					Gen batt charging circuit diode
					06-07-2008, 07:19
				 Post: #1 | |||
					I need to replace the doide in the generator battery charging circuit, does anyone know the specifications for that item? Scott Forman 86 PT38 Memphis | |||
					06-08-2008, 03:49
				 Post: #2 | |||
					Scott, Tom Sorrentino and I just replaced ours with a Blue Sea Systems "Battery Link ACR". It works flawlessly- linking the two banks only when voltage is over 13.4 and separating them at levels below that. It was literally a "drop-in" replacement- although I used a little heavier wire for those "just in case" moments. There is zero voltage drop- my generator has never cranked as fast as it does now! Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I need to replace the doide in the generator battery charging circuit, > does anyone know the specifications for that item? > > Scott Forman > 86 PT38 > Memphis > | |||
					06-08-2008, 04:37
				 Post: #3 | |||
					Scott, I have to agree with what Shane said. I would just upgrade to the Battery Link ACR. My generator has never cranked as fast as it does now either! I could probably find the old diode I took out, if you want it. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Scott, > > Tom Sorrentino and I just replaced ours with a Blue Sea Systems > "Battery Link ACR". It works flawlessly- linking the two banks only > when voltage is over 13.4 and separating them at levels below that. It > was literally a "drop-in" replacement- although I used a little > heavier wire for those "just in case" moments. There is zero voltage > drop- my generator has never cranked as fast as it does now! > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > I need to replace the doide in the generator battery charging circuit, > > does anyone know the specifications for that item? > > > > Scott Forman > > 86 PT38 > > Memphis > > > | |||
					06-08-2008, 06:12
				 Post: #4 | |||
					What does this cost and where do I get it? Scott --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Scott, > > I have to agree with what Shane said. I would just upgrade to the > Battery Link ACR. My generator has never cranked as fast as it does > now either! I could probably find the old diode I took out, if you > want it. > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > wrote: > > > > Scott, > > > > Tom Sorrentino and I just replaced ours with a Blue Sea Systems > > "Battery Link ACR". It works flawlessly- linking the two banks only > > when voltage is over 13.4 and separating them at levels below that. > It > > was literally a "drop-in" replacement- although I used a little > > heavier wire for those "just in case" moments. There is zero voltage > > drop- my generator has never cranked as fast as it does now! > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > wrote: > > > > > > I need to replace the doide in the generator battery charging > circuit, > > > does anyone know the specifications for that item? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > | |||
					06-08-2008, 06:43
				 Post: #5 | |||
					Scott, I got mine at westmarine. Their part number 6917124 $77.99. One of the better upgrades I've done. I think Gardner Yeaw did one also. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > What does this cost and where do I get it? > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > Scott, > > > > I have to agree with what Shane said. I would just upgrade to the > > Battery Link ACR. My generator has never cranked as fast as it does > > now either! I could probably find the old diode I took out, if you > > want it. > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > > wrote: > > > > > > Scott, > > > > > > Tom Sorrentino and I just replaced ours with a Blue Sea Systems > > > "Battery Link ACR". It works flawlessly- linking the two banks > only > > > when voltage is over 13.4 and separating them at levels below > that. > > It > > > was literally a "drop-in" replacement- although I used a little > > > heavier wire for those "just in case" moments. There is zero > voltage > > > drop- my generator has never cranked as fast as it does now! > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > > wrote: > > > > > > > > I need to replace the doide in the generator battery charging > > circuit, > > > > does anyone know the specifications for that item? > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > | |||
					06-08-2008, 07:06
				 Post: #6 | |||
					Thank you sir, I will pick one up Scott --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Scott, > > I got mine at westmarine. Their part number 6917124 $77.99. One of > the better upgrades I've done. I think Gardner Yeaw did one also. > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > What does this cost and where do I get it? > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > > > > Scott, > > > > > > I have to agree with what Shane said. I would just upgrade to the > > > Battery Link ACR. My generator has never cranked as fast as it > does > > > now either! I could probably find the old diode I took out, if > you > > > want it. > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > > > wrote: > > > > > > > > Scott, > > > > > > > > Tom Sorrentino and I just replaced ours with a Blue Sea > Systems > > > > "Battery Link ACR". It works flawlessly- linking the two banks > > only > > > > when voltage is over 13.4 and separating them at levels below > > that. > > > It > > > > was literally a "drop-in" replacement- although I used a little > > > > heavier wire for those "just in case" moments. There is zero > > voltage > > > > drop- my generator has never cranked as fast as it does now! > > > > > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> > > > > wrote: > > > > > > > > > > I need to replace the doide in the generator battery charging > > > circuit, > > > > > does anyone know the specifications for that item? > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > Memphis > > > > > > > > > > > > > > > | |||
					06-08-2008, 12:56
				 Post: #7 | |||
					Scott, Yes, I did install one on my '78. It is nice to have a visual indication that things are working, and the genie does seem to crank faster. I destroyed my original generator battery when I forgot to open the disconnect switch. The old diode or whatever let it drain to zero. The new ACR should prevent such mishaps as well. Gardner 78GC33 --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Scott, > > I got mine at westmarine. Their part number 6917124 $77.99. One of > the better upgrades I've done. I think Gardner Yeaw did one also. > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > What does this cost and where do I get it? > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > > > > Scott, > > > > > > I have to agree with what Shane said. I would just upgrade to the > > > Battery Link ACR. My generator has never cranked as fast as it > does > > > now either! I could probably find the old diode I took out, if > you > > > want it. > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > > > wrote: > > > > > > > > Scott, > > > > > > > > Tom Sorrentino and I just replaced ours with a Blue Sea > Systems > > > > "Battery Link ACR". It works flawlessly- linking the two banks > > only > > > > when voltage is over 13.4 and separating them at levels below > > that. > > > It > > > > was literally a "drop-in" replacement- although I used a little > > > > heavier wire for those "just in case" moments. There is zero > > voltage > > > > drop- my generator has never cranked as fast as it does now! > > > > > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> > > > > wrote: > > > > > > > > > > I need to replace the doide in the generator battery charging > > > circuit, > > > > > does anyone know the specifications for that item? > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > Memphis > > > > > > > > > > > > > > > | |||
					06-08-2008, 13:08
				 Post: #8 | |||
					I just got one off ebay, came out to about the same price with shipping and tax... See this sellers store, "internet mall" for details. BTW, Im not associated with him at all! So YMMV :} I just finished hooking up a solar panel and charge controller this afternoon, it was putting over 4A into the batteries... I hope this will keep the batteries charged up since where its stored I cant plug it in. /Joe '87 PT40 San Francisco --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > What does this cost and where do I get it? > > Scott > | |||
					06-08-2008, 14:21
				 Post: #9 | |||
					Anyone purchase and install the ON-OFF-ON switch for the Battery Link ACR? [b] | |||
					06-09-2008, 01:21
				 Post: #10 | |||
					It works just fine without it. If you want another switch for the dash, you'll only need another 40' of wire and a new LED. It is a pretty straightforward install. Just to be on the safe side, I also installed a resettable marine grade 80 amp breaker on the hot side. --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Anyone purchase and install the ON-OFF-ON switch for the Battery Link ACR?* > *<http://www.google.com/url?sa=t&ct=res&cd...2Fene\ rgycitations%2Fproduct.biblio.jsp%3Fosti_id%3D6917124&ei=p5BMSOWhDIOKpwSspr25BA&\ usg=AFQjCNEWmmhxjSyZccKSAqn62AKkoszFOg&sig2=vNzvfetNNz9HHjhyXcTzng> > On Sun, Jun 8, 2008 at 6:08 PM, joepat50 > > > I just got one off ebay, came out to about the same price with > > shipping and tax... > > > > See this sellers store, "internet mall" for details. > > > > BTW, Im not associated with him at all! So YMMV :} > > > > I just finished hooking up a solar panel and charge controller this > > afternoon, it was putting over 4A into the batteries... I hope this > > will keep the batteries charged up since where its stored I cant plug > > it in. > > > > /Joe > > '87 PT40 > > San Francisco > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "Scott Forman" <sforman@> > > wrote: > > > > > > What does this cost and where do I get it? > > > > > > Scott > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
