Gen Fan Relay
05-23-2005, 03:58
Gen Fan Relay
Derk,
If you are getting 120 volts on both legs you're getting 240 volts from the
genset. Sounds like the fan (blower on mine) is not getting
current or is defective.
Bill in Roanoke, VA
1987 FC-35 12.5 Kohler with Yanmar engine
05-23-2005, 05:20
Gen Fan Relay
Ok I'm confused, if there is no thermostat relay to turn the fan motor
on how will the diesel engine get up to operating temp? The other reply
says that it in the neck set which is where?
Derk
79FC 35
05-23-2005, 06:04
Gen Fan Relay
The perkins engine has a thermostat valve in the return to the radiator
like most engines, doesn't open until the engine is warm enough to
require radiator cooling.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, "derkallaben"
motor
reply
> Derk
> 79FC 35
05-23-2005, 06:48
Gen Fan Relay
I have a '85 12.5 Kohler and from the neck to the expansion tank is
mounted a Kysor thermo switch. There is a 1/2" pipe coming off the top
of the block that tee's , one to the expansion tank, the other is where
the switch is mounted. That is how mine is set up. Not saying yours is
that way. I will look at mine tonight to see if there is a thermostat.
I do not know what they did in '79 just trying to help.
>>> dallaben@... 05/23/05 1:20 PM >>>
Derk
79FC 35
Yahoo! Groups Links
To visit your group on the web, go to:
05-23-2005, 07:49
Gen Fan Relay
Ok the the electric fan on the radiator is suppose to run all of the
time the genset is on, if the genset is making 220 and the thermostat
opens and closes like it should. How can I tell if I am making 220? I
know I am getting 115 out of the genset.
Derk
79FC 35
05-23-2005, 09:25
Gen Fan Relay
Hi Bill in Roanoke,
Just curious,
I thought all 87,88, 89FC's had the
8.0 k Onan.
Bill in Michigan 88 FC
--- In WanderlodgeForum@yahoogroups.com, racin41@a... wrote:
> Derk,
from the
> Bill in Roanoke, VA
05-23-2005, 12:09
Gen Fan Relay
The 8.0 Onan became standard in the FC in '88, streetside, along with
2 roof A/Cs.
The 12.5kw on a streetside slideout (side-bath) or curbside (rear
bath) was still optional as were triple roof A/Cs.
http://www.millercoachworks.com/Silver.html
- Jeff Miller
http://www.wanderlodge.net
> Hi Bill in Roanoke,
> Just curious,
> 8.0 k Onan.
> > Derk,
volts
> from the
> > Bill in Roanoke, VA
