steering box
08-28-2008, 03:16
Post: #21
steering box
Got me Ole Girl back on the road again: Basically they replaced the
TieRod Ends and did alignment and adjusted what could be adjusted, lubrication and inspection. The handling is significantly improved. Much of the free travel has been eliminated. The result is less wander in the wonderlodge. The fellows appreciated the input from the forum and especially Chuck Wheelers comments. I feel like the shop did an excellent job for me and with the help from my fellow Bluebirders I made a pretty significant step in the right direction. There still remains the issue of the springs,shackles and shocks with respect to ride quality. To replace all of that stuff will set me back pretty big bucks. Likely about $3500. Now the question is how much improvement, or how much bang for my buck will I get. At this point I am going to hold tight until I get to a rally so that some of you other fellows can drive my bus and see how it compares to others. I would not mind spending the money if I was going to get real value. I have nothing to compare to. So plan to head to Hershey in Oct lets see if some of you guys can take'r out for a spin to see where I am at and where I should be going. John Heckman central Pa 1973 FC > > When I had my steering box rebuilt I discovered that there were two > different boxes used in the FC. The older one has much more "free play" > than the newer design. The difference is in the spool valve design. If the > steering wheel input shaft moves up and down when you move the wheel with > the engine off you have the older design. It's not really mechanical free > play but the amount of movement requires for the hydraulic system to react. > At the time we had ours rebuilt there were none of the newer design > available to see if they were interchangeable. With the rebuilt steering > box, new tie rod ends, and bushings in the front end suspension (totally > gone) our FC handles very well now. There is still the free play, but not > slack, in the steering system. Now on a straight road there is very little > correction required. You want to be careful adjusting the sector shaft > preload, it is done with the box unloaded using a torque wrench on the input > shaft. Many people mistake eliminating free play with putting the steering > box in a bind which increases wear. The seals were worn out in our steering > box, but all other parts were in good condition. We are all used to rack > and pinion steering in our cars. Drive a 50s or early 60s vehicle that have > steering boxes and they have much the same feeling as our FCs. > > - Chuck Wheeler- > FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 > Sent: Sunday, August 24, 2008 3:11 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Steering box > > > > My bus is in the shop as we speak sorting our suspension and handling > issues. The fellows have told me that they have things in pretty > good order but are concerned about some "free travel" which they have > traced to the steering box. Now here is the issue. This steering box > was a rebuilt box which the previous owner replaced about 20K miles > ago. (The previous owner said this greatly improved the handling.) > The guys are telling me that my options are to live with this free > travel or get another remanufactured steering box. My concern is > that I might get another only to find its no better then the one I > have now. My fellows are also not really familiar with BB's and I > wonder if they are expection the impossible with this old FC? Any > suggestions or tricks which I might pass on to the shop. They did > say there was some type of adjustment that they were going to try to > make but it was "tricky" if they went just a little too far then the > steering would potentially have a tight spot or a hitch in it.( I may > not have that exactly right as to their discription but you likely > get the point. They said what they were going to adjust but that > didn't stick in the ole knoggin) The shop works on RV's and heavy > equipment and is very well respected. They don't see a lot of BB'ds > so if there is any thing I can pass along they are more then willing > for my information. > > John Heckman > central Pa > 1973 FC > |
08-28-2008, 04:09
Post: #22
steering box
Shocks can make a big improvement if the existing ones are weak. If the shopcould align the front end and there were no obvious problems I would not spend the money on springs etc.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 Sent: Thursday, August 28, 2008 10:17 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Steering box Got me Ole Girl back on the road again: Basically they replaced the TieRod Ends and did alignment and adjusted what could be adjusted, lubrication and inspection. The handling is significantly improved. Much of the free travel has been eliminated. The result is less wander in the wonderlodge. The fellows appreciated the input from the forum and especially Chuck Wheelers comments. I feel like the shop did an excellent job for me and with the help from my fellow Bluebirders I made a pretty significant step in the right direction. There still remains the issue of the springs,shackles and shocks with respect to ride quality. To replace all of that stuff will set me back pretty big bucks. Likely about $3500. Now the question is how much improvement, or how much bang for my buck will I get. At this point I am going to hold tight until I get to a rally so that some of you other fellows can drive my bus and see how it compares to others. I would not mind spending the money if I was going to get real value. I have nothing to compare to. So plan to head to Hershey in Oct lets see if some of you guys can take'r out for a spin to see where I am at and where I should be going. John Heckman central Pa 1973 FC > > When I had my steering box rebuilt I discovered that there were two > different boxes used in the FC. The older one has much more "free play" > than the newer design. The difference is in the spool valve design. If the > steering wheel input shaft moves up and down when you move the wheel with > the engine off you have the older design. It's not really mechanical free > play but the amount of movement requires for the hydraulic system to react. > At the time we had ours rebuilt there were none of the newer design > available to see if they were interchangeable. With the rebuilt steering > box, new tie rod ends, and bushings in the front end suspension (totally > gone) our FC handles very well now. There is still the free play, but not > slack, in the steering system. Now on a straight road there is very little > correction required. You want to be careful adjusting the sector shaft > preload, it is done with the box unloaded using a torque wrench on the input > shaft. Many people mistake eliminating free play with putting the steering > box in a bind which increases wear. The seals were worn out in our steering > box, but all other parts were in good condition. We are all used to rack > and pinion steering in our cars. Drive a 50s or early 60s vehicle that have > steering boxes and they have much the same feeling as our FCs. > > - Chuck Wheeler- > FC 31SB Fort Worth TX > > > _____ > > From: "WanderlodgeForum%40yahoogroups.com" > [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of bubblerboy64 > Sent: Sunday, August 24, 2008 3:11 AM > To: "WanderlodgeForum%40yahoogroups.com" > Subject: [WanderlodgeForum] Steering box > > > > My bus is in the shop as we speak sorting our suspension and handling > issues. The fellows have told me that they have things in pretty > good order but are concerned about some "free travel" which they have > traced to the steering box. Now here is the issue. This steering box > was a rebuilt box which the previous owner replaced about 20K miles > ago. (The previous owner said this greatly improved the handling.) > The guys are telling me that my options are to live with this free > travel or get another remanufactured steering box. My concern is > that I might get another only to find its no better then the one I > have now. My fellows are also not really familiar with BB's and I > wonder if they are expection the impossible with this old FC? Any > suggestions or tricks which I might pass on to the shop. They did > say there was some type of adjustment that they were going to try to > make but it was "tricky" if they went just a little too far then the > steering would potentially have a tight spot or a hitch in it.( I may > not have that exactly right as to their discription but you likely > get the point. They said what they were going to adjust but that > didn't stick in the ole knoggin) The shop works on RV's and heavy > equipment and is very well respected. They don't see a lot of BB'ds > so if there is any thing I can pass along they are more then willing > for my information. > > John Heckman > central Pa > 1973 FC > |
08-28-2008, 04:33
Post: #23
steering box
Thanks Chuck, I am certainly not going to jump to replacing the
springs until I have some further input from people more informed then I at this point. Shocks?? They intended to replace them but were sent the wrong ones (Monroe's)They cross referenced off what is on the bus now Delco) I know Koni shocks are the preference. The shocks which are on my bus are Delco 3187991 both front and back. Can you tell me what numbers I need for my application. Consider that this bus has been modified and specifically the switch from the gas engine to the 3208 NA. Don't know if that makes a difference or not. John Heckman central Pa 1973 FC > > Shocks can make a big improvement if the existing ones are weak. If the > shop could align the front end and there were no obvious problems I would > not spend the money on springs etc. > > - Chuck Wheeler- > FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 > Sent: Thursday, August 28, 2008 10:17 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Steering box > > > > Got me Ole Girl back on the road again: Basically they replaced the > TieRod Ends and did alignment and adjusted what could be adjusted, > lubrication and inspection. The handling is significantly improved. > Much of the free travel has been eliminated. The result is less > wander in the wonderlodge. The fellows appreciated the input from > the forum and especially Chuck Wheelers comments. I feel like the > shop did an excellent job for me and with the help from my fellow > Bluebirders I made a pretty significant step in the right direction. > > There still remains the issue of the springs,shackles and shocks with > respect to ride quality. To replace all of that stuff will set me > back pretty big bucks. Likely about $3500. Now the question is how > much improvement, or how much bang for my buck will I get. At this > point I am going to hold tight until I get to a rally so that some of > you other fellows can drive my bus and see how it compares to > others. I would not mind spending the money if I was going to get > real value. I have nothing to compare to. So plan to head to > Hershey in Oct lets see if some of you guys can take'r out for a spin > to see where I am at and where I should be going. > John Heckman > central Pa > 1973 FC > > > > > When I had my steering box rebuilt I discovered that there were two > > different boxes used in the FC. The older one has much more "free > play" > > than the newer design. The difference is in the spool valve > design. If the > > steering wheel input shaft moves up and down when you move the > wheel with > > the engine off you have the older design. It's not really > mechanical free > > play but the amount of movement requires for the hydraulic system > to react. > > At the time we had ours rebuilt there were none of the newer design > > available to see if they were interchangeable. With the rebuilt > steering > > box, new tie rod ends, and bushings in the front end suspension > (totally > > gone) our FC handles very well now. There is still the free play, > but not > > slack, in the steering system. Now on a straight road there is > very little > > correction required. You want to be careful adjusting the sector > shaft > > preload, it is done with the box unloaded using a torque wrench on > the input > > shaft. Many people mistake eliminating free play with putting the > steering > > box in a bind which increases wear. The seals were worn out in our > steering > > box, but all other parts were in good condition. We are all used > to rack > > and pinion steering in our cars. Drive a 50s or early 60s vehicle > that have > > steering boxes and they have much the same feeling as our FCs. > > > > - Chuck Wheeler- > > FC 31SB Fort Worth TX > > > > > > _____ > > > > From: WanderlodgeForum@ > yahoogroups.com > > [mailto:WanderlodgeForum@ > yahoogroups.com] On Behalf Of bubblerboy64 > > Sent: Sunday, August 24, 2008 3:11 AM > > To: WanderlodgeForum@ > yahoogroups.com > > Subject: [WanderlodgeForum] Steering box > > > > > > > > My bus is in the shop as we speak sorting our suspension and > handling > > issues. The fellows have told me that they have things in pretty > > good order but are concerned about some "free travel" which they > have > > traced to the steering box. Now here is the issue. This steering > box > > was a rebuilt box which the previous owner replaced about 20K miles > > ago. (The previous owner said this greatly improved the handling.) > > The guys are telling me that my options are to live with this free > > travel or get another remanufactured steering box. My concern is > > that I might get another only to find its no better then the one I > > have now. My fellows are also not really familiar with BB's and I > > wonder if they are expection the impossible with this old FC? Any > > suggestions or tricks which I might pass on to the shop. They did > > say there was some type of adjustment that they were going to try > to > > make but it was "tricky" if they went just a little too far then > the > > steering would potentially have a tight spot or a hitch in it.( I > may > > not have that exactly right as to their discription but you likely > > get the point. They said what they were going to adjust but that > > didn't stick in the ole knoggin) The shop works on RV's and heavy > > equipment and is very well respected. They don't see a lot of BB'ds > > so if there is any thing I can pass along they are more then > willing > > for my information. > > > > John Heckman > > central Pa > > 1973 FC > > > |
08-28-2008, 05:36
Post: #24
steering box
I would suspect that the shocks, if they show signs of being, worn
might offer a modest but cost-effective improvement in handling. (Does the coach bounce excessively or porpoise?) Unless the springs and shackles, etc. are clearly displaying out-of-spec sag or other bent components, that you'll get much less benefit from making any changes to them. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Aug 28, 2008, at 9:16 AM, bubblerboy64 wrote: > <snip> > There still remains the issue of the springs,shackles and shocks with > respect to ride quality. To replace all of that stuff will set me > back pretty big bucks. Likely about $3500. Now the question is how > much improvement, or how much bang for my buck will I get. At this > point I am going to hold tight until I get to a rally so that some of > you other fellows can drive my bus and see how it compares to > others. I would not mind spending the money if I was going to get > real value. I have nothing to compare to. So plan to head to > Hershey in Oct lets see if some of you guys can take'r out for a spin > to see where I am at and where I should be going. > John Heckman > central Pa > 1973 FC > <snip> |
08-28-2008, 06:16
Post: #25
steering box
Our 82 has air suspension so the application might not be the same for the shocks. Koni has a application guide online although I purchased mine form BB.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 Sent: Thursday, August 28, 2008 11:33 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Steering box Thanks Chuck, I am certainly not going to jump to replacing the springs until I have some further input from people more informed then I at this point. Shocks?? They intended to replace them but were sent the wrong ones (Monroe's)They cross referenced off what is on the bus now Delco) I know Koni shocks are the preference. The shocks which are on my bus are Delco 3187991 both front and back. Can you tell me what numbers I need for my application. Consider that this bus has been modified and specifically the switch from the gas engine to the 3208 NA. Don't know if that makes a difference or not. John Heckman central Pa 1973 FC > > Shocks can make a big improvement if the existing ones are weak. If the > shop could align the front end and there were no obvious problems I would > not spend the money on springs etc. > > - Chuck Wheeler- > FC 31SB Fort Worth TX > > > _____ > > From: "WanderlodgeForum%40yahoogroups.com" > [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of bubblerboy64 > Sent: Thursday, August 28, 2008 10:17 AM > To: "WanderlodgeForum%40yahoogroups.com" > Subject: [WanderlodgeForum] Re: Steering box > > > > Got me Ole Girl back on the road again: Basically they replaced the > TieRod Ends and did alignment and adjusted what could be adjusted, > lubrication and inspection. The handling is significantly improved. > Much of the free travel has been eliminated. The result is less > wander in the wonderlodge. The fellows appreciated the input from > the forum and especially Chuck Wheelers comments. I feel like the > shop did an excellent job for me and with the help from my fellow > Bluebirders I made a pretty significant step in the right direction. > > There still remains the issue of the springs,shackles and shocks with > respect to ride quality. To replace all of that stuff will set me > back pretty big bucks. Likely about $3500. Now the question is how > much improvement, or how much bang for my buck will I get. At this > point I am going to hold tight until I get to a rally so that some of > you other fellows can drive my bus and see how it compares to > others. I would not mind spending the money if I was going to get > real value. I have nothing to compare to. So plan to head to > Hershey in Oct lets see if some of you guys can take'r out for a spin > to see where I am at and where I should be going. > John Heckman > central Pa > 1973 FC > > > > > When I had my steering box rebuilt I discovered that there were two > > different boxes used in the FC. The older one has much more "free > play" > > than the newer design. The difference is in the spool valve > design. If the > > steering wheel input shaft moves up and down when you move the > wheel with > > the engine off you have the older design. It's not really > mechanical free > > play but the amount of movement requires for the hydraulic system > to react. > > At the time we had ours rebuilt there were none of the newer design > > available to see if they were interchangeable. With the rebuilt > steering > > box, new tie rod ends, and bushings in the front end suspension > (totally > > gone) our FC handles very well now. There is still the free play, > but not > > slack, in the steering system. Now on a straight road there is > very little > > correction required. You want to be careful adjusting the sector > shaft > > preload, it is done with the box unloaded using a torque wrench on > the input > > shaft. Many people mistake eliminating free play with putting the > steering > > box in a bind which increases wear. The seals were worn out in our > steering > > box, but all other parts were in good condition. We are all used > to rack > > and pinion steering in our cars. Drive a 50s or early 60s vehicle > that have > > steering boxes and they have much the same feeling as our FCs. > > > > - Chuck Wheeler- > > FC 31SB Fort Worth TX > > > > > > _____ > > > > From: WanderlodgeForum@ 40yahoogroups. > yahoogroups. > > [mailto:Wanderlodge 40yahoogroups. > yahoogroups. > > Sent: Sunday, August 24, 2008 3:11 AM > > To: WanderlodgeForum@ > yahoogroups. > > Subject: [WanderlodgeForum] Steering box > > > > > > > > My bus is in the shop as we speak sorting our suspension and > handling > > issues. The fellows have told me that they have things in pretty > > good order but are concerned about some "free travel" which they > have > > traced to the steering box. Now here is the issue. This steering > box > > was a rebuilt box which the previous owner replaced about 20K miles > > ago. (The previous owner said this greatly improved the handling.) > > The guys are telling me that my options are to live with this free > > travel or get another remanufactured steering box. My concern is > > that I might get another only to find its no better then the one I > > have now. My fellows are also not really familiar with BB's and I > > wonder if they are expection the impossible with this old FC? Any > > suggestions or tricks which I might pass on to the shop. They did > > say there was some type of adjustment that they were going to try > to > > make but it was "tricky" if they went just a little too far then > the > > steering would potentially have a tight spot or a hitch in it.( I > may > > not have that exactly right as to their discription but you likely > > get the point. They said what they were going to adjust but that > > didn't stick in the ole knoggin) The shop works on RV's and heavy > > equipment and is very well respected. They don't see a lot of BB'ds > > so if there is any thing I can pass along they are more then > willing > > for my information. > > > > John Heckman > > central Pa > > 1973 FC > > > |
08-28-2008, 06:44
Post: #26
steering box
Hi Pete, The springs are pretty flat especially the back ones. One
poster commented about wheel clearance. I have plenty of that. The shop thinks that when the engine was switched over to the 3208 the springs were modified by adding additional springs leaves which would make sense. The bus doesn't porpoise at all, the opposite it bangs pretty hard over bumps. The shop feels that the springs would function better if they were graduated from top to bottom and matched to the weight that the bus is being ask to carry now. So there is some reason to speculate that the bus would ride better with new springs under it. The question remains HOW MUCH. I can spend the money to find out. I might gain a lot I might gain just a little. The fellows at the shop didn't think the bus rode too badly. They objected to the loose steering more then the ride. I of course became some what used to the steering. But it is much better now I will grant you that. The shop obviously knews their stuff. There are other issues as well. Currently the they can buy the springs off the shelf. If they become unavailable then they are have to be custom made at about twice the cost. I have to factor all that in with considerations as to how long I will keep the coach. I think I will let a couple of the fellows drive the bus when we get together at Hershey and see if there is a consensus of opinion. John Heckman central Pa 1973 FC > > I would suspect that the shocks, if they show signs of being, worn > might offer a modest but cost-effective improvement in handling. > (Does the coach bounce excessively or porpoise?) Unless the springs > and shackles, etc. are clearly displaying out-of-spec sag or other > bent components, that you'll get much less benefit from making any > changes to them. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Idaho Springs, CO > > > > On Aug 28, 2008, at 9:16 AM, bubblerboy64 wrote: > > > <snip> > > There still remains the issue of the springs,shackles and shocks with > > respect to ride quality. To replace all of that stuff will set me > > back pretty big bucks. Likely about $3500. Now the question is how > > much improvement, or how much bang for my buck will I get. At this > > point I am going to hold tight until I get to a rally so that some of > > you other fellows can drive my bus and see how it compares to > > others. I would not mind spending the money if I was going to get > > real value. I have nothing to compare to. So plan to head to > > Hershey in Oct lets see if some of you guys can take'r out for a spin > > to see where I am at and where I should be going. > > John Heckman > > central Pa > > 1973 FC > > <snip> > |
08-28-2008, 08:47
Post: #27
steering box
Your idea of having others, with similar old coaches, give it a drive
and give you an opinion is probably a good one. When I was first considering a coach, I was looking at bus conversions (not just BBs) and I recall reading a web site that suggested that the Blue Birds with air suspension were "much preferred" over the metal spring suspension coaches -- so I'd expect that a somewhat hard ride might be normal. (Years ago, I drove a few heavy trucks with spring suspension in the Army -- they rode hard, but we didn't go very fast, either.) I think one member got an "air ride seat" in his bird... it might be a more cost effective choice to improve ride comfort. About all I can say about my coach is that "it rides like a bus...." You might call the factory and see if you can get some opinions there... if there's anyone around who remembers the spring-suspension models. (I suppose that the school busses have the air suspension these days, so knowledge about spring suspension may be lost by now...) Over $3000 is quite a price to pay for potentially only a small incremental improvement.... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Aug 28, 2008, at 12:44 PM, bubblerboy64 wrote: > Hi Pete, The springs are pretty flat especially the back ones. One > poster commented about wheel clearance. I have plenty of that. The > shop thinks that when the engine was switched over to the 3208 the > springs were modified by adding additional springs leaves which would > make sense. The bus doesn't porpoise at all, the opposite it bangs > pretty hard over bumps. The shop feels that the springs would > function better if they were graduated from top to bottom and matched > to the weight that the bus is being ask to carry now. So there is > some reason to speculate that the bus would ride better with new > springs under it. The question remains HOW MUCH. I can spend the > money to find out. I might gain a lot I might gain just a little. > The fellows at the shop didn't think the bus rode too badly. They > objected to the loose steering more then the ride. I of course became > some what used to the steering. But it is much better now I will > grant you that. The shop obviously knews their stuff. > > There are other issues as well. Currently the they can buy the > springs off the shelf. If they become unavailable then they are have > to be custom made at about twice the cost. I have to factor all that > in with considerations as to how long I will keep the coach. I think > I will let a couple of the fellows drive the bus when we get together > at Hershey and see if there is a consensus of opinion. > John Heckman > central Pa > 1973 FC > > > > >> >> I would suspect that the shocks, if they show signs of being, worn >> might offer a modest but cost-effective improvement in handling. >> (Does the coach bounce excessively or porpoise?) Unless the > springs >> and shackles, etc. are clearly displaying out-of-spec sag or other >> bent components, that you'll get much less benefit from making any >> changes to them. >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> aeonix1@... >> On the road at Idaho Springs, CO >> >> >> >> On Aug 28, 2008, at 9:16 AM, bubblerboy64 wrote: >> >>> <snip> >>> There still remains the issue of the springs,shackles and shocks > with >>> respect to ride quality. To replace all of that stuff will set me >>> back pretty big bucks. Likely about $3500. Now the question is > how >>> much improvement, or how much bang for my buck will I get. At > this >>> point I am going to hold tight until I get to a rally so that > some of >>> you other fellows can drive my bus and see how it compares to >>> others. I would not mind spending the money if I was going to get >>> real value. I have nothing to compare to. So plan to head to >>> Hershey in Oct lets see if some of you guys can take'r out for a > spin >>> to see where I am at and where I should be going. >>> John Heckman >>> central Pa >>> 1973 FC >>> <snip> >> > > > > ------------------------------------ > > Yahoo! Groups Links > > > |
08-28-2008, 11:31
Post: #28
steering box
Pete, Shane and I got air pedestal seats about six weeks ago and that
helped so much I gotten greedy wanting more. I need to drive a couple newer buses and have guys who are in the know drive mine. Until I do that I really can't set long term goals. My goal is to be able to drive all day if needed and be reasonably comfortable. My bus is greatly improved but not there yet. If I can get to that point then I don't have a problem spending the money. If my goal is unrealistic then I would be better off trading up. So experience is needed and of course opinions considered. In the end I will have to decide what is right for me, I know that. Too bad I can't go to a used BB lot and drive two or three like you can a car. Maybe at a Rally? John Heckman central Pa 1973 FC > > Your idea of having others, with similar old coaches, give it a drive > and give you an opinion is probably a good one. When I was first > considering a coach, I was looking at bus conversions (not just BBs) > and I recall reading a web site that suggested that the Blue Birds > with air suspension were "much preferred" over the metal spring > suspension coaches -- so I'd expect that a somewhat hard ride might > be normal. (Years ago, I drove a few heavy trucks with spring > suspension in the Army -- they rode hard, but we didn't go very fast, > either.) I think one member got an "air ride seat" in his bird... it > might be a more cost effective choice to improve ride comfort. About > all I can say about my coach is that "it rides like a bus...." > > You might call the factory and see if you can get some opinions > there... if there's anyone around who remembers the spring- suspension > models. (I suppose that the school busses have the air suspension > these days, so knowledge about spring suspension may be lost by now...) > > Over $3000 is quite a price to pay for potentially only a small > incremental improvement.... > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Idaho Springs, CO > > > > On Aug 28, 2008, at 12:44 PM, bubblerboy64 wrote: > > > Hi Pete, The springs are pretty flat especially the back ones. One > > poster commented about wheel clearance. I have plenty of that. The > > shop thinks that when the engine was switched over to the 3208 the > > springs were modified by adding additional springs leaves which would > > make sense. The bus doesn't porpoise at all, the opposite it bangs > > pretty hard over bumps. The shop feels that the springs would > > function better if they were graduated from top to bottom and matched > > to the weight that the bus is being ask to carry now. So there is > > some reason to speculate that the bus would ride better with new > > springs under it. The question remains HOW MUCH. I can spend the > > money to find out. I might gain a lot I might gain just a little. > > The fellows at the shop didn't think the bus rode too badly. They > > objected to the loose steering more then the ride. I of course became > > some what used to the steering. But it is much better now I will > > grant you that. The shop obviously knews their stuff. > > > > There are other issues as well. Currently the they can buy the > > springs off the shelf. If they become unavailable then they are have > > to be custom made at about twice the cost. I have to factor all that > > in with considerations as to how long I will keep the coach. I think > > I will let a couple of the fellows drive the bus when we get together > > at Hershey and see if there is a consensus of opinion. > > John Heckman > > central Pa > > 1973 FC > > > > > > > > > >> > >> I would suspect that the shocks, if they show signs of being, worn > >> might offer a modest but cost-effective improvement in handling. > >> (Does the coach bounce excessively or porpoise?) Unless the > > springs > >> and shackles, etc. are clearly displaying out-of-spec sag or other > >> bent components, that you'll get much less benefit from making any > >> changes to them. > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> aeonix1@ > >> On the road at Idaho Springs, CO > >> > >> > >> > >> On Aug 28, 2008, at 9:16 AM, bubblerboy64 wrote: > >> > >>> <snip> > >>> There still remains the issue of the springs,shackles and shocks > > with > >>> respect to ride quality. To replace all of that stuff will set me > >>> back pretty big bucks. Likely about $3500. Now the question is > > how > >>> much improvement, or how much bang for my buck will I get. At > > this > >>> point I am going to hold tight until I get to a rally so that > > some of > >>> you other fellows can drive my bus and see how it compares to > >>> others. I would not mind spending the money if I was going to get > >>> real value. I have nothing to compare to. So plan to head to > >>> Hershey in Oct lets see if some of you guys can take'r out for a > > spin > >>> to see where I am at and where I should be going. > >>> John Heckman > >>> central Pa > >>> 1973 FC > >>> <snip> > >> > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > |
08-28-2008, 11:45
Post: #29
steering box
John,
Well, about all I can say is that I can drive my coach for 6, 8, or even 10 hours and not feel significantly more tired that if I'd driven my car that long. Frankly, I prefer to keep driving days to about 6 hours -- but that's true in the car as well. It's just a personal preference. It's been a very long time since I've driven a non-air suspension heavy vehicle -- and I was much younger then...! I guess you ought to drive a newer coach just to get a feel for the difference. You might watch the ads and see if there's a for-sale (newer unit) somewhere near you. A test drive of an air-suspended coach might just give you the additional data you need. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Aug 28, 2008, at 5:31 PM, bubblerboy64 wrote: > Pete, Shane and I got air pedestal seats about six weeks ago and that > helped so much I gotten greedy wanting more. I need to drive a > couple newer buses and have guys who are in the know drive mine. > Until I do that I really can't set long term goals. My goal is to be > able to drive all day if needed and be reasonably comfortable. My bus > is greatly improved but not there yet. If I can get to that point > then I don't have a problem spending the money. If my goal is > unrealistic then I would be better off trading up. So experience is > needed and of course opinions considered. In the end I will have to > decide what is right for me, I know that. Too bad I can't go to a > used BB lot and drive two or three like you can a car. Maybe at a > Rally? > > John Heckman > central Pa > 1973 FC >> >> Your idea of having others, with similar old coaches, give it a > drive >> and give you an opinion is probably a good one. When I was first >> considering a coach, I was looking at bus conversions (not just > BBs) >> and I recall reading a web site that suggested that the Blue Birds >> with air suspension were "much preferred" over the metal spring >> suspension coaches -- so I'd expect that a somewhat hard ride > might >> be normal. (Years ago, I drove a few heavy trucks with spring >> suspension in the Army -- they rode hard, but we didn't go very > fast, >> either.) I think one member got an "air ride seat" in his bird... > it >> might be a more cost effective choice to improve ride comfort. > About >> all I can say about my coach is that "it rides like a bus...." >> >> You might call the factory and see if you can get some opinions >> there... if there's anyone around who remembers the spring- > suspension >> models. (I suppose that the school busses have the air suspension >> these days, so knowledge about spring suspension may be lost by > now...) >> >> Over $3000 is quite a price to pay for potentially only a small >> incremental improvement.... >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> aeonix1@... >> On the road at Idaho Springs, CO >> >> >> >> On Aug 28, 2008, at 12:44 PM, bubblerboy64 wrote: >> >>> Hi Pete, The springs are pretty flat especially the back ones. > One >>> poster commented about wheel clearance. I have plenty of that. > The >>> shop thinks that when the engine was switched over to the 3208 the >>> springs were modified by adding additional springs leaves which > would >>> make sense. The bus doesn't porpoise at all, the opposite it > bangs >>> pretty hard over bumps. The shop feels that the springs would >>> function better if they were graduated from top to bottom and > matched >>> to the weight that the bus is being ask to carry now. So there is >>> some reason to speculate that the bus would ride better with new >>> springs under it. The question remains HOW MUCH. I can spend the >>> money to find out. I might gain a lot I might gain just a little. >>> The fellows at the shop didn't think the bus rode too badly. They >>> objected to the loose steering more then the ride. I of course > became >>> some what used to the steering. But it is much better now I will >>> grant you that. The shop obviously knews their stuff. >>> >>> There are other issues as well. Currently the they can buy the >>> springs off the shelf. If they become unavailable then they are > have >>> to be custom made at about twice the cost. I have to factor all > that >>> in with considerations as to how long I will keep the coach. I > think >>> I will let a couple of the fellows drive the bus when we get > together >>> at Hershey and see if there is a consensus of opinion. >>> John Heckman >>> central Pa >>> 1973 FC >>> >>> >>> >>> >>>> >>>> I would suspect that the shocks, if they show signs of being, > worn >>>> might offer a modest but cost-effective improvement in handling. >>>> (Does the coach bounce excessively or porpoise?) Unless the >>> springs >>>> and shackles, etc. are clearly displaying out-of-spec sag or > other >>>> bent components, that you'll get much less benefit from making > any >>>> changes to them. >>>> >>>> Pete Masterson >>>> '95 Blue Bird Wanderlodge WBDA 42 >>>> aeonix1@ >>>> On the road at Idaho Springs, CO >>>> >>>> >>>> >>>> On Aug 28, 2008, at 9:16 AM, bubblerboy64 wrote: >>>> >>>>> <snip> >>>>> There still remains the issue of the springs,shackles and shocks >>> with >>>>> respect to ride quality. To replace all of that stuff will set > me >>>>> back pretty big bucks. Likely about $3500. Now the question is >>> how >>>>> much improvement, or how much bang for my buck will I get. At >>> this >>>>> point I am going to hold tight until I get to a rally so that >>> some of >>>>> you other fellows can drive my bus and see how it compares to >>>>> others. I would not mind spending the money if I was going to > get >>>>> real value. I have nothing to compare to. So plan to head to >>>>> Hershey in Oct lets see if some of you guys can take'r out for a >>> spin >>>>> to see where I am at and where I should be going. >>>>> John Heckman >>>>> central Pa >>>>> 1973 FC >>>>> <snip> >>>> >>> >>> >>> >>> ------------------------------------ >>> >>> Yahoo! Groups Links >>> >>> >>> >> > > > > ------------------------------------ > > Yahoo! Groups Links > > > |
08-28-2008, 15:50
Post: #30
steering box
John,
By all means change your shocks. You will see a difference. Go to a NAPA store and tell them you have a '78 Bird. You can get NAPA shocks(they are the same as Monroe. Same co.) The reason for a '78 model is the engine(they were all diesel). Plus, the part #'s are in their book. How do I know? Personal experience. I had a '78. Installation was easy. Did it in the driveway, without having to jack anything up. Steve Gureasko 90WLWB40 Jus Chillin Ponchatoula, La Waiting and watching Gustav make it's move before I make mine. A game of chess!! |
