Plumbing materials
07-01-2008, 11:55
Plumbing materials
I noticed when I removed my hot water heater the coach had copper &
galvanized fittings. The galvanized fittings sure seemed corroded.
Shouldn't these all be copper fittings?
Michael Putz
78FC35 "Putz'n Around"
Mesa, Az
07-01-2008, 12:19
Plumbing materials
Ideally, all the fittings would be copper. Considering the age of your FC, a previous owner may have taken a short cut and used galvanized fittings when replacing/repairing various components.
In a home I once lived in, copper plumbing was used, except the last few inches to the various fixtures were fitted with galvanized nipples and other fittings. When the house was 20-30 years old, those were really bad... and it was a lot of work to get them out, etc. The small economy involved at the time they were installed hardly seemed like a reasonable savings, but "lowest bidder" sometimes means shortcuts are taken.
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
Michael Putz
Mesa, Az
07-01-2008, 12:40
Plumbing materials
Mike,you putz!, copper threaded parts are best to be fitted with a
harder metal. I think that is where they used the galv?? I replace
the galv fittings with brass even if there is copper avaliable. A
copper threaded with copper ends up screwing the threads (both are
soft). Using brass or galv keeps the threads erect. when you thread
a male plastic fitting into the copper, the plastic ID is way small
and it is hard to back out. Working with old copper lines I fit a good
treaded pipe wrench close to the copper fitting to hold the stress
from twisting the old line (for every action there is a equal and
opposit reaction)
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@...>
> Michael Putz
> Mesa, Az
07-01-2008, 14:22
Plumbing materials
Michael:
I am in the process of changing my water heater as well, and yes, I would think so.
I have changed all of my piping inside my coach to Pex, with Wirsbo fittings, but fitting coming from the heater and all will be changed from iron to copper.
What heater are you installing in your coach?
Terrace, B.C. Canada
----- Original Message ----
Sent: Tuesday, July 1, 2008 4:55:37 PM
Subject: [WanderlodgeForum] Plumbing materials
Michael Putz
Mesa, Az
İmageYahoo! Canada Toolbar : Search from anywhere on the web and bookmark your favourite sites. Download it now!
07-01-2008, 14:24
Plumbing materials
Greg:
Good point, hey you not as dumb as you look LOL.
Thanks for the good advice.
Say hi to Tim.
Sent: Tuesday, July 1, 2008 5:40:01 PM
Subject: [WanderlodgeForum] Re: Plumbing materials
opposit reaction)
GregoryO'Connor
94ptRomolandCa
--- In "WanderlodgeForum%40yahoogroups.com", "Michael" <mike.putz@. ..>
> I noticed when I
> Michael Putz
> Mesa, Az
07-01-2008, 15:34
Plumbing materials
But there will be galvanic action between the Cu and the Zn;
hence, the corroded galvanized fittings...
David
'02 LXi, NC
opposit reaction)
GregoryO'Connor
94ptRomolandCa
"Michael" <mike.putz@.<wbr>..>
> Michael Putz
> Mesa, Az
Checked by AVG. Version: 7.5.526 / Virus Database: 270.4.3/1527 - Release Date: 6/30/2008 6:07 PM
07-01-2008, 17:20
Plumbing materials
Hey Bill,
I'm replacing it with a WH1000-001 11 gal water heater from
Dupree Products. Rick was very helpful, informative, and I felt
comfortable with his knowledge. I was going to replace it with a
standard low boy style heater, but the heat exchanger model was only
a few dollars more and can aid in engine cooling too. Since all the
plumbing was already in place it just made more sense.
In my '63 Bird I had installed all copper and had freezing issues
when the bus was stored up in Kingman for a few years (blown
engine). I then had to open the walls and replace all the copper
with Qwest and have never had issue again. Now I'm finding an
abundance of copper in my new Bird and it scares me. I'll replace
the fittings to the appliances with brass but will be using some
other material every where else as I go through the coach.
Michael Putz
Mesa, Az
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> Michael:
would think so.
> From: Michael <mike.putz@...>
> Michael Putz
> Mesa, Az
__________________________________________________________________
> Yahoo! Canada Toolbar: Search from anywhere on the web, and
bookmark your favourite sites. Download it now at
> http://ca.toolbar.yahoo.com.
07-01-2008, 22:43
Plumbing materials
Take caution with any metal pipe fittings at the HWT.
The tank is aluminum and soft, MFG. recommends, plastic or a pipe
dope lubricant, it is possible to pull the threads out of this
expensive appliance.
BIll 88 FC Michigan
> Hey Bill,
only
> Michael Putz
> Mesa, Az
> > Michael:
I
> would think so.
Wirsbo
changed
> > From: Michael <mike.putz@>
corroded.
> > Michael Putz
> > Mesa, Az
07-02-2008, 02:26
Plumbing materials
Thanx Bill, I was not aware of that. With the heat involved from the
heater itself and from the engine recirucalation I'll stick with
brass but will use an anti-siezing agent.
Michael Putz
Mesa, Az
> BIll 88 FC Michigan
> --- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@>
> > Hey Bill,
> only
> the
replace
> > Michael Putz
> > Mesa, Az
> > wrote:
> > > Michael:
yes,
> I
> > would think so.
> Wirsbo
> changed
copper
> corroded.
> > > Michael Putz
> > > Mesa, Az
07-02-2008, 04:34
Plumbing materials
Michael:
Replacing all of the copper lines in the water system, not the heating system, was relatively easy. The hardest part was putting the new lines up totheshower area. I did not have to take any walls down, but I did have to take the water tank, rear furnace,and ice maker out.
I also installed a chillipepper (cold water circulator) in the bathroom, so I can get hotwater without wasting it.
