Park Brake Air Valve
04-21-2009, 06:57
Our bird is in storage,
So does anyone have the part number for the Push / Pull park spring brake
valve???
This is one of the parts I would like to replace, before our next trip.
Bill 88 FC Michigan
04-21-2009, 07:08
Bill, the best thing is to remove that as there must be a bunch of those out there. At least, when we were looking for on of those the parts guy showed us a bunch of pictures and told us to pick one~
83PT40
Wanderlodge
--- On Tue, 4/21/09, pattypape wrote:
Subject: [WanderlodgeForum] Park Brake Air Valve
Date: Tuesday, April 21, 2009, 1:57 PM
So does anyone have the part number for the Push / Pull park spring brake valve???
Bill 88 FC Michigan
04-21-2009, 07:22
Bill:
Try B-W 289954
http://www.wbparts.com/rfq/2530-01-503-7903.html
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
>valve???
>Bill 88 FC Michigan
04-21-2009, 07:24
Bill, on my coach the push /pull control valve assembly is a Bendix PP-1, 30PSI.
Try http://www.anythingtruck.com. Remans available. My book shows BB number for what it's worth is 0900266. I can send you a photo of the drawing if you like.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Date: Tuesday, April 21, 2009, 2:57 PM
Bill 88 FC Michigan
04-21-2009, 09:30
Mine has been problematical for some time, so I just ordered a reman PP-1 from
http://www.anythingtruck.com - $31.50+11.48 shipping.
Leroy, there is a line on the exhaust port. I have not tried to trace where it
goes, do you know? I assume it is to keep noise down, but blockage in that line
would certainly make operation problematical.
Don Bradner
90 PT40 "Blue Thunder"
>30PSI.
>like..
>Leroy Eckert
>Dahlonega, GA
>Royale Conversion
>From: pattypape
>valve???
>Bill 88 FC Michigan
04-21-2009, 13:07
Thanks for the inputs, Leroy has the BB #0900266 & Ralph has the Bendix #
289954
This leads to several available, Bendix tech support calls it a 289954 N,
(N) for new number, maybe a revision ??
So, I think I will take Ernie's advise and wait until
I can remove it and match it ,
I need to find out if the plumbing is copper or plastic.
I do not want to re-plumb in the tight space.
Thanks again,
Bill 88 FC Michigan
30PSI.
it's worth is 0900266. I can send you a photo of the drawing if you like..
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: pattypape
valve???
> Bill 88 FC Michigan
04-21-2009, 15:44
Hopefully yours will have the paper band around it with all of the numbers. I
have mine sitting in front of me, and it reads Bendix 289954 PP-1 30 P.S.I.
Bendix has a page on their site that indicates just about everything was
renumbered in 2007, mostly by adding a letter or two.
See http://www.bendixvrc.com/itemDisplay.asp...entID=4572 for pictures and
diagrams.
># 289954
>N,
>Thanks again,
>Bill 88 FC Michigan
>PP-1, 30PSI.
>like..
>> Leroy Eckert
>> Dahlonega, GA
>> Royale Conversion
>> From: pattypape
>brake valve???
>> Bill 88 FC Michigan
>Yahoo! Groups Links
04-21-2009, 22:58
Don, I do not know where the exhaust exits. I have not chased mine down.
Leroy Eckert
Dahlonega, GA
Royale Conversion
--- On Tue, 4/21/09, Don Bradner wrote:
Subject: Re: [WanderlodgeForum] Park Brake Air Valve
Date: Tuesday, April 21, 2009, 5:30 PM
Mine has been problematical for some time, so I just ordered a reman PP-1 from http://www.anythingtruck. com - $31.50+11.48 shipping.
Leroy, there is a line on the exhaust port. I have not tried to trace where it goes, do you know? I assume it is to keep noise down, but blockage in that line would certainly make operation problematical.
Don Bradner
My location: http://www.bbirdmaps. com/user2. cfm?user= 1
>30PSI.
>Try http://www.anythingtruck. com. Remans available. My book shows BB number for
>like..
>Leroy Eckert
>Dahlonega, GA
>Royale Conversion
>--- On Tue, 4/21/09, pattypape <billpatty@hotmail. com> wrote:
>From: pattypape <billpatty@hotmail. com>
>To: WanderlodgeForum@ yahoogroups. com
>valve???
>Bill 88 FC Michigan
04-22-2009, 00:10
Leroy/ Don:
If you slide under the drivers side front bumper area and look up there
should be a small hose that is open ended and that will be the exhaust
from the PP-1 valve.
Safe travels,
Duncan, Oklahoma
Leroy Eckert
Dahlonega, GA
Royale Conversion
from
www.anythingtruck.
problematical.
Don Bradner
My location:
www.bbirdmaps.
PP-1,
>30PSI.
>Try
www.anythingtruck.
you
>like..
>Leroy Eckert
>Dahlonega, GA
>Royale Conversion
04-22-2009, 00:44
Thank You.
Leroy Eckert
Dahlonega, GA
Date: Wednesday, April 22, 2009, 8:10 AM
Leroy/ Don:
Safe travels,
Duncan, Oklahoma
Leroy Eckert
Dahlonega, GA
Royale Conversion
from
www.anythingtruck.
problematical.
Don Bradner
My location:
www.bbirdmaps.
PP-1,
>30PSI.
>Try
www.anythingtruck.
you
>like..
>Leroy Eckert
>Dahlonega, GA
>Royale Conversion
