6V92 Detroit
02-18-2009, 13:27
6V92 Detroit
Well Gregg you got me curious. I looked at the web site you posted.
Why isn't it a good idea to use a CCV on a 2 stroke? When I researched this system all the inf. I found for it was on the boat sites, As I recall most of them had some sort of system to keep the oily mist off of and out of the enclosed engine compartments. I don't recall any reference to this being detrimental to any engine type. Either way a catch can keeps the oil from dripping on the ground,, the CCV recycles the gasses from the slobber tube back into the fresh air flow to be burnt again and keeps oil from dripping on the ground. The mfg.'s offered systems for all engine types and manufacturers --- So what up??? Kurt Horvath 95 PT 42 10AC In WanderlodgeForum@yahoogroups.com, "timvasqz" > > the drip from the slobbertubes is a function of scaveging and > necessary with the two stroke jimmies. There was a time when some > would direct the discharge back to the sump. All the aftermarket > engineering has down sides. > > The s60 is four stroke and has a way different setup. If slobber > bothers, you dont sleep sitting up and get a four stroke. > > Here is an article on the diffs between 2 and four strokes some times > refered to as two cycle and four cycle. "blower" and "turbo" are also > two terms confused which differ. > > http://www.yachtsurvey.com/comparing_diesel_types.htm > > Greg ofTim&Greg > 94ptca > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > wrote: > > > > > > Scooter, > > > > If it becomes bothersome you can install a trap or a CCV ( Closed > > Crankcase Ventilation System ) > > Racor makes one as well as Walker . They are used quite a bit on > > boats. > > I didn't like the oily film on the coach or trailer. I installed a > > Racor and am very happy with it's performance. > > > > Kurt Horvath > > 95 PT 42 > > 10AC > > > > > > --- In WanderlodgeForum@yahoogroups.com, Al Scudder > > wrote: > > > > > > > > > Coming from the Boating world every 6v92 and 8v92 applications > > needed Pampers under the engine bays, and for long runs you needed > to > > wipedown the engine room, but they always kept going.Scooter 2000LX > > Ocqueoc, MI > > > > > > To: WanderlodgeForum@: jburgessx2@: Mon, 16 Feb 2009 17:59:23 > > +0000Subject: [WanderlodgeForum] Re: 6V92 Detroit > > > > > > > > > > > > Pete,No oil-related crashes behind me yet - must mean I'm good to > > go. I noticed the motor discharged about a 5" circle of oil after I > > parked it after an 1800 mile run (1800 miles in 36 hours). I > checked > > the oil level and only added about 1 quart (or so) after 1800 > miles. > > I'm guessing that's not too bad for oil consumption. I think this > > motor had an in-frame rebuild about 56k miles ago. So, wanted to > make > > sure it wasn't doing something out of the ordinary. I can't imagine > > the engine going bad already unless it was abused by the > > PO.Thanks.Jerry 85 PT40Port Hueneme, CA--- In > > WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote:>> > > Those are commonly called "the slobber tubes" and, yes, they > normally > > > discharge oil-looking stuff (which is primarily oil).> > If the > > cars following behind you on the highway are sliding off into a > > > ditch, that's too much.> > Pete Masterson> '95 Blue Bird > Wanderlodge > > WBDA 42 (For Sale)> <http://www.aeonix.biz/BBforsale.html>> El > > Sobrante CA> aeonix1@> > > > > On Feb 16, 2009, at 8:14 AM, > > jburgessx2 wrote:> > > I'm new to these Detroit engines. I noticed > > the 6v92 has two hoses> > that hang from the bottom and > occasionally > > discharge what appears to > > be> > some oil. Are these supposed to > > do that? If so, how much is too > > much?> >> > Jerry> > 85 PT40> > > > Port Hueneme, CA> > > > > > > |
02-18-2009, 13:59
6V92 Detroit
probably ok to use aftermarket systems just a good idea to look at
the possible failures. things like crank case vents blowing 100% verticle is to keep the wet stuff from settling on the bends and walls and scumming up the vent. the other engineering design is to route it past the exhaust to help vapor off the condensation and keep the oil in the tube hot and flowing. when you change the dynamics I always wonder what engineered calc you stand in the way of. boats vent most everything out the exhaust because the compartment is closed special attention is adressed to gas engines. If there is a issue you would be the one who could build scenario case to prove correctness. Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" wrote: > > > > Well Gregg you got me curious. I looked at the web site you posted. > > Why isn't it a good idea to use a CCV on a 2 stroke? > > When I researched this system all the inf. I found for it was on the > boat sites, As I recall most of them had some sort of system to keep > the oily mist off of and out of the enclosed engine compartments. > > I don't recall any reference to this being detrimental to any engine > type. > > Either way a catch can keeps the oil from dripping on the ground,, > the CCV recycles the gasses from the slobber tube back into the fresh > air flow to be burnt again and keeps oil from dripping on the ground. > > The mfg.'s offered systems for all engine types and manufacturers -- - > > So what up??? > > Kurt Horvath > 95 PT 42 > 10AC > > > > > In WanderlodgeForum@yahoogroups.com, "timvasqz" > > > > the drip from the slobbertubes is a function of scaveging and > > necessary with the two stroke jimmies. There was a time when some > > would direct the discharge back to the sump. All the aftermarket > > engineering has down sides. > > > > The s60 is four stroke and has a way different setup. If slobber > > bothers, you dont sleep sitting up and get a four stroke. > > > > Here is an article on the diffs between 2 and four strokes some > times > > refered to as two cycle and four cycle. "blower" and "turbo" are > also > > two terms confused which differ. > > > > http://www.yachtsurvey.com/comparing_diesel_types.htm > > > > Greg ofTim&Greg > > 94ptca > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > wrote: > > > > > > > > > Scooter, > > > > > > If it becomes bothersome you can install a trap or a CCV ( Closed > > > Crankcase Ventilation System ) > > > Racor makes one as well as Walker . They are used quite a bit on > > > boats. > > > I didn't like the oily film on the coach or trailer. I installed > a > > > Racor and am very happy with it's performance. > > > > > > Kurt Horvath > > > 95 PT 42 > > > 10AC > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Al Scudder > > > wrote: > > > > > > > > > > > > Coming from the Boating world every 6v92 and 8v92 applications > > > needed Pampers under the engine bays, and for long runs you > needed > > to > > > wipedown the engine room, but they always kept going.Scooter > 2000LX > > > Ocqueoc, MI > > > > > > > > To: WanderlodgeForum@: jburgessx2@: Mon, 16 Feb 2009 17:59:23 > > > +0000Subject: [WanderlodgeForum] Re: 6V92 Detroit > > > > > > > > > > > > > > > > Pete,No oil-related crashes behind me yet - must mean I'm good > to > > > go. I noticed the motor discharged about a 5" circle of oil after > I > > > parked it after an 1800 mile run (1800 miles in 36 hours). I > > checked > > > the oil level and only added about 1 quart (or so) after 1800 > > miles. > > > I'm guessing that's not too bad for oil consumption. I think this > > > motor had an in-frame rebuild about 56k miles ago. So, wanted to > > make > > > sure it wasn't doing something out of the ordinary. I can't > imagine > > > the engine going bad already unless it was abused by the > > > PO.Thanks.Jerry 85 PT40Port Hueneme, CA--- In > > > WanderlodgeForum@yahoogroups.com, Pete Masterson > > wrote:>> > > > Those are commonly called "the slobber tubes" and, yes, they > > normally > > > > discharge oil-looking stuff (which is primarily oil).> > If the > > > cars following behind you on the highway are sliding off into a > > > > ditch, that's too much.> > Pete Masterson> '95 Blue Bird > > Wanderlodge > > > WBDA 42 (For Sale)> <http://www.aeonix.biz/BBforsale.html>> El > > > Sobrante CA> aeonix1@> > > > > On Feb 16, 2009, at 8:14 AM, > > > jburgessx2 wrote:> > > I'm new to these Detroit engines. I > noticed > > > the 6v92 has two hoses> > that hang from the bottom and > > occasionally > > > discharge what appears to > > be> > some oil. Are these supposed > to > > > do that? If so, how much is too > > much?> >> > Jerry> > 85 PT40> > > > > > Port Hueneme, CA> > > > > > > > > > > |
