Electrical problem - where to start?
04-03-2009, 15:33
Hi Everyone,
I have an electrical problem and I'm not sure where to begin. It seems my Bird
will give you a small "shock" whenever you touch the outside of the bus (not
wearing shoes of course). So if you are barefoot and try to open the doors,
zap!. Needless to say the wife and kids do not care for this feature.
It's obvious I have a short somewhere, I'm just not sure where to start. I
haven't made any electrical changes. Any suggestions on where to start? I have
a EE background so I know a little about this area, just not sure how best to
tackle this one.
Thanks!
Wayne
1985 PT-40
04-03-2009, 15:42
Wayne, your skin is "hot" withd 120v ac and you should disconnect immediately
until you find the problem.
Bruce Morris
Webmaster Wanderlodge Owners Online
83 FC35
--- In WanderlodgeForum@yahoogroups.com, "curlesw" wrote:
> Hi Everyone,
Bird will give you a small "shock" whenever you touch the outside of the bus
(not wearing shoes of course). So if you are barefoot and try to open the
doors, zap!. Needless to say the wife and kids do not care for this feature.
tackle this one.
> Thanks!
> Wayne
> 1985 PT-40
04-03-2009, 15:47
Drive a 2 foot copper ground rod (steel rod will work too) into the
ground...wet the area good...then us a meter to measure from the ground
rod and the coach body. If it is dry where you are, you may be
experiencing static electricity.
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
On Fri, Apr 3, 2009 at 8:33 PM, curlesw <"curlesw@yahoo.com"> wrote:
Hi Everyone,
I have an electrical problem and I'm not sure where to begin. It seems my Bird will give you a small "shock" whenever you touch the outside of the bus (not wearing shoes of course). So if you are barefoot and try to open the doors, zap!. Needless to say the wife and kids do not care for this feature.
It's obvious I have a short somewhere, I'm just not sure where to start. I haven't made any electrical changes. Any suggestions on where to start? I have a EE background so I know a little about this area, just not sure how best to tackle this one.
Thanks!
Wayne
1985 PT-40
04-03-2009, 17:51
Wayne, A buddy of mine had the same problem with a Eagle bus conversion that he owned. It turned out that he had a bad ground at his batteries. Hope this helps, and is your problem, because it is a cheap and simple fix. Good Luck, George Burke 1977 FC31 FCharlotte
On Fri, Apr 3, 2009 at 11:33 PM, curlesw <"curlesw@yahoo.com"> wrote:
Hi Everyone,
Thanks!
Wayne
1985 PT-40
04-04-2009, 00:02
I had a similar problem on a 35FC the problem was a 110V cord was caught under a swivel chair and the insulation had worn thru enough to cause a slight short, If you can feel it you have got a AC short some where, first check with a good voltmeter, then try turning off theAC breakers to locate which circuit is the problem. Good luck,
Ron Roberts
95PT40WB
In a message dated 4/4/2009 8:50:24 A.M. Eastern Daylight Time, bamnc@... writes:
Wayne, your skin is "hot" withd 120v ac and you should disconnect immediately until you find the problem.
Bruce Morris
83 FC35
--- In "WanderlodgeForum%40yahoogroups.com", "curlesw" > wrote:
> Hi Everyone,
> Thanks!
> Wayne
> 1985 PT-40
Worried about job security? Check out the 5 safest jobs in a recession.
04-04-2009, 01:32
Wayne- there was a write up from ralph about the hots skin test. You can do a
search about that and when you come to message # 37132 that is the section that
talks about it. I suspect your plug at either the house end or the coach end has
a wire that has come loose. Ernie Ekberg, 83PT40 in Texas
> Hi Everyone,
tackle this one.
> Thanks!
> Wayne
> 1985 PT-40
04-04-2009, 03:19
Wayne,
+1 on what Ernie said. You need to check that out ASAP. The common wire had
come loose in the coach plug on my Bird and every now and then that same thing
happened. I would check both plug ends for tight wire connections first. If
not that, then on to Ralph's tutorial.....
1991 WB40 "Texas Minivan" - not so shocking now!
> > Hi Everyone,
tackle this one.
> > Thanks!
> > Wayne
> > 1985 PT-40
04-04-2009, 09:05
Thanks all, will take a look at the article.
Also, forgot to mention, this happens only when the DC is connect, AC is not
turned on (i.e. plugged in or generator on)...not sure if that make a
difference.
Will read up on things and report back.
Wayne C.
85 PT-40
> a good voltmeter, then try turning off the AC breakers to locate which
> Ron Roberts
> 95PT40WB
> bamnc@... writes:
> Bruce Morris
> 83 FC35
> --- In _WanderlodgeForum@WanderlodgeFWan_
> (mailto:WanderlodgeForum@yahoogroups.com) , "curlesw" wrote:
> > Hi Everyone,
best
> to tackle this one.
> > Thanks!
> > Wayne
> > 1985 PT-40
> **************Worried about job security? Check out the 5 safest jobs in a
> recession.
> (http://jobs.aol.com/gallery/growing-job-...re00000003)
04-04-2009, 09:42
That makes a lot of sense. Start with the power cord between the coach and the
pedestal. I'll bet you find a loose ground.
Marv
2004 M380
Ocean Shores, WA
difference.
> Wayne C.
> 85 PT-40
slight
with
> > Ron Roberts
> > 95PT40WB
> > bamnc@ writes:
> > Bruce Morris
> > 83 FC35
> > > Hi Everyone,
bus
feature.
I
best
> > to tackle this one.
> > > Thanks!
> > > Wayne
> > > 1985 PT-40
> > recession.
04-04-2009, 17:25
get rid of the nylon rugs or polyester sheets??? DC electric in a wanderlodge
has many inverters built in where the current can be more than 12 volt. there
could be an inverter for one of the flourecent lights or el dash or a start
compasitor some place. maybe the flourcent inverters are one of the phantom
draws often spoken about????
Greg of Tim&Greg
difference.
> Wayne C.
> 85 PT-40
slight
with
> > Ron Roberts
> > 95PT40WB
> > bamnc@ writes:
> > Bruce Morris
> > 83 FC35
> > > Hi Everyone,
bus
feature.
I
best
> > to tackle this one.
> > > Thanks!
> > > Wayne
> > > 1985 PT-40
> > recession.
