plastic roof strips
03-20-2009, 14:30
plastic roof strips
03-21-2009, 02:44
plastic roof strips
Steve:
I need a set in Oklahoma as well, when they are made available. I only have 2 strips left. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma At 10:14 PM 3/20/2009 +0000, you wrote: >They are an extruded plastic piece it is not possible to vary the width >without building another mold and that is unlikely to happen. >The strips will be 90 inches long and will ship 10 in a tube >Right now if it does not change they will be priced at 90.00 for ten >larger quantities will be priced lower that will be set later > >Stephen 77fc35 >dupreeproducts.com > > > >--- In WanderlodgeForum@yahoogroups.com, david edwards > > > > > Is it possible to get the plastic roof strips in slightly wider > versions? Some of mine don't quite cover the edge of the ceiling panels. > > > > Kerry > > 82 FC 35 > > Denver > > > > > |
03-21-2009, 03:18
plastic roof strips
Hi Stephen, Please add me to your list for 10 of the strips too. Thanks, Terry Neal Bozeman, MT 82PT40 74FC34 On 3/20/2009 4:14 PM, Stephen Birtles wrote:
03-21-2009, 04:34
plastic roof strips
Are these the same strips used on the inside of an 85 PT40 to hold the
ceiling/wall cover in place? Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Steven...$90.00 for ten is a good buy. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > *Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > On Fri, Mar 20, 2009 at 3:14 PM, Stephen Birtles > > > They are an extruded plastic piece it is not possible to vary the width > > without building another mold and that is unlikely to happen. > > The strips will be 90 inches long and will ship 10 in a tube > > Right now if it does not change they will be priced at 90.00 for ten larger > > quantities will be priced lower that will be set later > > > > Stephen 77fc35 > > dupreeproducts.com > > > > --- In WanderlodgeForum@yahoogroups.com > > david edwards > > > > > > Is it possible to get the plastic roof strips in slightly wider > > versions? Some of mine don't quite cover the edge of the ceiling panels. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > > > > > |
03-21-2009, 04:49
plastic roof strips
these strips till 1989 on all narrow body coaches
Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" > > Are these the same strips used on the inside of an 85 PT40 to hold the ceiling/wall cover in place? > > Jerry > 85 PT40 > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > Steven...$90.00 for ten is a good buy. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > *Read all about Southwest Bluebirds and Friends (SWBB) at > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > > > > > > On Fri, Mar 20, 2009 at 3:14 PM, Stephen Birtles > > > > > They are an extruded plastic piece it is not possible to vary the width > > > without building another mold and that is unlikely to happen. > > > The strips will be 90 inches long and will ship 10 in a tube > > > Right now if it does not change they will be priced at 90.00 for ten larger > > > quantities will be priced lower that will be set later > > > > > > Stephen 77fc35 > > > dupreeproducts.com > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > david edwards > > > > > > > > Is it possible to get the plastic roof strips in slightly wider > > > versions? Some of mine don't quite cover the edge of the ceiling panels. > > > > > > > > Kerry > > > > 82 FC 35 > > > > Denver > > > > > > > > > > > > > > > > |
03-21-2009, 04:54
plastic roof strips
Stephen,
So that's a "yes' to the 85 PT40 question? I guess I don't know the difference between a narrow body and a wide body - I'm new to the BB. Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > these strips till 1989 on all narrow body coaches > Stephen 77fc35 > dupreeproducts.com > > > --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" > > > > Are these the same strips used on the inside of an 85 PT40 to hold the ceiling/wall cover in place? > > > > Jerry > > 85 PT40 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > > > > > > Steven...$90.00 for ten is a good buy. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > *Read all about Southwest Bluebirds and Friends (SWBB) at > > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > > > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > > > > > > > > > > > On Fri, Mar 20, 2009 at 3:14 PM, Stephen Birtles > > > > > > > They are an extruded plastic piece it is not possible to vary the width > > > > without building another mold and that is unlikely to happen. > > > > The strips will be 90 inches long and will ship 10 in a tube > > > > Right now if it does not change they will be priced at 90.00 for ten larger > > > > quantities will be priced lower that will be set later > > > > > > > > Stephen 77fc35 > > > > dupreeproducts.com > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > david edwards > > > > > > > > > > Is it possible to get the plastic roof strips in slightly wider > > > > versions? Some of mine don't quite cover the edge of the ceiling panels. > > > > > > > > > > Kerry > > > > > 82 FC 35 > > > > > Denver > > > > > > > > > > > > > > > > > > > > > > > |
03-21-2009, 05:12
plastic roof strips
Narrow bodies are 8 feet wide, wide bodies are 8-1/2 feet. According to the
history at Vintage birds, WB were introduced in 1988, and both were made in 88 and 89, with narrow discontinued after that. On 3/21/2009 at 3:54 PM jburgessx2 wrote: >Stephen, > >So that's a "yes' to the 85 PT40 question? I guess I don't know the >difference between a narrow body and a wide body - I'm new to the BB. > >Jerry >85 PT40 > >--- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" >wrote: >> >> these strips till 1989 on all narrow body coaches >> Stephen 77fc35 >> dupreeproducts.com >> >> >> --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" >wrote: >> > >> > Are these the same strips used on the inside of an 85 PT40 to hold the >ceiling/wall cover in place? >> > >> > Jerry >> > 85 PT40 >> > >> > >> > >> > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger >wrote: >> > > >> > > Steven...$90.00 for ten is a good buy. >> > > >> > > Curt Sprenger >> > > 1987 PT38 8V92 "MacAttack Racing" >> > > Anaheim Hills, CA >> > > *Read all about Southwest Bluebirds and Friends (SWBB) at >> > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. >> > > "Host of the Annual Bluebird Quartzsite Rally" * >> > > >> > > >> > > >> > > >> > > On Fri, Mar 20, 2009 at 3:14 PM, Stephen Birtles >> > > >> > > > They are an extruded plastic piece it is not possible to vary >the width >> > > > without building another mold and that is unlikely to happen. >> > > > The strips will be 90 inches long and will ship 10 in a tube >> > > > Right now if it does not change they will be priced at 90.00 for >ten larger >> > > > quantities will be priced lower that will be set later >> > > > >> > > > Stephen 77fc35 >> > > > dupreeproducts.com >> > > > >> > > > --- In >WanderlodgeForum@yahoogroups.com >> > > > david edwards >> > > > > >> > > > > Is it possible to get the plastic roof strips in slightly wider >> > > > versions? Some of mine don't quite cover the edge of the ceiling >panels. >> > > > > >> > > > > Kerry >> > > > > 82 FC 35 >> > > > > Denver >> > > > > >> > > > >> > > > >> > > > >> > > >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
03-23-2009, 06:25
plastic roof strips
Stephen, I would like a set of strips for Dan Williams 81RB33 Jackson MS From: Is there any call for the plastic roof strips found on older fcs and narrow body pts up to 1989 model year these strips hold the roof and wall panels in place They will be produced by the same company that made them for Wanderlodge there has to be significant interest because there is a large investment to be made Stephen 77fc35 dupreeproducts. |
03-23-2009, 09:23
plastic roof strips
We are working on ceiling and wall panels BUT there were at least three
different styles we will have only one stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "Dan Williams" > > Stephen, I would like a set of strips for my 81 and do you have any of the > ceiling panels? > > Dan Williams 81RB33 Jackson MS > > > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Stephen Birtles > Sent: Friday, March 20, 2009 9:35 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] plastic roof strips > > > > Is there any call for the plastic roof strips found on older fcs and narrow > body pts up to 1989 model year > these strips hold the roof and wall panels in place They will be produced by > the same company that made them for Wanderlodge > there has to be significant interest because there is a large investment to > be made > > Stephen 77fc35 > dupreeproducts.com > |
03-23-2009, 13:33
plastic roof strips
> > We are working on ceiling and wall panels BUT there were at least three different styles we will have only one > > stephen 77fc35 > dupreeproducts.com Stephen- My vote is for the panels that match my coach. First dibs carries the day. ![]() John Churchill 1980 FC33 LARGE MARGE |
