Reset switch on Kohler generators?
10-04-2008, 05:56
I blew the fuse on the generator a few days ago and replaced it. I've
checked the battery, ground, power at the solonoid. I get NOTHING when I hit the generator start switch. Any more ideas? Regards, GPSGary 84FC35 |
10-04-2008, 06:08
You blew a fuse and replaced it. Did the new fuse blow? Check the new fuse for continuity. If the fuse is good then hopefully Chuck Wheeler or someone of his electrical calibar will chime in here.
2008/10/4 hippieforever3 <"debra@ticogps.com">
-- Rob, Sue & Merlin Robinson 94 WLWB |
10-04-2008, 07:05
New fuse is fine.
I've even jumped a car battery directly to the heavy post on the solenoid just in case it was poor contacts and get nothing. Regards, GPSGary --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > You blew a fuse and replaced it. Did the new fuse blow? Check the new fuse > for continuity. If the fuse is good then hopefully Chuck Wheeler or someone > of his electrical calibar will chime in here. > > > 2008/10/4 hippieforever3 > > > I blew the fuse on the generator a few days ago and replaced it. I've > > checked the battery, ground, power at the solonoid. > > > > I get NOTHING when I hit the generator start switch. > > > > Any more ideas? > > > > Regards, > > GPSGary > > 84FC35 > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > |
10-04-2008, 13:38
Flakey fuse cap. Inserted small ball of aluminum foil.
Fixed Regards, GPSGary |
