					Suspension not filling up...??? Tag pressure not going up???
					01-18-2009, 10:30
				 Post: #1 | |||
					Hello...All... as always I greatley appreciate any assistance from the group... I am getting ready to make the journey to the Q-ralley and I went to drive our 84 PT-40 for a quick trip and I cannot get the suspension to fill.... The front & rear pressure reads 75 pounds but the tag pressure is zero..... I have filpped both dump switches repeatedly but no change.... any suggestions???? | |||
					01-18-2009, 10:55
				 Post: #2 | |||
| Suspension not filling up...??? Tag pressure not going up??? air up your tanks with the suspension fill switches off. Let it blow off and then flip your switches. Ernie Ekberg 83PT40 in Texas In a message dated 01/18/09 16:30:45 Central Standard Time, brianp@... writes:
					01-18-2009, 10:56
				 Post: #3 | |||
					Dump switch in "UP" position. Then possiblities are governor, compressor, compressor belt, But first check for an air leak. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > Hello...All... as always I greatley appreciate any assistance from the > group... > > I am getting ready to make the journey to the Q-ralley and I went to > drive our 84 PT-40 for a quick trip and I cannot get the suspension to > fill.... > > The front & rear pressure reads 75 pounds but the tag pressure is > zero..... > > I have filpped both dump switches repeatedly but no change.... > > any suggestions???? > | |||
					01-18-2009, 10:56
				 Post: #4 | |||
| Suspension not filling up...??? Tag pressure not going up??? Bill, our air compressor is direct drive. Wish I was going to Q. Ernie Ekberg 83PT40 in Texas In a message dated 01/18/09 16:56:35 Central Standard Time, billpatty@... writes:
					01-18-2009, 11:06
				 Post: #5 | |||
					Opps,  No belt,  Just like my pants, I wish I was the fourth Amigo......... Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, erniecarpet > > Bill, our air compressor is direct drive. Wish I was going to Q. > > Ernie Ekberg 83PT40 in Texas > > > In a message dated 01/18/09 16:56:35 Central Standard Time, billpatty@... writes: > Dump switch in "UP" position. > > Then possiblities are governor, compressor, compressor belt, > But first check for an air leak. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > Hello...All... as always I greatley appreciate any assistance from > the > > group... > > > > I am getting ready to make the journey to the Q-ralley and I went > to > > drive our 84 PT-40 for a quick trip and I cannot get the suspension > to > > fill.... > > > > The front & rear pressure reads 75 pounds but the tag pressure is > > zero..... > > > > I have filpped both dump switches repeatedly but no change.... > > > > any suggestions???? > > > | |||
					01-18-2009, 15:26
				 Post: #6 | |||
					Keep in mind that the Front/Rear are brakes, not air bags. Those should peak around 120psi. In mine, the sequence is that the brakes air first, to about 75-90lbs, then the air bags, then the auxiliary items, then the brakes fill the rest of the way. If yours is the same, it sounds like something is leaking badly during the air bag fill. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Quartzsite My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 1/18/2009 at 10:30 PM t3brian wrote: >Hello...All... as always I greatley appreciate any assistance from the >group... > >I am getting ready to make the journey to the Q-ralley and I went to >drive our 84 PT-40 for a quick trip and I cannot get the suspension to >fill.... > >The front & rear pressure reads 75 pounds but the tag pressure is >zero..... > >I have filpped both dump switches repeatedly but no change.... > >any suggestions???? > > > >------------------------------------ > >Yahoo! Groups Links > > > | |||
					01-18-2009, 17:19
				 Post: #7 | |||
					Thank You everybody for your suggestions...... A combination of filling the suspension a few times after a short around the block drive did the trick!!!!!! However is this a sign of something on its way to a failure??? or... is it simply a sign of older parts that every once in awhile need a little kick start to get going??? the bird did 'rest' for 6 months since it's last venture.... but she is up and ready to go now... again thank you all for your suggestions... --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Keep in mind that the Front/Rear are brakes, not air bags. Those should peak around 120psi. > > In mine, the sequence is that the brakes air first, to about 75- 90lbs, then the air bags, then the auxiliary items, then the brakes fill the rest of the way. If yours is the same, it sounds like something is leaking badly during the air bag fill. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by satellite from Quartzsite > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 1/18/2009 at 10:30 PM t3brian wrote: > > >Hello...All... as always I greatley appreciate any assistance from the > >group... > > > >I am getting ready to make the journey to the Q-ralley and I went to > >drive our 84 PT-40 for a quick trip and I cannot get the suspension to > >fill.... > > > >The front & rear pressure reads 75 pounds but the tag pressure is > >zero..... > > > >I have filpped both dump switches repeatedly but no change.... > > > >any suggestions???? > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > | |||
					01-19-2009, 03:40
				 Post: #8 | |||
| Suspension not filling up...??? Tag pressure not going up??? I had many problems with this. When you flip the tag axle switch do you hear a rush of air?? On my wbwl when you remove the front panell covering the electric in the center od the coach there are three valves (forgot the name) they some times got stuck so the tag would not fill. flip the switch ah tap on there valves. I ended up replacing them and solved the problem Jim Riordan  88 WBWL XXV Stuart, Fl 772-260-1328 t3brian
					01-19-2009, 03:45
				 Post: #9 | |||
| Suspension not filling up...??? Tag pressure not going up??? I might of misread your post...main pressure guage only 75 pounds? sb 120, possible leak in air system. run bus pressure up shut off buss (carefully listen for leaks.). I had to replace the air dryer, in front of the rear axles in the center of the coach, underneath, this helped with the system spped in filling. Jim Riordan t3brian
					01-19-2009, 04:18
				 Post: #10 | |||
					IF your location is in a temperature below 32* freeze area, moisture, & condensation will cause all kinds of strange issues. there are numerous check valves , pressure reducing,etc valves, with diaphragms that do not like freezing temps. Bill 88 FC michigan --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > Thank You everybody for your suggestions...... > > A combination of filling the suspension a few times after a short > around the block drive did the trick!!!!!! > > However is this a sign of something on its way to a failure??? > > or... is it simply a sign of older parts that every once in awhile > need a little kick start to get going??? > > the bird did 'rest' for 6 months since it's last venture.... > > but she is up and ready to go now... > > again thank you all for your suggestions... > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > > > Keep in mind that the Front/Rear are brakes, not air bags. Those > should peak around 120psi. > > > > In mine, the sequence is that the brakes air first, to about 75- > 90lbs, then the air bags, then the auxiliary items, then the brakes > fill the rest of the way. If yours is the same, it sounds like > something is leaking badly during the air bag fill. > > > > Don Bradner > > 90 PT40 "Blue Thunder" > > Posting today by satellite from Quartzsite > > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > > > On 1/18/2009 at 10:30 PM t3brian wrote: > > > > >Hello...All... as always I greatley appreciate any assistance from > the > > >group... > > > > > >I am getting ready to make the journey to the Q-ralley and I went > to > > >drive our 84 PT-40 for a quick trip and I cannot get the > suspension to > > >fill.... > > > > > >The front & rear pressure reads 75 pounds but the tag pressure is > > >zero..... > > > > > >I have filpped both dump switches repeatedly but no change.... > > > > > >any suggestions???? > > > > > > > > > > > >------------------------------------ > > > > > >Yahoo! Groups Links > > > > > > > > > > > > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
