Dupree products & trim
02-06-2009, 05:41
I recently ordered (and received) replacement ballasts for my
2 light fixtures in the dining room but they are not low profile like the original and the only way they will work is if I put them inside the overhead compartments above the dining table. When I tried to contact Dupree, I got no response. Are they still in business? Also need to find a source for the hard rubber trim that fits in the top and bottom grooves of the ss side trim. Chuck Harrison Akron, Ohio 90 SP36 |
02-06-2009, 05:45
02-06-2009, 06:23
I called him
Stephen 77fc35 Dupree products .com --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > I recently ordered (and received) replacement ballasts for my > 2 light fixtures in the dining room but they are not low > profile like the original and the only way they will work is if I put > them inside the overhead compartments above the dining table. When > I tried to contact Dupree, I got no response. Are they still in > business? Also need to find a source for the hard rubber trim > that fits in the top and bottom grooves of the ss side trim. > > Chuck Harrison > Akron, Ohio > 90 SP36 > |
02-09-2009, 17:27
02-09-2009, 17:32
Chuck did you find the trim?
The flex-vinyl molding shrinks over time. BB did not have any nor did they know of a supplier manufacturing a replacement. I had spent some time trying to match up a cross section online with no luck. Just last week I bought some that was wider than my existing trim and clearly not as high a quality, but it looks just fine as it fits in the grooves and has a rounder profile. I'd be happy to send you a sample to try it and do have photos if you are interested. I purchased mine at Majors RV on Cape Cod MA and it was only $7 for 25FT. I did replace the whole pieces on the doors but only replace the sections that had shrunk for the sake efficiency. Michael Campbell 89 WLPT 40 ThunderBird --- In WanderlodgeForum@yahoogroups.com, "Michael" <michael3536@...> wrote: > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > I recently ordered (and received) replacement ballasts for my > > 2 light fixtures in the dining room but they are not low > > profile like the original and the only way they will work is if I put > > them inside the overhead compartments above the dining table. When > > I tried to contact Dupree, I got no response. Are they still in > > business? Also need to find a source for the hard rubber trim > > that fits in the top and bottom grooves of the ss side trim. > > > > Chuck Harrison > > Akron, Ohio > > 90 SP36 > > > |
02-10-2009, 02:27
What I did on our '90 PT40 worked and may for you.I used RTV on one
end to glue about a foot of the trim in place. Then on a hot day I stretched the vinyl insert toward the other end back to over it's original length then used RTV to glue that end (again about the last one foot). I secured the vinyl in place with duct tape until the RTV curred. This lasted the several years I still owned the coach. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Michael" <michael3536@...> wrote: > > > > Chuck did you find the trim? > > The flex-vinyl molding shrinks over time. BB did not have any nor did they know of a > supplier manufacturing a replacement. > > I had spent some time trying to match up a cross section online with no luck. > > Just last week I bought some that was wider than my existing trim and clearly not as high > a quality, but it looks just fine as it fits in the grooves and has a rounder profile. I'd be > happy to send you a sample to try it and do have photos if you are interested. I purchased > mine at Majors RV on Cape Cod MA and it was only $7 for 25FT. > > I did replace the whole pieces on the doors but only replace the sections that had shrunk > for the sake efficiency. > > Michael Campbell > 89 WLPT 40 > ThunderBird > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Michael" <michael3536@> wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > I recently ordered (and received) replacement ballasts for my > > > 2 light fixtures in the dining room but they are not low > > > profile like the original and the only way they will work is if I put > > > them inside the overhead compartments above the dining table. When > > > I tried to contact Dupree, I got no response. Are they still in > > > business? Also need to find a source for the hard rubber trim > > > that fits in the top and bottom grooves of the ss side trim. > > > > > > Chuck Harrison > > > Akron, Ohio > > > 90 SP36 > > > > > > |
02-10-2009, 06:15
Chuck,
As far as the rubber trim, go to this Ebay seller: http://stores.ebay.com/Mobile-Home-RV-Su...arts-Store Type "trim" in the search box on the left. They have all sizes, colors, etc. and the price is right. Dan Schrader 83 FC35 Buckeye Bird --- In WanderlodgeForum@yahoogroups.com, "Michael" <michael3536@...> wrote: > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > I recently ordered (and received) replacement ballasts for my > > 2 light fixtures in the dining room but they are not low > > profile like the original and the only way they will work is if I put > > them inside the overhead compartments above the dining table. When > > I tried to contact Dupree, I got no response. Are they still in > > business? Also need to find a source for the hard rubber trim > > that fits in the top and bottom grooves of the ss side trim. > > > > Chuck Harrison > > Akron, Ohio > > 90 SP36 > > > |
02-10-2009, 12:25
Hey Dan,
Just ordered 200 ft for our rig. Thanks. Bob Lawrence 84 PT36 Laguna Atascosa NWR Los Fresnos, Texas > Chuck, > As far as the rubber trim, go to this Ebay seller: > > http://stores.ebay.com/Mobile-Home-RV-Su...arts-Store > > Type "trim" in the search box on the left. They have all sizes, > colors, etc. and the price is right. > > Dan Schrader > 83 FC35 > Buckeye Bird > > --- In WanderlodgeForum@yahoogroups.com, "Michael" <michael3536@> > wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > I recently ordered (and received) replacement ballasts for my > > > 2 light fixtures in the dining room but they are not low > > > profile like the original and the only way they will work is if I > put > > > them inside the overhead compartments above the dining table. > When > > > I tried to contact Dupree, I got no response. Are they still in > > > business? Also need to find a source for the hard rubber trim > > > that fits in the top and bottom grooves of the ss side trim. > > > > > > Chuck Harrison > > > Akron, Ohio > > > 90 SP36 > > > > > > |
02-10-2009, 12:31
02-11-2009, 00:22
Ernie,
The Ebay seller is Mobile Home/RV Surplus Parts Store http://stores.ebay.com/Mobile-Home-RV-Su...arts-Store The easiest way to find all of their vinyl trim is to type "trim" in the search box upper left. I used the 3/4" black on the front of mine. Dan Schrader 83 FC35 http://buckeye-bird.com --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg wrote: > > Bob, can you send the exact link for the trim that you ordered? Mine has shrunk so bad that it really looks tacky. > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos.groups.yahoo.com/group/erni...gandrepair > > --- On Tue, 2/10/09, Bob Lawrence > > From: Bob Lawrence > Subject: [WanderlodgeForum] Re: Dupree products & trim > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, February 10, 2009, 6:25 PM > > > > > > > Hey Dan, > Just ordered 200 ft for our rig. > Thanks. > Bob Lawrence > 84 PT36 > Laguna Atascosa NWR > Los Fresnos, Texas > > > Chuck, > > As far as the rubber trim, go to this Ebay seller: > > > > http://stores. ebay.com/ Mobile-Home- RV-Surplus- Parts-Store > > > > Type "trim" in the search box on the left. They have all sizes, > > colors, etc. and the price is right. > > > > Dan Schrader > > 83 FC35 > > Buckeye Bird > > > > --- In WanderlodgeForum@ yahoogroups. com, "Michael" <michael3536@ > > > wrote: > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "williamcharrison" > > > > > > > > > > > I recently ordered (and received) replacement ballasts for my > > > > 2 light fixtures in the dining room but they are not low > > > > profile like the original and the only way they will work is if > I > > put > > > > them inside the overhead compartments above the dining table. > > When > > > > I tried to contact Dupree, I got no response. Are they still in > > > > business? Also need to find a source for the hard rubber trim > > > > that fits in the top and bottom grooves of the ss side trim. > > > > > > > > Chuck Harrison > > > > Akron, Ohio > > > > 90 SP36 > > > > > > > > > > |
