FC Air System- info needed
03-14-2009, 10:12
After a long hiatus, I am fooling with the air system on my 1980 FC33.
First- I have the diagram #0988733 with diagrams. Everything is numbered rather than labeled and I do not have the key. Anyone got a copy they could send? Second- There is a gray air valve of some sort behind the driver's side bumper outboard of the frame that has a bunch of hoses and one of the outlets Bottom passenger's side) has the hose missing off it. Leaks at a pretty good clip. No nearby homeless hose in evidence. What's this valve? Any idea where that missing hose is supposed to go? Third- The suspension dump valve does not seem to work as far as I can tell. Light does not go on either. How fast is the dump supposed to happen? Any common/easy things to check? Fourth- The air cylinder to the generator slide is absent. There is a crimped air hose but I do not see a bracket or anything else. Any good place to get parts or an alternative (eg electric) arrangement? Anyone got a picture of the factory layout? Thanks. John Churchill LARGE MARGE 1980 FC 33 Sanibel FL |
03-14-2009, 14:00
I can answer two questions....
The "missing hose" behind the bumper is normal, the "leaking" air creates vacuum for the cruise control. This valve has a proper name, but I can't remember it. If your cruise doesn't work (as it didn't on my old FC), you can cap that "leak" if it makes you feel better (I did). The suspension should dump fully in 20-30 seconds. The valve is electric over air, it could be as simple as a loose wire. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Robin" > > After a long hiatus, I am fooling with the air system on my 1980 FC33. > > First- I have the diagram #0988733 with diagrams. Everything is numbered rather than labeled and I do not have the key. Anyone got a copy they could send? > > Second- There is a gray air valve of some sort behind the driver's side bumper outboard of the frame that has a bunch of hoses and one of the outlets Bottom passenger's side) has the hose missing off it. Leaks at a pretty good clip. No nearby homeless hose in evidence. What's this valve? Any idea where that missing hose is supposed to go? > > Third- The suspension dump valve does not seem to work as far as I can tell. Light does not go on either. How fast is the dump supposed to happen? Any common/easy things to check? > > Fourth- The air cylinder to the generator slide is absent. There is a crimped air hose but I do not see a bracket or anything else. Any good place to get parts or an alternative (eg electric) arrangement? Anyone got a picture of the factory layout? Thanks. > > John Churchill > LARGE MARGE > 1980 FC 33 > Sanibel FL > |
03-15-2009, 03:14
03-15-2009, 07:25
--- In WanderlodgeForum@yahoogroups.com, david edwards
wrote: > > The thing behind the bumper is called a vacuum generator. If it is 'leaking' all the time, it means it is making vacuum all the time which means there is a vacuum leak in the lines that control your cruise control or the little diaphragm that is supposed to shut off the generator once the vacuum has reached a usable level has failed. There are no replacements for the vacuum generator so once that system fails, your only option is an electric cruise control or rigging up an alternative vacuum generator. I went with the electric version. > I would look closely for vacuum leaks in your system. It could be as simple as a disconnected vacuum line. > > Kerry > 82 FC 35 > Denver > David does the vacuum generator run anything else or can it be removed when you install an electric cruise control. this is where iam at and was just wondering. thanks ed mcstay 83fc 35ft RB "lonesome dove" |
03-16-2009, 01:55
03-16-2009, 02:01
you can still buy vacuum generators maybe not in the same style
stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > I can answer two questions.... > > The "missing hose" behind the bumper is normal, the "leaking" air creates vacuum for the cruise control. This valve has a proper name, but I can't remember it. If your cruise doesn't work (as it didn't on my old FC), you can cap that "leak" if it makes you feel better (I did). > > The suspension should dump fully in 20-30 seconds. The valve is electric over air, it could be as simple as a loose wire. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Robin" > > > > After a long hiatus, I am fooling with the air system on my 1980 FC33. > > > > First- I have the diagram #0988733 with diagrams. Everything is numbered rather than labeled and I do not have the key. Anyone got a copy they could send? > > > > Second- There is a gray air valve of some sort behind the driver's side bumper outboard of the frame that has a bunch of hoses and one of the outlets Bottom passenger's side) has the hose missing off it. Leaks at a pretty good clip. No nearby homeless hose in evidence. What's this valve? Any idea where that missing hose is supposed to go? > > > > Third- The suspension dump valve does not seem to work as far as I can tell. Light does not go on either. How fast is the dump supposed to happen? Any common/easy things to check? > > > > Fourth- The air cylinder to the generator slide is absent. There is a crimped air hose but I do not see a bracket or anything else. Any good place to get parts or an alternative (eg electric) arrangement? Anyone got a picture of the factory layout? Thanks. > > > > John Churchill > > LARGE MARGE > > 1980 FC 33 > > Sanibel FL > > > |
03-17-2009, 02:00
03-17-2009, 11:05
Who makes an electric cruise control? Mine went out 4 years ago. How much
work is there to install? Chuck 81SBFC Florida > When my vacuum generator failed I did buy a couple of vacuum generators > which I had planned to use to replace the original. My memory is that I > chose not to use them because none of them had the built in shut off > diaphragm like the Wanderlodge original. All the ones I could find would > have been running constantly whereas the OE shut off when the appropriate > vacuum level was reached. The OE was a part used on old Ford trucks as I > recall. Perhaps an old Ford truck forum might have info on a suitable > replacement. I looked for a long time for a vacuum generator with a built > in shut off valve and couldn't find one. I'm sure that someone with the > skills of a Cuban mechanic could adapt some kind of generator to work. I > concluded an electric cruise control was a better option > > Kerry > 82 FC 35 > Denver > > > > > |
03-17-2009, 11:47
--- In WanderlodgeForum@yahoogroups.com, cfsomers@... wrote:
> > Who makes an electric cruise control? Mine went out 4 years ago. How much > work is there to install? > > Chuck > > 81SBFC > Florida > > > When my vacuum generator failed I did buy a couple of vacuum generators > > which I had planned to use to replace the original. My memory is that I > > chose not to use them because none of them had the built in shut off > > diaphragm like the Wanderlodge original. All the ones I could find would > > have been running constantly whereas the OE shut off when the appropriate > > vacuum level was reached. The OE was a part used on old Ford trucks as I > > recall. Perhaps an old Ford truck forum might have info on a suitable > > replacement. I looked for a long time for a vacuum generator with a built > > in shut off valve and couldn't find one. I'm sure that someone with the > > skills of a Cuban mechanic could adapt some kind of generator to work. I > > concluded an electric cruise control was a better option > > > > Kerry > > 82 FC 35 > > Denver Kerry did you ever get your cruse control to work? I just took mine apart and cleaned up the internals and now it works perfect. But I don't think mine has any vacumm censor device that will turn it oft and on at a certain vacumm pressure. If there is such a device I have never seen it on my coach. Jon Rebel Bird Bremerton washington > > > > > > > > > > > |
03-17-2009, 12:00
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > > > --- In WanderlodgeForum@yahoogroups.com, cfsomers@ wrote: > > > > Who makes an electric cruise control? Mine went out 4 years ago. How > much > > work is there to install? > > > > Chuck > > > > 81SBFC > > Florida > > > > > When my vacuum generator failed I did buy a couple of vacuum > generators > > > which I had planned to use to replace the original. My memory is > that I > > > chose not to use them because none of them had the built in shut off > > > diaphragm like the Wanderlodge original. All the ones I could find > would > > > have been running constantly whereas the OE shut off when the > appropriate > > > vacuum level was reached. The OE was a part used on old Ford trucks > as I > > > recall. Perhaps an old Ford truck forum might have info on a > suitable > > > replacement. I looked for a long time for a vacuum generator with a > built > > > in shut off valve and couldn't find one. I'm sure that someone with > the > > > skills of a Cuban mechanic could adapt some kind of generator to > work. I > > > concluded an electric cruise control was a better option > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > Kerry did you ever get your cruse control to work? I just took mine > apart and cleaned up the internals and now it works perfect. But I > don't think mine has any vacumm censor device that will turn it oft and > on at a certain vacumm pressure. If there is such a device I have > never seen it on my coach. > > > > Jon > > Rebel Bird > > Bremerton washington JON- Did you just do your vac generator or did you do the whole cruise mechanism. Mine does not work either. Mechanic said it was not worth fooling with (probably true at his rate). I need another project to put on the list. John Churchill 1980 FC33 LARGE MARGE Sanibel, FL |
