1111Aa RV3012M inverter installation photos
06-12-2008, 06:55
Of course, you can run double 4/0 (two 4/0 cables for + and two for -) or get railroad engine cable which is about 4 to 9 times the cross-sectional area of 4/0 and therefore about 1/4 to 1/9 the voltage drop for a given current. If you run two or more parallel runs of 4/0, they each carry 1/2 or 1/3 or whatever fraction of the amperage and have correspondingly lower voltage drops. I've been considering running individual 4/0 from each battery and gathering them at the inverter terminal or a nearby bus-bar.
On Thu, Jun 12, 2008 at 1:39 PM, pgchd <"pgchin@bellsouth.net"> wrote:
06-12-2008, 07:30
Thanks Everybody,
The time has come to S--T or get off the Pot! No responce yet from BB. I've got no more time to waste on reinventing the wheel. The new inverters are going back into the same place as the old ones. As noted most of these inverters have been in this location for years. Mine have been there since 1995 so it's probably not as bad as some belive it to be. Anyway this frees up some funds for other projects. Kurt Horvath 95 PT-42 10AC |
06-12-2008, 07:38
Kurt,Â
I gotta say, I was thinking that the current location isn't all that bad. I went down and looked over my inverters -- yes, there's a bit of dirt/dust that has accumulated in the metal box -- but it's not a super serious build up. I _think_ the previous owner may have replaced the inverters. At least, he installed a Link 2000 R controller (which is somewhat more sophisticated than the original, as I understand). If he replaced the inverters, they were the exact same model as the original. I'm guessing that was the case as I have 4 "owners manuals" for the two inverters. Next time I have my work clothes on and a dust mask and goggles, I'm going to use some compressed air to blow out the dirt in the inverter box. I'm guessing that it will be pretty gross... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 12, 2008, at 12:30 PM, bumpersbird wrote:
06-12-2008, 08:09
Kurt, I agree with you. Thanks for sharing all of your research but I think you are right to keep the inverters in the original location. I'll put my single unit in the same location as the Rediline was in the rear engine compartment. Will close off the interior side towards the engine & leave the exterior side open for ventilation. Should keep much of the dirt off the inverter & it's only a couple of feet to the battery bank. Thanks again, Terry Terry Neal |
06-12-2008, 08:15
I was just finishing putting everything back in bay three and I am
now wondering should I put the electric grill back in or get the gas fired Infrared BBQ that I have been drooling over, OH I love seared beef! My inverterd box is dirty to, but from the start heat was the issue. no worries when the engine gill fans are installed their will be 3300 CFM sucking hot air out of the engine box. If that doesn't work nothing will. Jessie from BB Tech just called and said they never went past whatever cables they got from Xantrex. So that answers that question. Thanks, Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Kurt, > > I gotta say, I was thinking that the current location isn't all that > bad. I went down and looked over my inverters -- yes, there's a bit > of dirt/dust that has accumulated in the metal box -- but it's not a > super serious build up. > > I _think_ the previous owner may have replaced the inverters. At > least, he installed a Link 2000 R controller (which is somewhat more > sophisticated than the original, as I understand). If he replaced the > inverters, they were the exact same model as the original. I'm > guessing that was the case as I have 4 "owners manuals" for the two > inverters. > > Next time I have my work clothes on and a dust mask and goggles, I'm > going to use some compressed air to blow out the dirt in the inverter > box. I'm guessing that it will be pretty gross... > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jun 12, 2008, at 12:30 PM, bumpersbird wrote: > > > Thanks Everybody, > > > > The time has come to S--T or get off the Pot! > > > > No responce yet from BB. > > > > I've got no more time to waste on reinventing the wheel. > > > > The new inverters are going back into the same place as the old ones. > > > > As noted most of these inverters have been in this location for > > years. > > > > Mine have been there since 1995 so it's probably not as bad as some > > belive it to be. > > > > Anyway this frees up some funds for other projects. > > > > Kurt Horvath > > 95 PT-42 > > 10AC > > > |
06-12-2008, 08:48
Kurt, Go for the gas infrared and be happy. Then you only have to put the grill back in one time... Terry Neal |
06-12-2008, 09:13
WHHOOOOOOOAOOAAAA! It's hot here in 10AC.
It must be BEER:30 Came in for a cold one. The Indugance has a propane tank, 45 gallons. On the curb side fuel hatch, just under the diesel fill is a real convenient quick detachable gas connection with an on-off valve. Looks like the female end of an air hose. I also carry a Smokey Joe BBQ. Sometimes just gotta throw it to the smoke! Whenever I need propane Flying J's RV island got it all. They usually give you 0.05 off per gallon over regular price with the F-J card. With that much propane onboard I have though about propane injection, but like this inverter project, I hear people saying it works but, I don't see anybody rushing to use it. Kurt Horvath 95 PT-42 10AC |
06-12-2008, 09:13
06-12-2008, 10:05
Hi Kurt, The wire is 4/0. I didn't take a real accurate measurement of the length, and I left the bus a moment ago. (Less than14 ft length estimate). David Brady '02 LXi, NC bumpersbird wrote:
