Aqua hot instrument panel switch
01-24-2009, 01:12
My instrument panel switch goes dead (light goes out and the diesel
does not run) after leaving it on for a couple of days. I usually rest
set it and the diesel starts and runs for a couple of day then the
switch goes dead again and must be reset. My question, is the switch
bad or is there something else going on in the system? Any advise is
welcomed.
Hisham Amaral
97 Wanderlodge 43'
Titusville,FL for the winter
01-24-2009, 01:50
Hisham
That indication to me is that your control module is going bad,I had the same symptoms and eventually had to replace it.
If you can get a hold of another one to borrow from another system,you can be certain then.
Fred & Jeanne Hulse
Morristown,Arizona
1997 Wanderlodge WB41
Posting from Quartzsite
01-24-2009, 03:22
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse"
> Hisham
> Fred & Jeanne Hulse
> Morristown,Arizona
Fred
Hope you are having fun at the Q.Side Raley.
Thank you for the input I am going to call Aqua Hot on Monday to
order one and also the panel switch. I talked to Paul Lazar he had
similar problem to mine, had the switch and the control module
replaced toke care of the problem.
Hisham Amaral
97 Wanderlodge
Titusville, FL
01-24-2009, 03:54
Good luck,I hope it works out for you!!
We are enjoying all the company this Ralley provides,all the folks are great..
Great weather this morning and will be throughout the day.
Fred & Jeanne Hulse
Morristown,Arizona
01-24-2009, 04:55
Hisham
When I am parked, and plugged, I use the AquaHot on electric. We have always had plenty of hotwater.
Mike
'97 BMC 40'
Michael Brody
P.O. Box 281
Dresher, Pennsylvania 19025
(V) 215-572-0663
(F) 215-572-6992
01-24-2009, 07:32
--- In WanderlodgeForum@yahoogroups.com, "Michael Brody"
<mibrody@...> wrote:
> Hisham
> When I am parked, and plugged, I use the Aqua Hot on electric. We
have always had plenty of hot water.
> Mike
> '97 BMC 40'
> Michael Brody
> P.O. Box 281
> (V) 215-572-0663
> (F) 215-572-6992
>Mike
The temp has been cold in Central FL so when I have the heat on
through the coach the electric cannot keep up so I have to start the
diesel burner the augment the electric.
Hisham
01-24-2009, 08:09
If the AquaHot fails to start, it will turn off the light and the diesel won't run. Discuss this with your AquaHot technician. If the switch is bad, the AquaHot won't cycle on at all.
Pete Masterson
'95 Blue Bird Wanderlodge WBDA 42 (For Sale)
El Sobrante CA
"aeonix1@mac.com"
welcomed.
Hisham Amaral
97 Wanderlodge 43'
01-24-2009, 14:34
I once had a similar problem. The problem turned out to be the
ignitor electrode had vibrated loose and sometimes the burner would
not ignight. When this happens the system shuts down and has to be
reset.
Happy trails,
Eric Perplies
96' 42' WBWL
01-24-2009, 23:53
--- In WanderlodgeForum@yahoogroups.com, "Eric Perplies"
> reset.
> Happy trails,
> Eric Perplies
> 96' 42' WBWL
>Eric
I had a problem last year but I corrected it by taking apart the
controller cleaned the contacts and reassembled, the system worked find
till now. We had a few day of temps in the upper 20's and low 30's in
Centrol Florida. The electric protion of the Aqua Hot will not keep up
with the heat demand, the diesel must add support to the system. I am
going to take the box apart and see if the electrode woked them self
loloose.
Again Thanks all for the input.
Hisham Amaral
97 Wanderlodge 43'
Titusville, FL for the winter.
01-25-2009, 03:06
Hi Hisham,
Many Foretravels are equipped with the Aqua-Hot systems. And many of us use a factory approved/authorized repairman named Roger Burke. Roger also runs the hydronic heat forum on yahoo groups, just like this group.He is quite knowledgeable with the systems. And he does excellent work, at the most reasonable of prices. The maker of the Aqua-Hot uses Roger to do repairs for themat many of the bigger conventions. He is roaming the south east now, in preparation for the FMCA Perry show. He has any parts you could need with him. Since he is down your way now, you may want to contact him. Try "roger.burke@gmail.com" or "AquaHot.Roger@gmail.com"
You can also go to the hydronic heat group, on-line, thru the yahoo groups.
Hope this helps,
Raymond Jordan
Foretravel
Maryland
In a message dated 1/25/2009 6:53:28 A.M. Eastern Standard Time, dukeflyer@... writes:
--- In "WanderlodgeForum%40yahoogroups.com", "Eric Perplies"
> reset.
> Happy trails,
> Eric Perplies
> 96' 42' WBWL
>Eric
loloose.
Hisham Amaral
97 Wanderlodge 43'
From Wall Street to Main Street and everywhere in between, stay up-to-date with the latest news.
