leaky AC compressor
06-15-2008, 15:38
leaky AC compressor
Folks,
I've noticed that my AC compressor is leaking something red in color. Is this R12 or R134a? Does the compressor use some sort of lubricant or is it lubed by the refrigerant? David '02 LXi, NC |
06-15-2008, 17:19
leaky AC compressor
The refrigerant in your '02 is almost certainly R134a. The lube used
in the compressor is a special low temperature ester oil. All the lubes I have seen are colorless or nearly colorless. The red color you see is likely a dye that has been put in the freon to identify the position of a freon leak. It's also illuminates with UV light. You didn't mention where the leak is. The only opening is the shaft seal, under the clutch. On my compressor it would be very hard to see the shaft seal area because the clutch is in the way. If the leak is around a fitting or around a flange you may be lucky enough to have a loose fastener. Does your a/c system still cool? Eric Perplies 96' 42' WBWL --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > I've noticed that my AC compressor is leaking something red > in color. Is this R12 or R134a? Does the compressor use some > sort of lubricant or is it lubed by the refrigerant? > > David > '02 LXi, NC > |
06-16-2008, 02:29
leaky AC compressor
Thanks Eric, It is leaking from behind the clutch in the vicinity of the shaft seal. The AC does still cool, and quite well. I'll check the bolts. Around 2 years ago BB replaced the a seal on the compressor, probably the shaft seal but I don't recall for certain. I'll have to sift through some old receipts. If it is the shaft seal, and the ester oil is leaking out, is there a fill plug to add oil? Will I risk damaging the unit if I continue to run. I would guess that I would if the compressor is starting to run low on lubricating oil. David Brady '02 LXi, NC Eric Perplies wrote:
06-16-2008, 04:08
leaky AC compressor
The problem is that a leak is a leak is a leak. You are losing oil, dye, and
coolant, equally, until you have no pressure left. Most likely a low-pressure cutout switch in the circuit somewhere will stop the compressor from engaging when it gets too low, making the lack of lubricant immaterial. Getting it fixed before you lose a few hundred dollars worth of coolant could be a good idea... Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 6/16/2008 at 9:29 AM David Brady wrote: >Thanks Eric, > >It is leaking from behind the clutch in the vicinity of the >shaft seal. The AC does still cool, and quite well. I'll check >the bolts. Around 2 years ago BB replaced the a seal on >the compressor, probably the shaft seal but I don't recall >for certain. I'll have to sift through some old receipts. If >it is the shaft seal, and the ester oil is leaking out, is there >a fill plug to add oil? Will I risk damaging the unit if I >continue to run. I would guess that I would if the compressor >is starting to run low on lubricating oil. > >David Brady >'02 LXi, NC |
06-16-2008, 08:17
leaky AC compressor
Yup, it seems these compressors need service of some sort or another every 2 years. sigh... David Brady '02 LXi, NC Don Bradner wrote:
06-16-2008, 18:19
leaky AC compressor
As Don mentioned there is no other solution than replace the seal or
the compressor. I have had a leaking seal also. I wondered what caused the leaking seal. I decided to carefully inspect the compressor. I found that the sheaves on the compressor were out of alignment with respect to the engine output pulley. Because the compressor mount was SO massive I looked elsewhere to find what was wrong. It turned out that the big hinge joint that the compressor pivots on has worn the frame of the mount. I had a new pin made and the frame re-bored. The point is: Inspect the alignment of the two sets of sheaves. A long straight piece of metal should be all you need. I choose to replace the whole compressor, clutch and sheaves. I found a great price on this item from http://www.ryderfleetproducts.com I think it was about $225. Only a few times the price of just a seal. If you are going to go this route buy the compressor yourself. A refrigeration supply house or a shop will likely charge many times this cost. Note too that the suction and pressure fittings on your freon compressor likely has shutoff valves built into them. If you can shut both the valves off you can likely keep the freon in your system from leaking out. One of my valves were frozen. You may be luckier. Good luck, Eric Perplies 96' 42' WBWL --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > I've noticed that my AC compressor is leaking something red > in color. Is this R12 or R134a? Does the compressor use some > sort of lubricant or is it lubed by the refrigerant? > > David > '02 LXi, NC > |
06-17-2008, 14:15
leaky AC compressor
David Do you know of any source for the AC compressor other than the CCW. I called Fort Valley their price for the compressorfor the97 WB 43ft. is $720.00for new and $620.00 for rebuild unit. I would appreciate any informationif there are any other sourcesavailable thatsell these compressors. Hisham Amaral 97 WB 43' Wanderlodge West Bloomfield MI David Brady
06-17-2008, 15:41
leaky AC compressor
Most Napa stores and truck supply stores will have the compressor.
Just bring type and model #. Steve Gureasko 90 WBWL 40 Jus Chillin Ponchatoula, La. |
06-17-2008, 15:52
leaky AC compressor
Hi Hisham, No, I haven't looked into it yet. Two years ago BB replaced the shaft seal on my compressor for $270.00. I found the receipt but it doesn't have a part number for the seal. I'll probably do seal replacement again. If you spring for a new compressor, you may find it failing again in a couple of years... A seal destroying groove on the shaft may be repaired with a Speedi-sleeve or Redi-Sleeve, available at most transmission shops or even at Napa. I'm going to try to repair mine. David Brady '02 LXi, NC Hisham Amaral wrote:
06-17-2008, 17:51
leaky AC compressor
There are 1872 "AC compressor" listings on eBay. You could probably narrow that down with a model number or brand. At least, the eBay listings might give you a lead on a vendor.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 17, 2008, at 7:15 PM, Hisham Amaral wrote:
