Cannon plugs
04-11-2009, 13:02
Cannon plugs
Hi Guys
I have a cannon plug with a bad wire in it. It is on the female side. Can you buy them or would it be better to bypass the wire around the plug. If you can buy them. Is there a good source.This plug has my parking lights & my 12 volt inside. Don Spithaler 89 SP 36' Butler, PA |
04-11-2009, 14:12
Cannon plugs
I'd bypass the plug.ÃÂ
Curt Sprenger On Sat, Apr 11, 2009 at 6:02 PM, Don Spithaler <"dspithaler@gmail.com"> wrote:
04-11-2009, 15:08
Cannon plugs
Curt   Do you know what makes one wire go bad in a plug of 24 wires?  Â
Don Spithaler 89 SP 36' Butler, PA On Sat, Apr 11, 2009 at 10:12 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
04-11-2009, 15:51
Cannon plugs
Heat, vibration, moisture, connect/disconnect, wire end(s)/connectors not the best at initial assemble, bad grounds, stress on the wire bundle or a wire in the bundle, etc., all leading to arching, deterioration and eventually no connection.
Just rewire the one bad wire outside the plugs.ÃÂ Good luck. Curt Sprenger Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. "Host of the Annual Bluebird Quartzsite Rally" On Sat, Apr 11, 2009 at 8:08 PM, Donald Spithaler <"dspithaler@gmail.com"> wrote:
04-12-2009, 06:48
Cannon plugs
Note, too that the cannon plugs are mostly for the manufacturer's
convenience during the initial assembly of the vehicle. They are of minimal use to the owner -- there's little reason to ever unplug one other than to look for problems. So, re-wiring a couple of wires around the plug is not likely to cause an difficulties down the line. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Apr 11, 2009, at 8:51 PM, Curt Sprenger wrote: > > > Heat, vibration, moisture, connect/disconnect, wire end(s)/ > connectors not the best at initial assemble, bad grounds, stress on > the wire bundle or a wire in the bundle, etc., all leading to > arching, deterioration and eventually no connection. > > Just rewire the one bad wire outside the plugs. > > Good luck. > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > On Sat, Apr 11, 2009 at 8:08 PM, Donald Spithaler > > > Curt Do you know what makes one wire go bad in a plug of 24 wires? |
04-13-2009, 12:53
Cannon plugs
--- In WanderlodgeForum@yahoogroups.com, "Don Spithaler"
> > Hi Guys > I have a cannon plug with a bad wire in it. It is on the female side. Can you buy them or would it be better to bypass the wire around the plug. If you can buy them. Is there a good source.This plug has my parking lights & my 12 volt inside. > Don Spithaler > 89 SP 36' > Butler, PA > I would like imformation on cannon plugs, if you hear anything. richard 89WB40 |
04-14-2009, 03:47
Cannon plugs
Have not looked at the cannon plugs we have onour coaches, but usually they can be repaired.
Have you looked intothat?
try MCM electronics to purchase. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada Now with a new friend-happy design! Try the new Yahoo! Canada Messenger |
04-14-2009, 04:56
Cannon plugs
I'd spray the cannon plugs with one of those water/corrosion resisting products
like Corrosion-X. Disconnect the plug and give the contacts a thorough dose. Corrosion-X is an aircraft corrosion inhibitor which molecularly binds with a variety of metals, forming a long lasting barrier. NFI. David Brady '02 LXi, NC -----Original Message----- |
