8V92 normal operating temps
06-04-2008, 11:15
In another thread, Pete said:
> Series 60 _CAN_ have a dirty radiator (I know, I have one). Watch > your coolant temperature it should stick at 180 except under heavy > load (steep grade) when it may go to 190-200. If it goes above 200 -- > even if it doesn't overheat -- then you may have a partially clogged > radiator. Which prompted me to ask this question: What are normal operating temps for the 8V92? My coach runs ~200-210 on the freeway, ~220-225 when climbing a long grade. I've never seen it hit the 230 mark, though. Is this normal? And, what would you all consider to be the emergency shutdown temperature, also known as the point at which the driver poops himself trying to get the coach off the road and the engine shut down as quickly as possible? Would like to know, in case I do have a problem some day, would be nice to be able to save the engine. :-) -Ryan '86 PT-40 8V92 |
06-04-2008, 11:37
Ryan, are you talking water, or oil? Water at 220 would be a
disaster-waiting-to-happen, oil at 230 not so bad. With the digital readout from VMSpc, the highest water temp I think I've seen is 201, pulling a hard grade at 100+ degrees ambient. My analog gauge has no readings between 190 and 220, which makes it hard to get anything exact there. I have often seen 230 on the oil temp, although an IR gun on the pan does not confirm that (reads lower). The engine computer doesn't output oil temp. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 6/4/2008 at 4:15 PM Ryan Wright wrote: >In another thread, Pete said: > >> Series 60 _CAN_ have a dirty radiator (I know, I have one). Watch >> your coolant temperature it should stick at 180 except under heavy >> load (steep grade) when it may go to 190-200. If it goes above 200 -- >> even if it doesn't overheat -- then you may have a partially clogged >> radiator. > >Which prompted me to ask this question: What are normal operating >temps for the 8V92? My coach runs ~200-210 on the freeway, ~220-225 >when climbing a long grade. I've never seen it hit the 230 mark, >though. Is this normal? And, what would you all consider to be the >emergency shutdown temperature, also known as the point at which the >driver poops himself trying to get the coach off the road and the >engine shut down as quickly as possible? Would like to know, in case I >do have a problem some day, would be nice to be able to save the >engine. :-) > >-Ryan >'86 PT-40 8V92 |
06-04-2008, 12:04
If you look at post 22995 you can see what my bus does. It was in chart form when sent but grouped together. Look at the column headings and follow them to the numbers below L to R. If you can't figure it out I will email one to you if you want it.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Ryan Wright
06-04-2008, 12:25
Whoops. Yeah, I was confused. I was thinking about oil, Pete was
talking water. Nevermind!! Appreciate the replies though. -Ryan On Wed, Jun 4, 2008 at 4:37 PM, Don Bradner > Ryan, are you talking water, or oil? Water at 220 would be a > disaster-waiting-to-happen, oil at 230 not so bad. > > With the digital readout from VMSpc, the highest water temp I think I've > seen is 201, pulling a hard grade at 100+ degrees ambient. My analog gauge > has no readings between 190 and 220, which makes it hard to get anything > exact there. I have often seen 230 on the oil temp, although an IR gun on > the pan does not confirm that (reads lower). The engine computer doesn't > output oil temp. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > |
06-04-2008, 14:04
Oil shows 200 ~ 250 as "normal" in my Blue Box book. I have
occasionally seen near-230 on a steep grade. I doubt that the 8v92 would be much different than the Series 60 on oil temp. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at CCW in Riverside, CA On Jun 4, 2008, at 5:25 PM, Ryan Wright wrote: > Whoops. Yeah, I was confused. I was thinking about oil, Pete was > talking water. Nevermind!! Appreciate the replies though. > > -Ryan > > On Wed, Jun 4, 2008 at 4:37 PM, Don Bradner > >> Ryan, are you talking water, or oil? Water at 220 would be a >> disaster-waiting-to-happen, oil at 230 not so bad. >> >> With the digital readout from VMSpc, the highest water temp I >> think I've >> seen is 201, pulling a hard grade at 100+ degrees ambient. My >> analog gauge >> has no readings between 190 and 220, which makes it hard to get >> anything >> exact there. I have often seen 230 on the oil temp, although an IR >> gun on >> the pan does not confirm that (reads lower). The engine computer >> doesn't >> output oil temp. >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> Eureka, CA >> > > ------------------------------------ > > Yahoo! Groups Links > > > |
