Hot skin safety test time
09-03-2008, 09:29
Hello everyone:
It has been a warm summer for most of us and the A/C's have been running
leaving the heaters and other things at rest.
I have been doing up grades and some R&R on some of the systems in Ruff
Diamond. And with winter coming up I decided it was time to do a hot skin
test as it is on my PM list every 6 months.
What your checking for is any rise in AC voltage from a ground/ground
source with the negative lead on your meter attached to that and the red
lead to probe several spots around the door frame metal. What you should
see when first hooking up the meter is .0001 plus or minus 0. If you see a
reading of .0201 reading then you have a hot skin with 1/4 volts AC (it can
be as much as 1/2 volt AC), and need to find the source of the voltage.
What will a hot skin do? It will send a tingling through your body if you
touch any metal part of the Coach while standing in a rain puddle or if
your sweaty and hot skin has been known to send enough voltage via amperage
through your hand to ground to knock you off the step and yes, deaths have
occurred. Is it serious, darn right it is.
If you don't have a deviation great, fold it up your done and you and your
Family are safe. If you do have voltage then use a clip lead and connect
the red lead to a point around the door and go to the main breaker box and
starting with one breaker (either leg) switch it off and check the meter
for change, do this on both legs until you find a change and what ever
breaker you switch off the difference is noted then that is the AC
electrical circuit you need to find the problem on.
If, when you first do the check and the meter range is un stable try
pouring a glass of water on the ground rod you drove into the ground for
your ground /ground. If the meter is still ranging up and down then more
than likely you do not have a hot skin but dirty contacts on the change
over switch, automatic or manual it does not matter.
Oh for my ground I use a copper tool I made for doing this. You can take an
18inch length of rebar, sharpen one end and drive it into the ground just
out side the door way so you can attach the black meter lead to it.
The whold think take less and 10 minutes to do and you know if your safe or
that you need to find the problem.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
09-03-2008, 10:16
Ralph, thanks for this, I have "hot skin" and also had it on my old
FC. I have a question...
One question...my coach is plugged into a non-grounded (the old 2-pin
type) outlet when parked at home. I am no electrician, but I had
convinced myself that this non-grounded outlet was the source of
my "hot skin". The "hot skin" isn't there when on generator power.
Is there any logic to that theory?
Scott Forman
86 PT38
Memphis
> Hello everyone:
running
Ruff
hot skin
ground/ground
the red
should
you see a
(it can
voltage.
if you
or if
amperage
deaths have
and your
connect
box and
meter
ever
try
ground for
more
change
take an
ground just
safe or
> Safe travels,
> Duncan, Oklahoma
09-03-2008, 10:35
Yes there is logic to that because the ground and neutral tie is not
present so there is only a path back to neutral and not ground, but still
go through the switching each breaker off and check. You will or should not
have a hot skin when plugged into campground shore power, or gen set, and
the hot skin is more prevalent when plugged into a 110 vac source vs 220 vac.
In recent posts, we learned that the only place that the neutral and ground
are to be bonded together is at the source only and not the coach. I have
seen the neutral and ground bonded in the heater in the bath where the
wiring got hot and melted through the wire nuts because the wire nuts were
not tight and taped and this was causing the hot skin test to fail. I also
found much the same thing in a 4x4 electrical box in route to the water heater.
I needed to mention the adapter to 110vac should be used for this test.
Safe travels,
Duncan, Oklahoma
>Scott Forman
>86 PT38
>Memphis
> > Hello everyone:
>running
>Ruff
>hot skin
>ground/ground
>the red
>should
>you see a
>(it can
>voltage.
>if you
>or if
>amperage
>deaths have
>and your
>connect
>box and
>meter
>ever
>try
>ground for
>more
>change
>take an
>ground just
>safe or
> > Safe travels,
> > Duncan, Oklahoma
09-03-2008, 10:46
Ralph,
Does this apply to the coaches that have 50 amp service?
If so, and I plug into a 30 amp. outlet only one leg of the two leg
system is hot, the other side has no power, Do I run the test as
first decribed or is there an alternative proceedure?
I have on rare occasions felt that tingling on the coach.
Thanks,
Kurt Horvath
95 PT-42
10AC
not
still
should not
set, and
vs 220 vac.
and ground
I have
nuts were
I also
water heater.
test.
> Safe travels,
> Duncan, Oklahoma
pin
> >Scott Forman
> >86 PT38
> >Memphis
> > wrote:
> > > Hello everyone:
> >running
in
> >Ruff
> >hot skin
> >ground/ground
> >the red
you
> >should
> >you see a
volts AC
> >(it can
> >voltage.
body
> >if you
puddle
> >or if
via
> >amperage
> >deaths have
you
> >and your
> >connect
breaker
> >box and
> >meter
what
> >ever
AC
> >try
> >ground for
then
> >more
> >change
can
> >take an
> >ground just
it.
your
> >safe or
> > > Safe travels,
> > > Duncan, Oklahoma
09-03-2008, 10:52
Kurt:
You can use an adapter for the 50 amp to 20 amp and 110vac will be on both
legs. You won't be running and major items while doing this test but it
will suffice to do the test and check.
Ralph
At 10:46 PM 9/3/2008 +0000, you wrote:
>Ralph,
>Thanks,
>Kurt Horvath
>95 PT-42
>10AC
>not
>still
>should not
>set, and
>vs 220 vac.
>and ground
>I have
>the
>nuts were
>I also
>water heater.
>test.
> > Safe travels,
> > Duncan, Oklahoma
>pin
> > >Scott Forman
> > >86 PT38
> > >Memphis
> > > wrote:
> > > > Hello everyone:
> > >running
>in
> > >Ruff
> > >hot skin
> > >ground/ground
> > >the red
>you
> > >should
> > >you see a
>volts AC
> > >(it can
> > >voltage.
>body
> > >if you
>puddle
> > >or if
>via
> > >amperage
> > >deaths have
>you
> > >and your
> > >connect
>breaker
> > >box and
>the
> > >meter
>what
> > >ever
>AC
> > >try
> > >ground for
>then
> > >more
> > >change
>can
> > >take an
> > >ground just
>it.
>your
> > >safe or
> > > > Safe travels,
> > > > Duncan, Oklahoma
>Yahoo! Groups Links
Safe travels,
Duncan, Oklahoma
09-03-2008, 10:59
Thanks Ralph,
I should have read your first post twice.
Kurt
> Kurt:
on both
but it
> Ralph
> >Ralph,
> >Thanks,
> >Kurt Horvath
> >95 PT-42
> >10AC
> >not
but
> >still
> >should not
> >set, and
source
> >vs 220 vac.
> >and ground
coach.
> >I have
where
> >the
> >nuts were
fail.
> >I also
> >water heater.
this
> >test.
> > > Safe travels,
> > > Duncan, Oklahoma
my old
old 2-
> >pin
had
of
power.
> > > >Scott Forman
> > > >86 PT38
> > > >Memphis
> > > > wrote:
> > > > > Hello everyone:
been
> > > >running
systems
> >in
> > > >Ruff
do a
> > > >hot skin
> > > >ground/ground
that and
> > > >the red
What
> >you
> > > >should
0. If
> > > >you see a
> >volts AC
> > > >(it can
> > > >voltage.
your
> >body
> > > >if you
> >puddle
> > > >or if
voltage
> >via
> > > >amperage
yes,
> > > >deaths have
> >you
> > > >and your
lead and
> > > >connect
> >breaker
> > > >box and
check
> >the
> > > >meter
> >what
> > > >ever
> >AC
stable
> > > >try
> > > >ground for
down
> >then
> > > >more
on the
> > > >change
You
> >can
> > > >take an
> > > >ground just
lead to
> >it.
if
> >your
> > > >safe or
> > > > > Safe travels,
> > > > > Duncan, Oklahoma
> >Yahoo! Groups Links
> Safe travels,
> Duncan, Oklahoma
09-04-2008, 04:41
Turning on a breaker does not a load make. electricians have ways to
pump the wires and test the path or use Ohms to test resistance and
possible path. Your test will prove some issues but $150 with a
Marine specific electrical tech will prove all.
I droped the bus off at a Marina for a safety check once purchased.
There are big issues with boats shored at docks and these techs have
more experience with issues typical to our bus. I am cheap and like
to learn by doing but the study of electric is a practice with many
if-then synarios.
I test my pool light with a tennis ball but it is hard to encourage a
dog to turn on the Bus microwave and water heater. hire this one out
only gotta do it once and maintain it there after.
GregoryO'Connor
94ptRomoland
> Hello everyone:
running
Ruff
hot skin
ground/ground
the red
should
you see a
(it can
voltage.
if you
or if
amperage
deaths have
and your
connect
box and
meter
ever
try
ground for
more
change
take an
ground just
safe or
> Safe travels,
> Duncan, Oklahoma
09-04-2008, 17:35
John:
It is possible of course. Check the ground and neutral in that outlet back
to the main breaker box. The neutral should only be tied to ground in the
main. Still, in Rv's it can be an easy thing to have a hot skin on other
units as well if the neutral is touching the ground in one or more of any
appliance or wiring junction boxes that were used.
Yes you need a multimeter, and there are some meters on the market that has
an IR built into them for checking hot spots like on tires rims or what ever.
Do the checks on the Coach and if there is no change in the meter readings
when you go through the shut off of the breakers in the main control box
then it is a good bet you have a problem with the source.
Safe travels,
Duncan, Oklahoma
At 02:12 AM 9/5/2008 +0000, you wrote:
>This is rather timely. I was sitting on the ground at the back of my
>coach and touched the exhaust pipe from the genny. My first thought
>was the pipe was hot (like in temperature) but after considering it
>was hot like in electric. I fear I must reseach this. I guess I am
>going to have to get one of them there meters and learn how to use
>it. The only clue I have on this is that I have had that happen
>before with trailers and such parked in the same place. Now this is
>a real stupid question is there anyway this could be house related
>and not RV related? The bus is parked over the electrical line that
>leads from the "box" underground into the meter and then the house.
>Just seems odd to have had so similar a situation with two RV's and
>no other indications of trouble. I guess I do need a meter don't I?
>The bus was plugged into the AC outlet I am pretty certain.
>John Heckman
>central Pa
>1973 FC
