Air Bags (Springs) & Radiator order numbers
04-03-2009, 23:29
Hi,
These are the order numbers my research uncovered. Order numbers for Air Bags and a Radiator for our 93' WL Detroit Diesel TAC DDECII 500 HP. Air Springs 1286814 front 0961250 rear 0990671 tag Radaitor G & O #x-3190-11996 We need to replace the above. Correct numbers ? Thank You for any comments or suggestions, Gene Sharp 93' WL 40' Belle Center, Ohio |
04-04-2009, 01:08
04-06-2009, 23:43
Leroy,
Did they use all the same size air bags for all axles ? Do you have the radaitor order number ? Sorry to keep asking the same questions. Thanks for Your Help, Gene Sharp 93' WL 40' Ohio --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Those air bag numbers are BB numbers which you will need to cross. I think they are the same as mine. Ridewell Models RAS227 and RAD227. I thought I had the cross for all of them but so far follows what I have. > Steer Axel- > BB 1286814 > Firestone-W01-358-9457 > Goodyear 1R11-151 > Ridewell-1003589457C > > I know I have the others somewhere. I will keep looking. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > > > --- On Sat, 4/4/09, Gene Sharp > > From: Gene Sharp > Subject: [WanderlodgeForum] Air Bags (Springs) & Radiator order numbers > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, April 4, 2009, 7:29 AM > > > > > > > > > > > > > > > Hi, > > > > > > These are the order numbers my research uncovered. > > Order numbers for Air Bags and a Radiator for our 93' WL > > Detroit Diesel TAC DDECII 500 HP. > > > > Air Springs > > 1286814 front > > 0961250 rear > > 0990671 tag > > > > Radaitor > > G & O #x-3190-11996 > > > > We need to replace the above. Correct numbers ? > > Thank You for any comments or suggestions, > > > > Gene Sharp > > 93' WL 40' > > Belle Center, Ohio > |
04-07-2009, 00:12
04-07-2009, 00:48
04-08-2009, 00:28
Hi Again,
Forgot to ask for a good place to purchase the air bags (springs). No more questions. My mind only works on one thing at a time. Thanks, Gene Sharp 93' WL 40' Ohio --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Here is a Firestone number for the Tag-W013589073. > When it quits snowing I will go out to the bus and looks at my spares and see who made them and their part numbers. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Tue, 4/7/09, Leroy Eckert > > From: Leroy Eckert > Subject: Re: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, April 7, 2009, 8:12 AM > > > > > > > > > > > > > There are three different air bags/springs. The BB numbers you have are correct per my records. Follows are Ridewell numbers which I have. I still cannot find the cross for these two in my files. > Tag-BB number-0990671, 4 each >      Ridewell-100- 358-9073C > > Drive-BB number-0961250- 4each >        Ridewell-100- 358-9039C >        http://www.ridewellcorp. com- Look under air spring part, by part number. > > If I ever find the cross reference in my files, I think I will summarize and post them in the parts section of the forum. > > I show the same radiator manufacturer and number. I would suggest you have a radiator shop go through yours and make it good as new. It will be a lot less expensive. > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, > GA > > > > --- On Tue, 4/7/09, Gene Sharp > > From: Gene Sharp > Subject: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers > To: WanderlodgeForum@ yahoogroups. com > Date: Tuesday, April 7, 2009, 7:43 AM > > > > > > > > > > Leroy, > > Did they use all the same size air bags for all axles ? > > Do you have the radaitor order number ? > > Sorry to keep asking the same questions. > > Thanks for Your Help, > > Gene Sharp > > 93' WL 40' > > Ohio > > > > --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert wrote: > > > > > > Those air bag numbers are BB numbers which you will need to cross. I think they are the same as mine. Ridewell Models RAS227 and RAD227. I thought I had the cross for all of them but so far follows what I have. > > > Steer Axel- > > > BB 1286814 > > > Firestone-W01- 358-9457 > > > Goodyear 1R11-151 > > > Ridewell-1003589457 C > > > > > > I know I have the others somewhere. I will keep looking. > > > Leroy Eckert > > > 1990 WB-40 Smoke N Mirrors > > > Dahlonega, GA > > > > > > > > > > > > --- On Sat, 4/4/09, Gene Sharp > > > > > > From: Gene Sharp > > > Subject: [WanderlodgeForum] Air Bags (Springs) & Radiator order numbers > > > To: WanderlodgeForum@ yahoogroups. com > > > Date: Saturday, April 4, 2009, 7:29 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Hi, > > > > > > > > > > > > > > > > > > These are the order numbers my research uncovered. > > > > > > Order numbers for Air Bags and a Radiator for our 93' WL > > > > > > Detroit Diesel TAC DDECII 500 HP. > > > > > > > > > > > > Air Springs > > > > > > 1286814 front > > > > > > 0961250 rear > > > > > > 0990671 tag > > > > > > > > > > > > Radaitor > > > > > > G & O #x-3190-11996 > > > > > > > > > > > > We need to replace the above. Correct numbers ? > > > > > > Thank You for any comments or suggestions, > > > > > > > > > > > > Gene Sharp > > > > > > 93' WL 40' > > > > > > Belle Center, Ohio > > > > |
04-08-2009, 00:41
04-08-2009, 01:05
Thank You - Thank You for your help !
Gene Sharp 93' WL 40' Oh --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Try your local fleet maintenance yard. Or if you can order on line. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Wed, 4/8/09, Gene Sharp > > From: Gene Sharp > Subject: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers > To: WanderlodgeForum@yahoogroups.com > Date: Wednesday, April 8, 2009, 8:28 AM > > > > > > > > > > > > > Hi Again, > > Forgot to ask for a good place to purchase the air bags (springs). No more questions. > > My mind only works on one thing at a time. > > Thanks, > > Gene Sharp > > 93' WL 40' Ohio > > > > --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert wrote: > > > > > > Here is a Firestone number for the Tag-W013589073. > > > When it quits snowing I will go out to the bus and looks at my spares and see who made them and their part numbers. > > > Leroy Eckert > > > 1990 WB-40 Smoke N Mirrors > > > Dahlonega, GA > > > Royale Conversion > > > > > > --- On Tue, 4/7/09, Leroy Eckert > > > > > > From: Leroy Eckert > > > Subject: Re: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers > > > To: WanderlodgeForum@ yahoogroups. com > > > Date: Tuesday, April 7, 2009, 8:12 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > There are three different air bags/springs. The BB numbers you have are correct per my records. Follows are Ridewell numbers which I have. I still cannot find the cross for these two in my files. > > > Tag-BB number-0990671, 4 each > > >      Ridewell-100- 358-9073C > > > > > > Drive-BB number-0961250- 4each > > >        Ridewell-100- 358-9039C > > >        http://www.ridewellcorp. com- Look under air spring part, by part number. > > > > > > If I ever find the cross reference in my files, I think I will summarize and post them in the parts section of the forum. > > > > > > I show the same radiator manufacturer and number. I would suggest you have a radiator shop go through yours and make it good as new. It will be a lot less expensive. > > > > > > Leroy Eckert > > > 1990 WB-40 Smoke N Mirrors > > > Dahlonega, > > > GA > > > > > > > > > > > > --- On Tue, 4/7/09, Gene Sharp > > > > > > From: Gene Sharp > > > Subject: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers > > > To: WanderlodgeForum@ yahoogroups. com > > > Date: Tuesday, April 7, 2009, 7:43 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Leroy, > > > > > > Did they use all the same size air bags for all axles ? > > > > > > Do you have the radaitor order number ? > > > > > > Sorry to keep asking the same questions. > > > > > > Thanks for Your Help, > > > > > > Gene Sharp > > > > > > 93' WL 40' > > > > > > Ohio > > > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert wrote: > > > > > > > > > > > > > > Those air bag numbers are BB numbers which you will need to cross. I think they are the same as mine. Ridewell Models RAS227 and RAD227. I thought I had the cross for all of them but so far follows what I have. > > > > > > > Steer Axel- > > > > > > > BB 1286814 > > > > > > > Firestone-W01- 358-9457 > > > > > > > Goodyear 1R11-151 > > > > > > > Ridewell-1003589457 C > > > > > > > > > > > > > > I know I have the others somewhere. I will keep looking. > > > > > > > Leroy Eckert > > > > > > > 1990 WB-40 Smoke N Mirrors > > > > > > > Dahlonega, GA > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- On Sat, 4/4/09, Gene Sharp > > > > > > > > > > > > > > From: Gene Sharp > > > > > > > Subject: [WanderlodgeForum] Air Bags (Springs) & Radiator order numbers > > > > > > > To: WanderlodgeForum@ yahoogroups. com > > > > > > > Date: Saturday, April 4, 2009, 7:29 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Hi, > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > These are the order numbers my research uncovered. > > > > > > > > > > > > > > Order numbers for Air Bags and a Radiator for our 93' WL > > > > > > > > > > > > > > Detroit Diesel TAC DDECII 500 HP. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Air Springs > > > > > > > > > > > > > > 1286814 front > > > > > > > > > > > > > > 0961250 rear > > > > > > > > > > > > > > 0990671 tag > > > > > > > > > > > > > > > > > > > > > > > > > > > > Radaitor > > > > > > > > > > > > > > G & O #x-3190-11996 > > > > > > > > > > > > > > > > > > > > > > > > > > > > We need to replace the above. Correct numbers ? > > > > > > > > > > > > > > Thank You for any comments or suggestions, > > > > > > > > > > > > > > > > > > > > > > > > > > > > Gene Sharp > > > > > > > > > > > > > > 93' WL 40' > > > > > > > > > > > > > > Belle Center, Ohio > > > > > > > > > > > |
04-08-2009, 10:15
You can search online. I let the guy who replaced them order them. A word of caution that bus is big and heavy. While they were repairingy bags the bus came down on the guy who was working on it he was not to badly hurt. We have had members killed under a wanderlodge !! Thanks Jim Riordan
On Apr 8, 2009, at 8:28, "Gene Sharp" <"jks_les@yahoo.com"> wrote:
