You look for problems, YOU WILL FIND THEM!!!!
10-17-2008, 06:13
My problem hasn't changed as far as the exhaust being all messed up. Here is a photo of the exhaust now that I'm getting into it. I'm glad I didn't burn up! And we thought the cracked pipe next to the turbo was bad. The pipe is completely disconnected. You can't see any of these problems from the rear or curbside. By the way if this ball joint connector is supposed to let the pipe flex so it doesn't crack next to the turbo why is there a clamp on the mount that holds everything down tight???? Kurt Horvath 95 PT 42 10AC |
10-17-2008, 09:31
Kurt
Mine was burnt out and I replaced that bell? with stainless flex.
Fred & Jeanne Hulse
10-17-2008, 10:42
Same, here -- a previous owner installed stainless flex on mine too.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Edinburg, VA On Oct 17, 2008, at 5:31 PM, Fred Hulse wrote: > Kurt > Mine was burnt out and I replaced that bell? with stainless flex. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 |
10-17-2008, 13:02
Kurt, the frame on my dump truck twist quite a bit as I drive off road. I converted the truck from a city tractor and within one month the exhaust had 3 cracks ( one at the manifold) I replaced the pipe and bends then used widebands to join the unions and not pipe in bell ends that the system had. on one problem area I used straps with springs for washers to keep agressive but nota fixedforce on the joint. The truck builders crossed the frame to hang the stack whick leaves alot of room for flex and give to help avoid a crack but the bus exhaust cantilevers close off the maniforl. I think the weight of the exhaust should be held ridgit at the top with a single point as a pivot. then hung stable from the sides????? one other point to check is the motor and transmission mounts. they too cause diferential movement that may result as a crack.
Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > You look for problems, YOU WILL FIND THEM!!!! > > My problem hasn't changed as far as the exhaust being all messed up. > Here is a photo of the exhaust now that I'm getting into it. I'm glad I > didn't burn up! And we thought the cracked pipe next to the turbo was > bad. The pipe is completely disconnected. You can't see any of these > problems from the rear or curbside. > > By the way if this ball joint connector is supposed to let the pipe > flex so it doesn't crack next to the turbo why is there a clamp on the > mount that holds everything down tight???? > > Kurt Horvath > 95 PT 42 > 10AC > |
