Black Valves
08-20-2008, 15:33
Black Valves
Hi there
Still going thru shakedown of new unit and tried to open gray and black
tanks valves.
I was able to twist gray water handle and with some force able to open
it, but on the black, i was only able to twist about 90 degrees and it
would go no further. Does this mean i am done and need to replace, or
is there some way to lubricate or service to try and bring back to life.
If i am don, do i replace with another Dupree Products valve, or go to
camping world and buy a regular knife type valve and adapt it.
Also another newbee question, where is the hot water heater located? I
glanced over some post earlier but was not paying attention about water
heater stuff so i apoligize about that, but i have opened every door
and have not found it yet.
Thanks again
Paul & Deborah Potter
1987 PT38
Hesperia CA
08-20-2008, 15:50
Black Valves
Hi Paul,
Not sure about the degree twist on the manual valves. Our coach has the air actuated dump valves.
Hot Water Heater...is located far drivers side, under the rear cabinets.
I'll be heading your way Friday early am. Let me know if you would like
me to stop and assist best I can. I'm heading over to our AZ property then, and I don't have a need to be there at any specific time. Email me at "curtsprenger@gmail.com" or call me at 714 269-6187. I'll need an address to look up on Mapquest.
On Wed, Aug 20, 2008 at 8:33 PM, ppotter14950 <"audvid1@gte.net"> wrote:
Hi there
tanks valves.
Thanks again
1987 PT38
Hesperia CA
Curt Sprenger
Anaheim Hills, CA
08-20-2008, 16:42
Black Valves
maybe Paul has air dump valves?? Curt is the air dump switch close
to the valve on the 87pt? and Paul if they are dupree I think they
are air operated and you need to build up air in the tank first to
use the air valve.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Hi Paul,
has the air
cabinets.
like me
then, and
> curtsprenger@... or call me at 714 269-6187. I'll need an address
to
> On Wed, Aug 20, 2008 at 8:33 PM, ppotter14950 wrote:
> > Hi there
and black
> > tanks valves.
to open
and it
replace, or
to life.
go to
located? I
about water
door
> > Thanks again
> > 1987 PT38
> > Hesperia CA
> Curt Sprenger
> Anaheim Hills, CA
08-20-2008, 17:41
Black Valves
Sounds like the manual dump valves. Twist 90 and pull outward on the
handle to open them. Reverse when done.
Water heater is hidden away under the far rear corner driver's side
of the closet where Curt indicated.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "ppotter14950"
> Hi there
black
> tanks valves.
open
it
or
life.
to
located? I
water
door
> Thanks again
> 1987 PT38
> Hesperia CA
08-20-2008, 17:43
Black Valves
Greg,
Good point, Paul's dump valves just might be air dump valves. I'll know more after observing on Friday. On our coach, the air valve controls are just above the dump pipe hose connection. If you are not too busy, can you meet at Paul's in the early am Friday? I'll buy breakfast!
On Wed, Aug 20, 2008 at 9:42 PM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
use the air valve.
GregoryO'Connor
94ptRomolandCa
--- In "WanderlodgeForum%40yahoogroups.com", "Curt Sprenger"
> Hi Paul,
has the air
cabinets.
like me
then, and
to
> > Hi there
and black
> > tanks valves.
to open
and it
replace, or
to life.
go to
located? I
about water
door
> > Thanks again
> > 1987 PT38
> > Hesperia CA
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
08-20-2008, 23:14
Black Valves
You can New Inserts or guts for the valves
it is a five minute job to replace them
all you need is a screwdriver
undo 2 screws pullout the valve push in the new one and replace the
screws and you are finished
order online at http://www.dupreeproducts.com
Stephen 77fc35 owner of dupree products
> Hi there
> tanks valves.
> Thanks again
> 1987 PT38
> Hesperia CA
08-21-2008, 05:10
Black Valves
Paul:
Recommend ELECTRIC VALVES.....DRAINMASTER.COM out of Hollister
California......call the factory direct IF u want to save
money....they will even put the attachements on the drainmasters
before they ship them....I put Drainmasters on my 90SP and am very
happy!!! push a button and "BAM" the "stuff" flows.....
make sure you get the "good" switches also.....
u can email me privately IF u have any questions...Also the 2008
bluebird is using electric dump valves for your information...
Regards,
Hank
90SP36
> Hi there
black
> tanks valves.
open
it
or
life.
to
located? I
water
door
> Thanks again
> 1987 PT38
> Hesperia CA
08-21-2008, 06:51
Black Valves
Hi Paul: Give Stephen Birtles a Call...You can replace those Dupree
paddles on the valves for < $20 each. This is a no brainer; the
paddles have probably swelled and become hardened because of age and
the harsh effect of the operating environment. Lubricate the new
paddles with teflon grease and clean the paddle seating surface
during reassembly. The two phillips head screws can be removed with
a long phillips head screwdriver or try a phillips head bit on a 1/4"
drive extension and 1/4" ratchet.
If you plan on going to Maxton this fall, I'll help you do this
project...Stephen B sold me two paddles recently and my valves now
operate smoothly (with air or manually) and more importantly, no more
leaks.
Dick Gideon
1989 35 FC
Rolla, MO
> Hi there
black
> tanks valves.
open
it
or
life.
to
located? I
water
door
> Thanks again
> 1987 PT38
> Hesperia CA
08-21-2008, 12:51
Black Valves
Hank I think electric valves are the ticket because most times when
I dump I have no air to open or close the valve so I do it manualy
or have to plan dumping. I just wonder what would happen to the
electric motors if the valve's gate encounters an obstacle of a high
fiber nature? would the motor stop or continue and damage the gate/
seal and motor?? and the other question is if the electric motor
fails can you manualy dump?
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> Paul:
> Regards,
> Hank
> 90SP36
> > Hi there
> black
> > tanks valves.
to
> open
> it
replace,
> or
to
> life.
go
> to
> located? I
about
> water
> door
> > Thanks again
> > 1987 PT38
> > Hesperia CA
08-21-2008, 12:59
Black Valves
it strips the small nylon gears
yes you can manually dump be prepared to spen 5 or 6 minute winding
open the valves
Stephen 77fc35
> GregoryO'Connor
> 94ptRomolandCa
> > Paul:
> > Regards,
> > Hank
> > 90SP36
> > wrote:
> > > Hi there
> and
> > black
> > > tanks valves.
> to
> > open
> and
> > it
> replace,
> > or
> to
> > life.
> go
> > to
> > located? I
> about
> > water
> > door
> > > Thanks again
> > > 1987 PT38
> > > Hesperia CA
