brush looked OK, but I replaced them both anyway, as
well as the little holder for them just for kicks. Fast forward to
this weekend: With only ~30 hours of operation on the new brushes, the
generator stopped and I found the rear brush worn down with it's wire
popped off again. Front brush still looks new. Thankfully, I still had
the good front brush from before, so I installed it in place of the
worn rear brush. This was Saturday morning.
Roughly 5 additional hours of runtime later, the generator stopped
again. That was this morning and I haven't climbed under there yet but
I suspect I'll find that rear brush worn back down.
What's the deal here?
-Ryan
'86 PT-40 8V92
06-01-2008, 21:58
Brush gobbler
Ryan,
I am going thru the exact same thing right now(yanmar/kohler). What I
discovered is that the rear commutator slip ring has a grove worn
into it, but only about a third of the way around. Causing the ring
to be more egg shaped. Which I think is whats causing that brush to
wear out so rapidily. I have no idea what has caused this irregular
wear pattern. I bought new slip rings and rear bearing, but don't
have enough guts to attempt the R+R yet! If anybody has been thru
this I also would appreciate any tips and advice.
Tom Sorrentino
1987 PT38
Bedford Hills, NY
working.
popped
wire
had
but
> -Ryan
> '86 PT-40 8V92
06-02-2008, 00:01
Brush gobbler
Your commutator ring is worn. I went through this in January. You
have three options:
1) Replace entire genset
2) Find a modern head unit that mates up to your engine
3) Rebuild the head unit
I went for option three, as it had the lowest price and fewest
potential headaches. Now it is basically a brand new "old
technology" generator which should last another 20 years just like
the first one did.
The commutator ring must be pressed out, so machine tools are
required.
Good luck
Scott Forman
86 PT38
Memphis
working.
popped
wire
had
but
> -Ryan
> '86 PT-40 8V92
06-02-2008, 00:19
Brush gobbler
MANY years ago I worked with large A/C.D/C motor generator set. We used to turn
the commutator with special tooling while in place. Maybe some one who rebuilds
commercial/industrial motors can lead you in the right direction. These units
are almost timeless...
Pete
-------------- Original message ----------------------
> have three options:
> the first one did.
> required.
> Good luck
> Scott Forman
> 86 PT38
> Memphis
> working.
> popped
> the
> wire
> had
> but
> > -Ryan
> > '86 PT-40 8V92
have three options:
the first one did.
required.
Good luck
Scott Forman
86 PT38
Memphis
--- In "WanderlodgeForum%40yahoogroups.com", "Ryan Wright"
working.
popped
wire
had
but
> -Ryan
> '86 PT-40 8V92
06-02-2008, 00:23
Brush gobbler
I think the shaft is tapered to the engine?? so it then could be the
bearing in the gen or the mounting bolts that hold the gen to the
engine?? MikeH pointed out some time ago that it is important to
replace critical bolts to get them back to spec torque.
I have a coleman light tower that had a crack in the casting that
holds the genset bearing. once I welded the crack I then started to
run thru brushes . I guess I off centered the bearing seat. when I
pulled the genhead off the Kubota I noticed a broken motor mount on
the engine side which must have cantilivered stress on the duo and
caused the crack. Servicing mounting points may also help with
vibration. vibration is more annoying than noise.
On the topic of mounting and vibration; BB has some funky exhaust
mating systems for genset slides. I notice most vibration come into
the coach from the muffler mounting.
GregoryO'Connor
94ptRomolandCa
working.
popped
wire
had
but
> -Ryan
> '86 PT-40 8V92
06-02-2008, 10:23
Brush gobbler
Scott, did you do this work yourself? If not, would you might sharing
a rough dollar figure as to what I should expect when I start calling
generator repair shops?
-Ryan
> the first one did.
06-02-2008, 11:56
Brush gobbler
No, I am pretty handy but this level of work is beyond my capability
right from the beginning...I have no way to get the Genset out of the
coach.
I am a bad example for costs, because the shop that services my coach
is owned by a close friend...he gives me parts at cost and greatly
reduced labor rates. That being said, it was 16 hours of labor and
$136 (at cost) in parts. You should be able to estimate your cost
based on your local hourly shop rates since the parts are insignificant.
This is the narrative from my shop invoice:
Complaint: Generator not making electricity. Cause: Exciter ring and
brushes bad. Correction: Drained coolant and disconnected radiator
hoses. Disconnected A/C wires and control box. Removed gen set from
coach. Removed engine from cradle. Dissassembled generator. Removed
armature from engine. Removed end bearing. Replaced exciter ring.
Installed new end bearing. Installed armature on engine. Assembled
generator. Put engine in cradle and installed in coach. Connected
wires, fuel lines, and rad hoses. Filled cooling system and bled air.
Cranked engine, okay. 120v A/C from both lugs at no load. Put load on
generator and let run to check out, okay.
Hope this helps
Scott
> -Ryan
> > the first one did.
06-02-2008, 13:06
Brush gobbler
All I would ask is that if anyone does this repair, take lots of
pictures. It sounds like a pretty common problem and nothing is more
helpful that pictures along with an explanation. I don't have one of
these gen sets (yet), but Ihave friends that do.
Gardner
78FC33
to
on
into
> GregoryO'Connor
> 94ptRomolandCa
eat
> working.
> popped
as
to
brushes,
> the
> wire
still
> had
stopped
yet
> but
> > -Ryan
> > '86 PT-40 8V92
06-02-2008, 17:19
Brush gobbler
Much appreciated, Scott. Thank you for sharing this.
-Ryan
'86 PT-40 8V92
06-02-2008, 17:44
Brush gobbler
What is an exciter ring? Between the ExciterRing and the swaybar
threads "porpoising", I'm lost.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
capability
> coach.
coach
insignificant.
radiator
from
Removed
ring.
Assembled
Connected
air.
load on
> Hope this helps
> Scott
sharing
calling
> > -Ryan
like
> > > the first one did.
