HWH jack wont extend, 94pt
08-05-2008, 13:06
I was preping my bus for radiator removal/rodding and new compressor
cooling lines today and I jacked the jack. I attempted to lift the
back end using two 8x8 timbers under the jack pads to gain some
height for frame jacksstands. the drivers side timber abruptly rolled
a bit in the gravel so I decided to drop the bus and use wider blocks
under the pads. the jacks retracted and I was never able to get the
drive/rear jack to extend once again?
The 94 hwh control pad only allow you to choose a pair of jacks or
auto level ;Both front ;both back ;both left ;both right or auto
level. I tried every combination to extend Drive/rear jack, no luck.
I wonder if I Knocked a sensor loose on the jack or confused the hwh
computer?
GregoryO'Connor
94ptRomolandCa
08-05-2008, 13:21
Gregory,
Don't forget when the rear wheels come off the ground the bus can
roll since the spring brakes are on the rear wheels only. Be sure
you have really big and strong wheel chocks on the front. Not those
cheesy stamped steel ones.
Gardner
83FC35
compressor
rolled
blocks
luck.
hwh
> computer?
> GregoryO'Connor
> 94ptRomolandCa
08-05-2008, 14:02
Greg
Every once and a while the switch on mine that is suppose to sense that the brakes are set doesn¢t work right. It is located in the generator compartment high to the left with either a green or green / white wire to both sides (this is from memory, an almost 60 yr old memory).
Try to jump the switch and see if it works.
Steve Quandt
Iron Mountain, MI
1993 PT-40
----- Original Message ----
Sent: Tuesday, August 5, 2008 8:06:15 PM
Subject: [WanderlodgeForum] HWH jack wont extend, 94pt
computer?
GregoryO'Connor
94ptRomolandCa
08-05-2008, 15:54
Steve and Gardner, thanks both good info to add. I got a call from
Canada with the fix (RobR 93pt)It seems as the jolt was enough to
knock a poor ground wire loose on the jack. I reached ontop of the
jack and fiddled with the 3 wires and the jack extended with the
next attempt.
As per Gardners post I set the tires down with a ton or two to keep
it from rolling. my bus is in gravel so I can steam the engine while
the radiator is out and I fear a chock will just skid. On the PT
the tag has no park brakes. when you think about it if the drive
axle bags bleed out, the bus would take off rolling on the steer and
tag!!!!!!!
Steve is that brake switch in the the generator radiator Bay?
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, Stephen Quandt
> Greg
yr old memory).
> Steve Quandt
> Iron Mountain, MI
> 1993 PT-40
> From: Gregory OConnor
compressor
rolled
blocks
luck.
hwh
> computer?
> GregoryO'Connor
> 94ptRomolandCa
08-05-2008, 22:41
Greg
Yes the switch is in the generator bay.
Steve
Quandt
Iron Mountain, MI
1993 PT-40
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gregory OConnor
Sent: Tuesday, August 05, 2008
10:55 PM
Subject: [WanderlodgeForum] Re:
a call from
Canada
next attempt.
As per Gardners
tag!!!!!!!
GregoryO'Connor
94ptRomolandCa
--- In "WanderlodgeForum%40yahoogroups.com",
Stephen Quandt
.> wrote:
> Greg
yr old memory).
> Steve Quandt
> Iron Mountain, MI
> 1993 PT-40
> From: Gregory OConnor ..>
compressor
rolled
blocks
luck.
hwh
> computer?
> GregoryO'Connor
> 94ptRomolandCa
08-06-2008, 16:37
Greg,
I 've always wondered how these radiators come out. Do they slide out from the rear? How much of the body work needs to be removed? What do you think that beast weighs?
David Brady
'02 LXi, Ca
-----Original Message-----
Sent: Aug 5, 2008 9:06 PM
computer?
GregoryO'Connor
94ptRomolandCa
08-07-2008, 00:10
Greg
You may to try turning your ignition switch off then on. Your system must have excessive slope that shows on you control panel. I had the same problem at Oshkosh last week, I called HWH and was told to do that, it worked.
Hisham
--- On Thu, 8/7/08, David Brady wrote:
Subject: Re: [WanderlodgeForum] HWH jack wont extend, 94pt
Date: Thursday, August 7, 2008, 12:37 AM
Greg,
David Brady
'02 LXi, Ca
computer?
GregoryO'Connor
94ptRomolandCa
