Electric Heaters, galley, salon, bedroom-the long thin heaters
09-10-2008, 06:44
Has anyone found the direct replacement for the electric heaters
found in the Galley, Salon and Bedroom?
Am familiar with the Cadet PerfectToe. I've replaced a few in the
Prevost coaches. The PerfectToe heaters have not been tested and are
NOT recommended for Vertical installations such as those in the
Bedroom and Galley heaters in 80's Birds.
Have researched the forum and read Dayton and Fasco names, but have
not been able to find correct heaters by these companies.
My heaters have been cleaned and they still operate, though with
little air movement and limited high thermostat settings.
Would like to just buy 3 new heaters to replace the originals and be
done, not buying pieces and parts to recondition them. But will if
thats the best answer ;~}
Thanks
jay darst
85PT40
91PrevostRoyale40XL
96PrevostCountryCoach40XL
Sullivan, IL
217 - 971 - 0036 cell
09-10-2008, 07:07
Do an Internet search on "toe heater".
Thanks
jay darst
85PT40
91PrevostRoyale40XL
Sullivan, IL
Curt Sprenger
Anaheim Hills, CA
09-10-2008, 09:56
Jay I used this one in the bath room Dayton Fan force wall
3UG16D Grainger catalog page 3194.Tomorrow ill be going to my bird
I can get you the info on the replacement for the bedroom.
Bob Loomas 1985 PT 36
Harahan La.
are
be
> Thanks
> jay darst
> 85PT40
> 91PrevostRoyale40XL
> Sullivan, IL
09-10-2008, 10:42
Just got done replacing the bedroom and kitchen heaters with new
Cadet Perfectoe heaters.
When I pulled the old ones out, they had stamped on them "No for
vertical installation".
Figured if old ones could be vertical, new ones could also.
New ones are smaller, so had to modify openings.
Bob Lawrence
84 PT36
Branson, Mo. (Still workcamping)
> Harahan La.
> are
have
> be
if
> > Thanks
> > jay darst
> > 85PT40
> > 91PrevostRoyale40XL
> > Sullivan, IL
09-11-2008, 04:11
Jay,
Nope, and I spent a good deal of time last year searching, too. My
heaters move enough air but also have limited high thermostat settings
which drives me to supplement with LP during the hard cold of winter.
I've been considering installing an automation controller, replacing
all heat & air thermostats with relays and temperature sensors, and
controlling HVAC throughout the entire bus from a small touchpanel.
This would allow me to set the heaters to any temperature and give me
a single control point. Unfortunately it also requires a lot of time
disassembling panels and running wires throughout the coach, which is
why I've not done it yet.
One thing you're going to notice, and the reason I gave up my search
for new heaters, is that nobody makes a 20 amp 120 volt toe heater
anymore. Your existing heaters are 20 amps a pop and the extra power
is nice on a cold winter night. So even if you do find something that
fits, it's not going to put out as much heat.
If someone does happen to find 20 amp heaters that fit, they're going
to sell a bunch of 'em.
-Ryan
'86 PT-40 8V92
> Thanks
> jay darst
> 85PT40
> 91PrevostRoyale40XL
> Sullivan, IL
09-11-2008, 05:54
These heaters are not as wide as the ones in my coach, 17 3/4" but
they might work for you.
http://www.heatersplus.com/qts.htm
Kurt Horvath
95 PT-42
10AC
> Jay,
settings
winter.
me
is
that
going
> -Ryan
> '86 PT-40 8V92
are
have
be
> > Thanks
> > jay darst
> > 85PT40
> > 91PrevostRoyale40XL
> > Sullivan, IL
09-11-2008, 06:05
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
The grill on this one looks like the ones in my coach.
http://www.cadetco.com/show_product.php?prodid=1005
Some other options?
http://www.houseneeds.com/Shop/HeatingPr...electrical
/mysonelectricaltoekickheaters.htm
> http://www.qmarkmeh.com/develop/prod_pdf...-QTSOO.pdf
http://www.grainger.com/Grainger/items/2...Item=2YV10
> Kurt Horvath
> 95 PT-42
> 10AC
> > Jay,
> settings
> winter.
replacing
touchpanel.
give
> me
time
which
> is
search
power
> that
> going
> > -Ryan
> > '86 PT-40 8V92
> are
> have
> be
if
> > > Thanks
> > > jay darst
> > > 85PT40
> > > 91PrevostRoyale40XL
> > > Sullivan, IL
