Front AC dripping water from ceiling grill
05-28-2005, 11:07
Liz I am wondering about the water also. Thanks for the post.
Rob Robinson
1994 WLWB
Victoria, BC
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Jack and Liz Pearce
Sent: Saturday, May 28, 2005 8:04 PM
Subject: [WanderlodgeForum] Front AC dripping water from ceiling grill
Howdy, Y'all.
We live in our 1993 Wanderlodge. The temperature outside today was in
the 90's with high humidity. A small amount of water is dripping from
the air conditioner ceiling grill in the living room. Jack says that
this drip is condensation on the condensate collection tray. When we
open that grill, we can see water droplets on the bottom of the
condensate tray. What can be causing this problem and how do we cure
it? I am NOT happy with this water dripping on the carpet.
Please help.
Thanks,
Liz
Regards,
Jack and Liz Pearce
1993 Wanderlodge WB40
Homesick Texans in Lantana, FL
Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.322 / Virus Database: 267.2.0 - Release Date: 5/27/2005
05-28-2005, 13:04
Howdy, Y'all.
Please help.
Thanks,
Liz
Regards,
Jack and Liz Pearce
05-28-2005, 13:30
FWIW...I had the same problem with our coach. The cure so far seems to
be working...had the AC roof units tuned up. I hired a guy to remove the
roof air covers, chemically clean the evaporators and flush them with
water, add freon as needed, $100.00 per AC unit. .So far the problem has
not repeated. But we don't have the humidity that you are experiencing.
> Rob Robinson
> 1994 WLWB
> Victoria, BC
> Howdy, Y'all.
> Please help.
> Thanks,
> Liz
> Regards,
> Jack and Liz Pearce
> Yahoo! Groups Links
> *Yahoo! Groups Links*
05-28-2005, 14:20
When we had a problem with water dripping from the A/C in the living
room it was because the drain tube was blocked. We had the air
conditioners serviced and the technician had to blow out the tube
from underneath the coach.
Do you know where all your drain tubes come out? In our 92 the front
and rear A/C drained to behind the wheels but the center A/C tube was
in the midline of the coach.
Julie Bonser
1992 WLWB PT 40'
On May 28, 2005, at 8:04 PM, Jack and Liz Pearce wrote:
> Howdy, Y'all.
> Please help.
> Thanks,
> Liz
> Regards,
> Jack and Liz Pearce
05-28-2005, 14:48
Liz........I had the same problem as you and had to perform the same
fix as Julie......Find the three drain hoses under the coach and blow
them ( with air from a air compressor ) from the bottom.......Be
carefull not to use to much air pressure as I can invision damage or
a mess,,,,but it did work for me........DAN SAARI
1992 WLWB 40ft
Depere, Wi
--- In WanderlodgeForum@yahoogroups.com, Julia Bonser
living
front
was
> Julie Bonser
> 1992 WLWB PT 40'
> > Howdy, Y'all.
was in
from
that
we
cure
> > Please help.
> > Thanks,
> > Liz
> > Regards,
> > Jack and Liz Pearce
