Going to get coach
10-19-2008, 00:33
Going to get coach
Ron, we can help you put the bedroom back together when you get home.
Ernie Ekberg 83PT40 Weatherford, Texas |
10-19-2008, 03:59
Going to get coach
Hi to all of you. I paid the bill in Calgary yesterday via direct
wire transfer. The good news is: the exchange rate saved me about $4,000 dollars, so all is not bad. I will fly to Calgary in the morning to pick up the coach. I will have to button up the bedroom, since they wanted to charge me over $600 labor to do that. I won't leave Calgary until Tuesday morning. Plan to stop see a friend in Lewistown, MT hopefully the first night out. Depends on how I have to run with the re-built engine. I will take a route back home avoiding as much mountain driving as possible. Once back in the US and further south, I should be able to get back on line using my dish and I can give a report on how the engine is performing. Dick: Sorry to hear about you tranny problems. Hope they are minor. R.E. (Ron) Marabito, Dallas, TX 92WB40 |
10-19-2008, 04:38
Going to get coach
10-19-2008, 05:06
Going to get coach
If that had happened to me, I probably would have shut the engine down, also. I bet it was very stressful to see the bodily fluids flowing so freely out of an area that is not supposed to be that way.
10-19-2008, 05:48
Going to get coach
Ron, Is there anything that can be done to Dan, 8v92, From: Hi to all of you. I paid the bill in wire transfer. The good news is: the exchange rate saved me about $4,000 dollars, so all is not bad. I will fly to in the morning to pick up the coach. I will have to button up the bedroom, since they wanted to charge me over $600 labor to do that. I won't leave until Tuesday morning. Plan to stop see a friend in out. Depends on how I have to run with the re-built engine. I will take a route back home avoiding as much mountain driving as possible. Once back in the and further south, I should be able to get back on line using my dish and I can give a report on how the engine is performing. Dick: Sorry to hear about you tranny problems. Hope they are minor. R.E. (Ron) Marabito, |
10-19-2008, 07:25
Going to get coach
I've got to cover the hole before I depart. The rest is simple.
Thanks R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Ron, we can help you put the bedroom back together when you get home. > > Ernie Ekberg > 83PT40 > Weatherford, Texas > > **************New MapQuest Local shows what's happening at your destination. > Dining, Movies, Events, News & more. Try it out > (http://local.mapquest.com/?ncid=emlcntnew00000002) > |
10-19-2008, 07:27
Going to get coach
Yes Wallace, but most of the damage was done after the shut-down
because it dumped all the coolant out the air box drain, thus overheating the engine and seizing it up. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > Ron, somewhere I missed the information as to what the final problem was found to be. Was there anti-freeze in the oil? Good travels. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Sun, 10/19/08, ronmarabito2002 > > From: ronmarabito2002 > Subject: [WanderlodgeForum] Going to get coach > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 19, 2008, 10:59 AM > > Hi to all of you. I paid the bill in Calgary yesterday via direct > wire transfer. The good news is: the exchange rate saved me about > $4,000 dollars, so all is not bad. > > I will fly to Calgary in the morning to pick up the coach. I will > have to button up the bedroom, since they wanted to charge me over > $600 labor to do that. I won't leave Calgary until Tuesday morning. > Plan to stop see a friend in Lewistown, MT hopefully the first night > out. Depends on how I have to run with the re-built engine. I will > take a route back home avoiding as much mountain driving as possible. > > Once back in the US and further south, I should be able to get back > on line using my dish and I can give a report on how the engine is > performing. > > Dick: Sorry to hear about you tranny problems. Hope they are minor. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > ------------------------------------ > > Yahoo! Groups Links > |
10-19-2008, 07:30
Going to get coach
Only thing I can think of is for the safety sensors to shut it down
first. Since the coolant temp did not rise, that sensor didn't do anything. It needs an oil temp sensor, but this model didn't have one. I'm planning to get a hold of Detroit to find out if one can be added. But I think it has to do with the DDEC II R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Dan Williams" wrote: > > Ron, Is there anything that can be done to the engine to keep this from > happening again? > > Dan, 8v92, Jackson, ms > > > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002 > Sent: Sunday, October 19, 2008 11:00 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Going to get coach > > > > Hi to all of you. I paid the bill in Calgary yesterday via direct > wire transfer. The good news is: the exchange rate saved me about > $4,000 dollars, so all is not bad. > > I will fly to Calgary in the morning to pick up the coach. I will > have to button up the bedroom, since they wanted to charge me over > $600 labor to do that. I won't leave Calgary until Tuesday morning. > Plan to stop see a friend in Lewistown, MT hopefully the first night > out. Depends on how I have to run with the re-built engine. I will > take a route back home avoiding as much mountain driving as possible. > > Once back in the US and further south, I should be able to get back > on line using my dish and I can give a report on how the engine is > performing. > > Dick: Sorry to hear about you tranny problems. Hope they are minor. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > |
10-19-2008, 07:52
Going to get coach
10-19-2008, 08:06
Going to get coach
Doubt that the couple minutes I could have run it would have done much
to cool it down, although doing that with the fan in override might have helped. I didn't know what the problem was however, until I got out and saw the coolant being dumped. Someone else suggested to me a couple days ago that if I would have turned the engine over every few minutes, it might also have helped to prevent the seize-up. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > ?? Would you have been better off to let it keep runnning until it cooled down if that was an option? > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Sun, 10/19/08, ronmarabito2002 > > From: ronmarabito2002 > Subject: [WanderlodgeForum] Re: Going to get coach > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 19, 2008, 2:27 PM > > Yes Wallace, but most of the damage was done after the shut-down > because it dumped all the coolant out the air box drain, thus > overheating the engine and seizing it up. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > > > > Ron, somewhere I missed the information as to what the final problem > was found to be. Was there anti-freeze in the oil? Good travels. > > > > > > Wallace Craig > > 95 WLWB 42 > > Azle, Texas > > > > --- On Sun, 10/19/08, ronmarabito2002 > > > > From: ronmarabito2002 > > Subject: [WanderlodgeForum] Going to get coach > > To: WanderlodgeForum@yahoogroups.com > > Date: Sunday, October 19, 2008, 10:59 AM > > > > Hi to all of you. I paid the bill in Calgary yesterday via direct > > wire transfer. The good news is: the exchange rate saved me about > > $4,000 dollars, so all is not bad. > > > > I will fly to Calgary in the morning to pick up the coach. I will > > have to button up the bedroom, since they wanted to charge me over > > $600 labor to do that. I won't leave Calgary until Tuesday morning. > > Plan to stop see a friend in Lewistown, MT hopefully the first night > > out. Depends on how I have to run with the re-built engine. I will > > take a route back home avoiding as much mountain driving as possible. > > > > Once back in the US and further south, I should be able to get back > > on line using my dish and I can give a report on how the engine is > > performing. > > > > Dick: Sorry to hear about you tranny problems. Hope they are minor. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
