Plumbing materials
07-01-2008, 11:55
Plumbing materials
I noticed when I removed my hot water heater the coach had copper &
galvanized fittings. The galvanized fittings sure seemed corroded. Shouldn't these all be copper fittings? Michael Putz 78FC35 "Putz'n Around" Mesa, Az |
07-01-2008, 12:19
Plumbing materials
Ideally, all the fittings would be copper. Considering the age of your FC, a previous owner may have taken a short cut and used galvanized fittings when replacing/repairing various components.
In a home I once lived in, copper plumbing was used, except the last few inches to the various fixtures were fitted with galvanized nipples and other fittings. When the house was 20-30 years old, those were really bad... and it was a lot of work to get them out, etc. The small economy involved at the time they were installed hardly seemed like a reasonable savings, but "lowest bidder" sometimes means shortcuts are taken. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jul 1, 2008, at 4:55 PM, Michael wrote:
07-01-2008, 12:40
Plumbing materials
Mike,you putz!, copper threaded parts are best to be fitted with a
harder metal. I think that is where they used the galv?? I replace the galv fittings with brass even if there is copper avaliable. A copper threaded with copper ends up screwing the threads (both are soft). Using brass or galv keeps the threads erect. when you thread a male plastic fitting into the copper, the plastic ID is way small and it is hard to back out. Working with old copper lines I fit a good treaded pipe wrench close to the copper fitting to hold the stress from twisting the old line (for every action there is a equal and opposit reaction) GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@...> wrote: > > I noticed when I removed my hot water heater the coach had copper & > galvanized fittings. The galvanized fittings sure seemed corroded. > Shouldn't these all be copper fittings? > > Michael Putz > 78FC35 "Putz'n Around" > Mesa, Az > |
07-01-2008, 14:22
Plumbing materials
Michael:
I am in the process of changing my water heater as well, and yes, I would think so.
I have changed all of my piping inside my coach to Pex, with Wirsbo fittings, but fitting coming from the heater and all will be changed from iron to copper.
What heater are you installing in your coach? Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada ----- Original Message ---- From: Michael <mike.putz@...> To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 1, 2008 4:55:37 PM Subject: [WanderlodgeForum] Plumbing materials I noticed when I removed my hot water heater the coach had copper & galvanized fittings. The galvanized fittings sure seemed corroded. Shouldn't these all be copper fittings? Michael Putz 78FC35 "Putz'n Around" Mesa, Az
07-01-2008, 14:24
Plumbing materials
Greg: Good point, hey you not as dumb as you look LOL. Thanks for the good advice. Say hi to Tim. Terrace, B.C. Canada ----- Original Message ---- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 1, 2008 5:40:01 PM Subject: [WanderlodgeForum] Re: Plumbing materials Mike,you putz!, copper threaded parts are best to be fitted with a harder metal. I think that is where they used the galv?? I replace the galv fittings with brass even if there is copper avaliable. A copper threaded with copper ends up screwing the threads (both are soft). Using brass or galv keeps the threads erect. when you thread a male plastic fitting into the copper, the plastic ID is way small and it is hard to back out. Working with old copper lines I fit a good treaded pipe wrench close to the copper fitting to hold the stress from twisting the old line (for every action there is a equal and opposit reaction) GregoryO'Connor 94ptRomolandCa --- In "WanderlodgeForum%40yahoogroups.com", "Michael" <mike.putz@. ..> wrote: > > I noticed when I removed my hot water heater the coach had copper & > galvanized fittings. The galvanized fittings sure seemed corroded. > Shouldn't these all be copper fittings? > > Michael Putz > 78FC35 "Putz'n Around" > Mesa, Az >
07-01-2008, 15:34
Plumbing materials
But there will be galvanic action between the Cu and the Zn; hence, the corroded galvanized fittings... David '02 LXi, NC Gregory OConnor wrote:
07-01-2008, 17:20
Plumbing materials
Hey Bill,
I'm replacing it with a WH1000-001 11 gal water heater from Dupree Products. Rick was very helpful, informative, and I felt comfortable with his knowledge. I was going to replace it with a standard low boy style heater, but the heat exchanger model was only a few dollars more and can aid in engine cooling too. Since all the plumbing was already in place it just made more sense. In my '63 Bird I had installed all copper and had freezing issues when the bus was stored up in Kingman for a few years (blown engine). I then had to open the walls and replace all the copper with Qwest and have never had issue again. Now I'm finding an abundance of copper in my new Bird and it scares me. I'll replace the fittings to the appliances with brass but will be using some other material every where else as I go through the coach. Michael Putz 78FC35 "Putz'n Around" Mesa, Az --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Michael: > I am in the process of changing my water heater as well, and yes, I would think so. > I have changed all of my piping inside my coach to Pex, with Wirsbo fittings, but fitting coming from the heater and all will be changed from iron to copper. > What heater are you installing in your coach? > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Michael <mike.putz@...> > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, July 1, 2008 4:55:37 PM > Subject: [WanderlodgeForum] Plumbing materials > > > I noticed when I removed my hot water heater the coach had copper & > galvanized fittings. The galvanized fittings sure seemed corroded. > Shouldn't these all be copper fittings? > > Michael Putz > 78FC35 "Putz'n Around" > Mesa, Az > > > > > __________________________________________________________________ > Yahoo! Canada Toolbar: Search from anywhere on the web, and bookmark your favourite sites. Download it now at > http://ca.toolbar.yahoo.com. > |
07-01-2008, 22:43
Plumbing materials
Take caution with any metal pipe fittings at the HWT.
The tank is aluminum and soft, MFG. recommends, plastic or a pipe dope lubricant, it is possible to pull the threads out of this expensive appliance. BIll 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@...> wrote: > > Hey Bill, > I'm replacing it with a WH1000-001 11 gal water heater from > Dupree Products. Rick was very helpful, informative, and I felt > comfortable with his knowledge. I was going to replace it with a > standard low boy style heater, but the heat exchanger model was only > a few dollars more and can aid in engine cooling too. Since all the > plumbing was already in place it just made more sense. > > In my '63 Bird I had installed all copper and had freezing issues > when the bus was stored up in Kingman for a few years (blown > engine). I then had to open the walls and replace all the copper > with Qwest and have never had issue again. Now I'm finding an > abundance of copper in my new Bird and it scares me. I'll replace > the fittings to the appliances with brass but will be using some > other material every where else as I go through the coach. > > Michael Putz > 78FC35 "Putz'n Around" > Mesa, Az > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > Michael: > > I am in the process of changing my water heater as well, and yes, I > would think so. > > I have changed all of my piping inside my coach to Pex, with Wirsbo > fittings, but fitting coming from the heater and all will be changed > from iron to copper. > > What heater are you installing in your coach? > > Bill 84 FC 35 SB "$quanderlodge" > > Terrace, B.C. Canada > > > > > > > > > > ----- Original Message ---- > > From: Michael <mike.putz@> > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, July 1, 2008 4:55:37 PM > > Subject: [WanderlodgeForum] Plumbing materials > > > > > > I noticed when I removed my hot water heater the coach had copper & > > galvanized fittings. The galvanized fittings sure seemed corroded. > > Shouldn't these all be copper fittings? > > > > Michael Putz > > 78FC35 "Putz'n Around" > > Mesa, Az > > > > > > > > > > > __________________________________________________________________ > > Yahoo! Canada Toolbar: Search from anywhere on the web, and > bookmark your favourite sites. Download it now at > > http://ca.toolbar.yahoo.com. > > > |
07-02-2008, 02:26
Plumbing materials
Thanx Bill, I was not aware of that. With the heat involved from the
heater itself and from the engine recirucalation I'll stick with brass but will use an anti-siezing agent. Michael Putz 78FC35 "Putz'n Around" Mesa, Az --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Take caution with any metal pipe fittings at the HWT. > The tank is aluminum and soft, MFG. recommends, plastic or a pipe > dope lubricant, it is possible to pull the threads out of this > expensive appliance. > > BIll 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Michael" <mike.putz@> > wrote: > > > > Hey Bill, > > I'm replacing it with a WH1000-001 11 gal water heater from > > Dupree Products. Rick was very helpful, informative, and I felt > > comfortable with his knowledge. I was going to replace it with a > > standard low boy style heater, but the heat exchanger model was > only > > a few dollars more and can aid in engine cooling too. Since all > the > > plumbing was already in place it just made more sense. > > > > In my '63 Bird I had installed all copper and had freezing issues > > when the bus was stored up in Kingman for a few years (blown > > engine). I then had to open the walls and replace all the copper > > with Qwest and have never had issue again. Now I'm finding an > > abundance of copper in my new Bird and it scares me. I'll replace > > the fittings to the appliances with brass but will be using some > > other material every where else as I go through the coach. > > > > Michael Putz > > 78FC35 "Putz'n Around" > > Mesa, Az > > > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > > > > Michael: > > > I am in the process of changing my water heater as well, and yes, > I > > would think so. > > > I have changed all of my piping inside my coach to Pex, with > Wirsbo > > fittings, but fitting coming from the heater and all will be > changed > > from iron to copper. > > > What heater are you installing in your coach? > > > Bill 84 FC 35 SB "$quanderlodge" > > > Terrace, B.C. Canada > > > > > > > > > > > > > > > ----- Original Message ---- > > > From: Michael <mike.putz@> > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Tuesday, July 1, 2008 4:55:37 PM > > > Subject: [WanderlodgeForum] Plumbing materials > > > > > > > > > I noticed when I removed my hot water heater the coach had copper > & > > > galvanized fittings. The galvanized fittings sure seemed > corroded. > > > Shouldn't these all be copper fittings? > > > > > > Michael Putz > > > 78FC35 "Putz'n Around" > > > Mesa, Az > > > > > > > > > > > > > > > > > __________________________________________________________________ > > > Yahoo! Canada Toolbar: Search from anywhere on the web, and > > bookmark your favourite sites. Download it now at > > > http://ca.toolbar.yahoo.com. > > > > > > |
07-02-2008, 04:34
Plumbing materials
Michael:
Replacing all of the copper lines in the water system, not the heating system, was relatively easy. The hardest part was putting the new lines up totheshower area. I did not have to take any walls down, but I did have to take the water tank, rear furnace,and ice maker out.
I also installed a chillipepper (cold water circulator) in the bathroom, so I can get hotwater without wasting it. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada
