Refrigerator cooling fans
09-08-2008, 05:05
Behind my refrigerator are two small 12 volt fans that have 12 volts
to them. They are equipped with a small button thermal switch. I am
assuming these fans should come on when the temperature behind the
refrigerator gets above a certain temperature. Mine never seem to run
even when it is 100 degrees outside and the sum is shining on that
side of the coach. Does anyone know the reason why they do not run?
Does anyone know at what temperature these button thermal switches
kick in? Yes I have the switch in the galley set to "on".
Chet Geist
1981 FC33, Austin, Texas
09-08-2008, 05:29
Your assumption is correct. You can try this...Use an IR gun and a hair drying or heat gun and test the snap switches. Point the IR on the snap switch and heat it up, record the IR temp. when the fan starts.
Might need new snap switches, or lower ON switches. They come in a wide range of settings. A thermostat works well. I installed a cheap heat/cool thermostst, powered it from behind the frig, wired it to the fan, set the temp at 85 and the fan comes on as needed.
Chet Geist
Curt Sprenger
Anaheim Hills, CA
09-08-2008, 07:23
--- In WanderlodgeForum@yahoogroups.com, "chetgeist" wrote:
My guss is there shot.You could connect them direct to a 12 volt
to see if they will run.
Bob Loomas 1985 PT 36
Harahan La.
> Chet Geist
09-08-2008, 12:35
You could try jumping them out and see if the fans start. If not the
fan may be NG.
If the switch is bad I got a dozen off ebay for a fan to cool the
charger compartment where Im putting an inverter. Supposed to close
at 45 dC or about 115dF. If you want one let me know and I'll send
one out...
/Joe
> Chet Geist
09-08-2008, 12:54
Thanks to all for the advise. I did jump the snap thermal switch on one of the fans and it runs fine. The refrigerator seemed to cool a little better this afternoon, but that was just a short test with only 95 degree temperature outside. I will probably bypass the thermal on the other fan soon and see if that is a good solution. I will also pull one of the thermal switches and see if I can get a number or something off of it and then buy two new ones.
Have been packing today to go to the Texas coast on Thursday and wouldn't you know it here comes Ike. May have to change plans again. Dolly screwed up the last trip.
Chet Geist
-----Original Message-----
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of joepat50
Sent: Monday, September 08, 2008 7:35 PM
Subject: [WanderlodgeForum] Re: Refrigerator cooling fans
fan may be NG.
one out...
/Joe
> Chet Geist
09-08-2008, 16:20
I dont think the advantage is cool air over the coil as much as it
is removing hot air from the compartment. heat is a necessary part
of Einstines amonia evaporation process and it is important to
maintain a gradual cooling. I put a fan ducted to blow in the
compartmet but others (I think Ryan or Scott) have a fan at the
exhaust which would also remove the chance that blowing in will
pressurizing the compartment and push un burned lpg into the bus.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Chet Geist"
on one of
little better
other fan
it and
wouldn't
Dolly screwed
> up the last trip.
> Chet Geist
> fan may be NG.
close
send
> one out...
> /Joe
volts
I am
to run
that
run?
switches
> > Chet Geist
09-08-2008, 16:49
Me to Gregg,I cut and pasted this from my post 33990
Photos of Exhaust Vent Fans are in my album , (bumpersbird) bottom of
page two and top of page three.
The goal is to move air past the cooling coil mounted on the rear of
the fridge, in my case a Dometic RM 7030. I have an angled setup
with an enormous space behind the refer. It is recommended that
there be no more than 1" a space behind the fridge to facilitate
convection for cooling the coils. Well I'm not one to reinvent the
wheel so I wasn't going to pull out the fridge to build a baffle
system, the recommended fix.
This won't be so much of a problem for you if your fridge is
1" or less from the wall behind it. The origonal fan and snap
thermostat set up should work good if it's all there and working.
To move a sufficient amount of air past the coils. You have two
choices you can suck or blow. Blowing is not recommended, but it
works.
Greg's system is set up this way and after a little tweeking it
works fine.
So how do you suck enough air volume past the coils to make a
difference? I not an engineer so I went for POWER!
You know the old saying. Put enough thrust behind anything and it
will fly.
I mounted 5 - 130 CFM computer fans inside the flue vent on the
roof.
http://autos.ph.groups.yahoo.com/group/W...tos/view/7
006?b=29
I got a marine style switch with a four switch/breaker combo. I
chose waterproof because I mounted it on the cabinet near the sink in
the bathroom and because its high quality and most of all because it
looks cool.
006?b=32
I tagged into the 12V power leading into the fridge.
006?b=30
Not a big draw for the fans and the fridge doesn't draw anywhere
near the 20 amps supplied to it. I used 2 of the 4 switches leaving
2 for future use. I wired the switches, #1 runs 2 fans, #2 runs 3
fans so I have the capability to run 2 fans @ 260 cfm, 3 fans@ 390
cfm or 5 fans@ 650 cfm.
Yes if you're standing near the access hatch you know its working. On
a calm day it will suck in cigar smoke in from 12" to 14" away.
I also mounted 4 fans in the fridge that blow air across the cooling
fins inside the fridge and of course they circulate the internal air.
006?b=33
They are powered from the internal light assembly and mounted in
pairs they are quite nice. I got them from a guy on e-bay. Once you
see these little jewels you'll want them to. I check e-bay for this
guy and he's not making any fans at this time
The only problem I had was getting the wiring up to the fans. I used
a piece of pvc pipe I don't remember the size I just grabbed some
pipe that was laying around the barn and some mounting clamps,
inserting the require wires into the conduit before mounting the
conduit to the wood walls.
006?b=31
I poked a hole up through the protective
screen in the flue vent, keeping it smaller than the diameter of the
pipe so it has a good grip on it. I had to drill one hole through the
wall to run the wires into the bathroom. A glob of silicon sealed the
hole and holds things firmly to prevent chaffing. I also used wire
loom where possible. Problem solved.
So far so good, this summer will tell if its working as well as I
think it will. I have already had to set the thermostat up to keep
everything on the lower shelves from freezing.
Is it noisy? Yes
Is it bothersome? Somewhat
Choice between noise and cold beer? Only you can answer that.
The fans are the big computer fans 4.7" @130cfm. There are fans of
this size that have a lower cfm and are much quieter to operate. I
have used these same fans to replace the blowers on some of my
heaters and they are quiet compared to the fridge set up. The only
thing I can think of is the fridge cabinet is hollow it may amplify
the noise.
This post is a little long and may not help a lot in your
application, but if you have a big space behind the fridge this will
work.
Kurt Horvath
95 PT-42 WLWB
> GregoryO'Connor
> 94ptRomolandCa
> on one of
> little better
> other fan
> the
of
> it and
> wouldn't
> Dolly screwed
> > up the last trip.
> > Chet Geist
not
> the
> > fan may be NG.
> close
> send
> > one out...
> > /Joe
12
> volts
switch.
> I am
behind
> the
seem
> to run
> that
not
> run?
> switches
> > > Chet Geist
09-09-2008, 00:09
I've been in Vegas all summer..ave temp over 103 every day...dometic
fridge worked fine..NO fan..more than 3inches behind coils in my
bird.....
Regards,
Hank
90SP36
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
of
> works.
> works fine.
> will fly.
> roof.
> 006?b=29
in
> looks cool.
> 006?b=32
> 006?b=30
On
air.
> 006?b=33
> 006?b=31
> Is it noisy? Yes
> the noise.
> work.
> Kurt Horvath
> 95 PT-42 WLWB
it
part
> > GregoryO'Connor
> > 94ptRomolandCa
switch
> > on one of
> > little better
degree
> > other fan
of
> > the
> of
> > it and
> > wouldn't
> > Dolly screwed
> > > up the last trip.
> > > Chet Geist
> not
> > the
> > > fan may be NG.
> the
> > close
> > send
> > > one out...
> > > /Joe
> 12
> > volts
> switch.
> > I am
> behind
> > the
> seem
> > to run
on
> > that
> not
> > run?
> > switches
> > > > Chet Geist
09-09-2008, 06:24
Chet,
As suggested, buy any 12 volt thermal switch or thermostat and wire it
in. The circuit is simple; switch in the coach provides 12 volts to
the thermostat which provides 12 volts to the fans above a certain
temperature.
I had a problem with my fridge not cooling well in 105+ degree heat
this summer. Found the previous owner had flat removed the fans. I
installed three high CFM 12 volt fans in the top of the fridge vent,
on the roof, per the advice of several folks here. Fridge temps are
stable and cold now no matter how hot it gets outside.
-Ryan
'86 PT-40 8V92
> up the last trip.
> Chet Geist
09-09-2008, 06:24
You are right Hank, We were in Gila Bend, 109 degrees and the Dometic held 37 in the refrigerator and -5 in the freezer. I was told by a service tech that a fan could help cool down faster but if the box was not getting cold enough there are other problems. He also said that if should be placed to remove hot air from the compartment behind the refrigerator not to blow on the coils because you could just recirculate hot air. He placed our fanat the vent stack.
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Henry Jay Hannigan
Sent: Tuesday, September 09, 2008 7:09 AM
bird.....
Regards,
Hank
90SP36
--- In "WanderlodgeForum%40yahoogroups.com", "Kurt Horvath"
of
> works.
> works fine.
> will fly.
> roof.
http://autos.ph.groups.yahoo.com/group/WanderlodgeForum/photos/view/7
> 006?b=29
in
> looks cool.
> 006?b=32
> 006?b=30
On
air.
> 006?b=33
> 006?b=31
> Is it noisy? Yes
> the noise.
> work.
> Kurt Horvath
> 95 PT-42 WLWB
> --- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor"
it
part
> > GregoryO'Connor
> > 94ptRomolandCa
> > --- In "WanderlodgeForum%40yahoogroups.com", "Chet Geist"
switch
> > on one of
> > little better
degree
> > other fan
of
> > the
> of
> > it and
> > wouldn't
> > Dolly screwed
> > > up the last trip.
> > > Chet Geist
> > > From: "WanderlodgeForum%40yahoogroups.com"
> > > [mailto:"WanderlodgeForum%40yahoogroups.com"]On Behalf Of joepat50
> > > To: "WanderlodgeForum%40yahoogroups.com"
> not
> > the
> > > fan may be NG.
> the
> > close
> > send
> > > one out...
> > > /Joe
> 12
> > volts
> switch.
> > I am
> behind
> > the
> seem
> > to run
on
> > that
> not
> > run?
> > switches
> > > > Chet Geist
