Parking brake knob
05-24-2005, 14:01
Parking brake knob
Ernie the easiest way to replace the park brake valve is to remove the trim
on the bottom dash and pull the dash up far enough to remove the valve. NAPA has them. tom 1982 FC35 Vernon Center,NY At 07:25 PM 5/24/2005 -0400, you wrote: >perhaps a skinny teenager that doesn't have to wear bi-focals? Ernie > > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-24-2005, 15:10
Parking brake knob
Ernie some of the BB (like my 1982 FC35) did not have 2 microswitches to
turn off the air at the open and closed position. As a result it just keeps leaking until your wet tank pressure is zero. Tom 1982 FC35 Vernon Center,NY is At 10:21 PM 5/24/2005 -0400, you wrote: >great idea, Tom. I'll pass that along. Ernie- 83PT40- no leak in the knob- >just in my step |
05-24-2005, 23:15
Parking brake knob
fixing the leak may cure the problem...randydupree93wb
----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 24, 2005 11:10 PM Subject: Re: [WanderlodgeForum] Re: Parking brake knob Ernie some of the BB (like my 1982 FC35) did not have 2 microswitches to turn off the air at the open and closed position. As a result it just keeps leaking until your wet tank pressure is zero. Tom 1982 FC35 Vernon Center,NY is At 10:21 PM 5/24/2005 -0400, you wrote: >great idea, Tom. I'll pass that along. Ernie- 83PT40- no leak in the knob- >just in my step ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-26-2005, 02:13
Parking brake knob
I believe that is in the works. Thanks, Ernie-83PT40 in Texas- my parking
brake knob doesn't leak- my step does [Non-text portions of this message have been removed] |
05-26-2005, 06:15
Parking brake knob
Thanks Randy! Another new trick. Easier to do, and no top plate to
jab me in the ribs! - Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > bob,does the seat not lift off of the pedestal? just losen the big wing nut and lift it off..i'm sure my 84 would lift off.my 93 does not! randydupree93wb > ----- Original Message ----- > From: freewill2008 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 24, 2005 6:33 PM > Subject: [WanderlodgeForum] Re: Parking brake knob > > > When I need to work around or under the dash, I just unbolt the > operator's seat from the seat post. Much better than wishing you had a > neck like a girrafe and a head like a golf ball with eyes all the way > around it, and tentacles instead of arms. > > If the seat has electric or air controls, there might be some > disconnecting to do. > > Bob Griesel '84 FC31 WLII WA > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Thanks, Bill- the culprit valve is on a FC. Maybe the individual can > squeeze > > in there to remove it. Ernie in Texas > > > > > > [Non-text portions of this message have been removed] > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
05-26-2005, 09:41
Parking brake knob
The parking brake kknob has been sucessfully- R/R and the coach airs up
faster then ever. He opened the lower dash to see what he was getting in for. many thanks go out to the forum for all their suggestions. Ernie-83PT40 in Texas [Non-text portions of this message have been removed] |
05-26-2005, 11:53
Parking brake knob
Randy, I just got this message and it's dated May 24...received a couple
other messages earlier today from you that were also dated a day or two back. Curt Sprenger â87PT38, Anaheim, Calif. randydupree wrote: > is it easier if you open the front panel? randydupree93wb > ----- Original Message ----- > From: racin41@... > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 24, 2005 3:31 PM > Subject: Re: [WanderlodgeForum] Parking brake knob > |
05-26-2005, 11:55
Parking brake knob
It's easiest from below the dash, it is open to the bottom. The hard
part is swinging the wrenches, a crow's-foot tubing wrench on a short extension makes it work. Opening the front panel doesn't help, you can barely see it from the front. Similarly, opening the top of the dash gives a good view of the valve, but the fittings are on the bottom & side. Leave the dash in IMO. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, randydupree > is it easier if you open the front panel? randydupree93wb |
05-26-2005, 12:29
Parking brake knob
Jeff where can I just locate the knob that goes on the shaft that opperates the
air brake? Right now I just have a shaft and a D ring and that's it. Can you help me? Jon http://i2.photobucket.com/albums/y4/1942...C00382.jpg Jeff Miller It's easiest from below the dash, it is open to the bottom. The hard part is swinging the wrenches, a crow's-foot tubing wrench on a short extension makes it work. Opening the front panel doesn't help, you can barely see it from the front. Similarly, opening the top of the dash gives a good view of the valve, but the fittings are on the bottom & side. Leave the dash in IMO. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > is it easier if you open the front panel? randydupree93wb Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Mail Stay connected, organized, and protected. Take the tour [Non-text portions of this message have been removed] |
05-26-2005, 14:07
Parking brake knob
Any truck-part shop should be able to help you, I buy from a fleet
supplier but a Kenworth store, bus service, etc. You are looking for a parking brake button for the Bendix PP-1 valve. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, jon lechich wrote: > Jeff where can I just locate the knob that goes on the shaft that opperates the air brake? Right now I just have a shaft and a D ring and that's it. Can you help me? Jon |
