Coolant Filters
08-27-2008, 00:50
Coolant Filters
One mod I would like to add is a filter system for the coolant on my
bus. CurtS brought this up one time but now that I have a grand invested in cleaning out my rad, I have interest (I wasn't political untill I paid taxes either). I am kinda surprised that there is not a OEM filter in the design some place. At the same time my Primus gone Wabasto need a filter system also. A recent flush of that independent system , register by register proved much crap inbeded in the path. I like the idea of running my bus as hot as the engineeres designed 185 to 195 to get all the hp and fluids working but the 10 degree margine prior to costly damage keeps me concerned. I proved that the rad will cool things off even compramised 90%(subjective calc by the shop that did the rodding) so the cooling system optimization is where I would like to relieve that concern. Has anyone added a coolant filter mod? I found this kit but would like a larger inlet outlet to mount it on the cockpit heater defroster loop. https://www.dieselsite.com/index.asp? PageAction=VIEWPROD&ProdID=796&HS=1 GregoryO'Connor 94ptRomolandCa |
08-27-2008, 01:25
Coolant Filters
Greg,
I did install a coolant filter. Easy install. Stop by and take a look. On Wed, Aug 27, 2008 at 5:50 AM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
08-27-2008, 05:50
Coolant Filters
Curt,
You obviously have too much time on your hands!! ;^) (I'm envious) Want to share part numbers, installation pointers, cost, pictures, etc. on that coolant filter? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Greg, > > I did install a coolant filter. Easy install. Stop by and take a look. > > On Wed, Aug 27, 2008 at 5:50 AM, Gregory OConnor wrote: > > > One mod I would like to add is a filter system for the coolant on my > > bus. CurtS brought this up one time but now that I have a grand > > invested in cleaning out my rad, I have interest (I wasn't political > > untill I paid taxes either). I am kinda surprised that there is not > > a OEM filter in the design some place. At the same time my Primus > > gone Wabasto need a filter system also. A recent flush of that > > independent system , register by register proved much crap inbeded > > in the path. > > > > I like the idea of running my bus as hot as the engineeres designed > > 185 to 195 to get all the hp and fluids working but the 10 degree > > margine prior to costly damage keeps me concerned. I proved that the > > rad will cool things off even compramised 90%(subjective calc by the > > shop that did the rodding) so the cooling system optimization is > > where I would like to relieve that concern. > > > > Has anyone added a coolant filter mod? > > I found this kit but would like a larger inlet outlet to mount it on > > the cockpit heater defroster loop. > > > > https://www.dieselsite.com/index.asp? > > PageAction=VIEWPROD&ProdID=796&HS=1 > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
08-27-2008, 06:51
Coolant Filters
Mike,
I'll getall the information together and publish it.
Curt
08-27-2008, 09:20
Coolant Filters
Greg,
Here's one with 3/8 NPT inlet/outlet sizes. You should be able to find it locally. It's what's used in the heavy truck side of things. Takes standard filters. https://dynamic.donaldson.com/webc/WebSt...tail.html? section=10324&item=1857 Hope this helps. I don't believe there is one designed for full flow coolant, only partial flow. Prevents filter blockage from interupting engine cooling. John --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > One mod I would like to add is a filter system for the coolant on my > bus. CurtS brought this up one time but now that I have a grand > invested in cleaning out my rad, I have interest (I wasn't political > untill I paid taxes either). I am kinda surprised that there is not > a OEM filter in the design some place. At the same time my Primus > gone Wabasto need a filter system also. A recent flush of that > independent system , register by register proved much crap inbeded > in the path. > > I like the idea of running my bus as hot as the engineeres designed > 185 to 195 to get all the hp and fluids working but the 10 degree > margine prior to costly damage keeps me concerned. I proved that the > rad will cool things off even compramised 90%(subjective calc by the > shop that did the rodding) so the cooling system optimization is > where I would like to relieve that concern. > > Has anyone added a coolant filter mod? > I found this kit but would like a larger inlet outlet to mount it on > the cockpit heater defroster loop. > > https://www.dieselsite.com/index.asp? > PageAction=VIEWPROD&ProdID=796&HS=1 > > > > GregoryO'Connor > 94ptRomolandCa > |
08-27-2008, 11:32
Coolant Filters
I took pictures of my coolant filter installation and wrote up a document. I just sent that off to Mike and John for Wanderlodge sites publication.
08-27-2008, 12:22
Coolant Filters
Thanks Curt. I'm interested in that mod myself.
2008/8/27 Curt Sprenger <"curtsprenger@gmail.com">
-- Rob, Sue & Merlin Robinson 94 WLWB |
08-27-2008, 12:41
Coolant Filters
DITO!
Thanks Curt. Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Thanks Curt. I'm interested in that mod myself. > > 2008/8/27 Curt Sprenger > > > I took pictures of my coolant filter installation and wrote up a > > document. I just sent that off to Mike and John for Wanderlodge sites > > publication. > > > > On Wed, Aug 27, 2008 at 2:20 PM, jcmace59 > > > >> Greg, > >> Here's one with 3/8 NPT inlet/outlet sizes. You should be able to > >> find it locally. It's what's used in the heavy truck side of > >> things. Takes standard filters. > >> > >> https://dynamic.donaldson.com/webc/WebSt...tail.html? > >> section=10324&item=1857 > >> > >> Hope this helps. I don't believe there is one designed for full flow > >> coolant, only partial flow. Prevents filter blockage from > >> interupting engine cooling. > >> > >> John > >> > >> --- In WanderlodgeForum@yahoogroups.com > >> "Gregory OConnor" > >> > >> > > >> > One mod I would like to add is a filter system for the coolant on > >> my > >> > bus. CurtS brought this up one time but now that I have a grand > >> > invested in cleaning out my rad, I have interest (I wasn't > >> political > >> > untill I paid taxes either). I am kinda surprised that there is not > >> > a OEM filter in the design some place. At the same time my Primus > >> > gone Wabasto need a filter system also. A recent flush of that > >> > independent system , register by register proved much crap inbeded > >> > in the path. > >> > > >> > I like the idea of running my bus as hot as the engineeres designed > >> > 185 to 195 to get all the hp and fluids working but the 10 degree > >> > margine prior to costly damage keeps me concerned. I proved that > >> the > >> > rad will cool things off even compramised 90%(subjective calc by > >> the > >> > shop that did the rodding) so the cooling system optimization is > >> > where I would like to relieve that concern. > >> > > >> > Has anyone added a coolant filter mod? > >> > I found this kit but would like a larger inlet outlet to mount it > >> on > >> > the cockpit heater defroster loop. > >> > > >> > https://www.dieselsite.com/index.asp? > >> > PageAction=VIEWPROD&ProdID=796&HS=1 > >> > > >> > > >> > > >> > GregoryO'Connor > >> > 94ptRomolandCa > >> > > >> > >> > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > |
08-27-2008, 13:04
Coolant Filters
I added the pictures in the Photos section in an albumn
named "Coolant Filter Modifcation". The pics are fairly self explanatory by themselves. The write up is in the Files under Engine Coolant Filter Installation with a link directly to the pictures or follow this link to the pics: http://autos.ph.groups.yahoo.com/group/W...os/browse/ d530?c= My pdf maker is not working this evening. When I repair it, I will add the pics to the write up and make a pdf out of it that is small enough to load as a single complete document. In the meantime, I wanted to get the info that Curt was so good to submit posted for folks to see. Thanks very much to Curt for this information!! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > I took pictures of my coolant filter installation and wrote up a document. I > just sent that off to Mike and John for Wanderlodge sites publication. > > On Wed, Aug 27, 2008 at 2:20 PM, jcmace59 > > > Greg, > > Here's one with 3/8 NPT inlet/outlet sizes. You should be able to > > find it locally. It's what's used in the heavy truck side of > > things. Takes standard filters. > > > > https://dynamic.donaldson.com/webc/WebSt...tail.html? > > section=10324&item=1857 > > > > Hope this helps. I don't believe there is one designed for full flow > > coolant, only partial flow. Prevents filter blockage from > > interupting engine cooling. > > > > John > > > > --- In WanderlodgeForum@yahoogroups.com > > "Gregory OConnor" > > > > > > > > One mod I would like to add is a filter system for the coolant on > > my > > > bus. CurtS brought this up one time but now that I have a grand > > > invested in cleaning out my rad, I have interest (I wasn't > > political > > > untill I paid taxes either). I am kinda surprised that there is not > > > a OEM filter in the design some place. At the same time my Primus > > > gone Wabasto need a filter system also. A recent flush of that > > > independent system , register by register proved much crap inbeded > > > in the path. > > > > > > I like the idea of running my bus as hot as the engineeres designed > > > 185 to 195 to get all the hp and fluids working but the 10 degree > > > margine prior to costly damage keeps me concerned. I proved that > > the > > > rad will cool things off even compramised 90%(subjective calc by > > the > > > shop that did the rodding) so the cooling system optimization is > > > where I would like to relieve that concern. > > > > > > Has anyone added a coolant filter mod? > > > I found this kit but would like a larger inlet outlet to mount it > > on > > > the cockpit heater defroster loop. > > > > > > https://www.dieselsite.com/index.asp? > > > PageAction=VIEWPROD&ProdID=796&HS=1 > > > > > > > > > > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
08-27-2008, 13:20
Coolant Filters
Prob with the files and pic section is they are not searchable. Is it ok to add the stuff like this: ?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Coolant Filter Installation -1987 PT38 â 8V92 Contributed by Curt Sprenger August 27.2008 Coolant Filter Base â Filters â 1st filter Parts â All Brass, all 3/8" - 4 street elbows, 1 close nipple, 1 1-1/2" nipple, 2 NIBCO T585 ball valves. Cost $68.79. You might find the part for less. I shop at a plumbing store that carries more parts than anyone in our area. They are not the least expensive but time is worth something. Hose â measure generously â I used just under 6' - get good ½" push-on or equivalent. Cost $10.00. Hose Clamps â 4 each. Bolts/Nuts â to mount the filter base.
Instructions - 1 I removed the Ether Injector system and installed the coolant filter base in the same location. Or pick a different location. 2 Loosely attach all the plumbing to the filter base, see picture, and the spin on the filter (not tight), to get an accurate mounting position that works. Keep the coolant hose clearance/routing in mind. 3 Drill new mounting holes if needed. 4 Install filter base. 5 Install the brass parts. See photos. Shorten the ball valve handles as needed. Use thread sealant. 6 Tighten the filter. 7 Remove the old hose at the Expansion Tank, save the coolant. Plug the hose for now. 8 Connect new hose from the expansion tank to the filter base center. 9 Connect new hose to the filter base outer connection. Run the hose to the thermostat housing street elbow to get the length of hose needed, and cut to length. 10 With a knife, slit the old hose at the street elbow on top of the thermostat housing. Quickly remove that hose and slid on the new hose. A terry towel on top of the thermostat housing will catch the small amount of coolant loss. |
