batery saver switch
06-06-2005, 00:51
batery saver switch
I found a BB Engineering bulletin that refers to a switch that shuts
off the filtered circuits that the master switch doesnt. It says to locate it in the overhead cabinet beside the left front load center. I havn't found this load center. Any ideas. Glenn Shehorn 83FC35RB Kansas City Mo |
06-06-2005, 01:33
batery saver switch
Glenn,
Mine is located in the center overhead where the VCR, Sat. receiver, etc. are located and it is labeled the "Electronics Master". Hope this helps. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD glenn_shehorn wrote: > I found a BB Engineering bulletin that refers to a switch that shuts > off the filtered circuits that the master switch doesnt. It says to > locate it in the overhead cabinet beside the left front load center. I > havn't found this load center. Any ideas. > Glenn Shehorn > 83FC35RB > Kansas City Mo > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
06-06-2005, 04:11
batery saver switch
our switch is in the street side center overhead, behind the
flip up door with the speaker and load center. It is labled electronic master off/on. It turns off things like montitor panels, digital clocks, radio and probably more. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn" > I found a BB Engineering bulletin that refers to a switch that shuts > off the filtered circuits that the master switch doesnt. It says to > locate it in the overhead cabinet beside the left front load center. I > havn't found this load center. Any ideas. > Glenn Shehorn > 83FC35RB > Kansas City Mo |
06-06-2005, 05:37
batery saver switch
Glenn I have a 83FC and the front load center is behind the driver side
head light. I don't know if there is a master cut off switch there or not. Thanks Bruce Campbell 83FCSB --- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn" > I found a BB Engineering bulletin that refers to a switch that shuts > off the filtered circuits that the master switch doesnt. It says to > locate it in the overhead cabinet beside the left front load center. I > havn't found this load center. Any ideas. > Glenn Shehorn > 83FC35RB > Kansas City Mo |
06-06-2005, 05:38
batery saver switch
Glenn, Phil is right. On my 84fc it is just where he said. Only it doesn't
shut off everything in my bird. I shut off both master switch's, the other being by your right knee, under the dash. Wish I knew how I can shut off the total deal without taking a battery cable off. Any help on this ???????? walker 84FC35 kcmo [Non-text portions of this message have been removed] |
06-06-2005, 05:59
batery saver switch
The master cut off switch is on the shift console. However that switch does
not turn off all of the filtered circuits for example your radio and monitoring circuits. I had thought that I had uploaded that factory modificiation into the files section but if I didnt will do it today. Tom 1982 FC35 Vernon Center,NY At 05:37 PM 6/6/2005 +0000, you wrote: >Glenn I have a 83FC and the front load center is behind the driver side >head light. I don't know if there is a master cut off switch there or >not. > >Thanks >Bruce Campbell 83FCSB > > >--- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn" > > > I found a BB Engineering bulletin that refers to a switch that shuts > > off the filtered circuits that the master switch doesnt. It says to > > locate it in the overhead cabinet beside the left front load center. >I > > havn't found this load center. Any ideas. > > Glenn Shehorn > > 83FC35RB > > Kansas City Mo > > > > > > >Yahoo! Groups Links > > > > |
06-06-2005, 06:01
batery saver switch
Glen the PT and FC have different configurations and locations that is why
it is so important for everyone to put their year and model coach at the end of their question. The FC is entirely different. tom 1982 FC35 Vernon Center,NY At 06:33 AM 6/6/2005 -0700, you wrote: >Glenn, > >Mine is located in the center overhead where the VCR, Sat. receiver, >etc. are located and it is labeled the "Electronics Master". Hope >this helps. > >George Lowry >'95 WBDA 4203 & GM 4106 (for sale) >Spearfish, SD > >glenn_shehorn wrote: > > I found a BB Engineering bulletin that refers to a switch that shuts > > off the filtered circuits that the master switch doesnt. It says to > > locate it in the overhead cabinet beside the left front load center. I > > havn't found this load center. Any ideas. > > Glenn Shehorn > > 83FC35RB > > Kansas City Mo > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > |
06-06-2005, 12:47
batery saver switch
I HAVE A DISCONNECT SWITCH BETWEEN MY HOUSE BATTERIES AND THE COACH IN
THE BATTERY COMPARTMENT,,, THIS GUARANTEES ALL 12 VDC IS DISCONNECTED FOR SURE. YOU CAN GET ONE AT ANY BOAT SUPPLY LOCATION, SUCH AS WEST MARINE. AND I HAVE A DISCONNECT BETWEEN MY STARTING BATTERY, AND THE STARTER, IN CASE THE STARTER SHOULD GET "HUNG UP" I CAN CUT THE BATTERY POWER TO THE STARTER TO KEEP IT FROM BURNING UP THE STARTER. DAY IN WARM JAX FLA 83 PT-40 [Non-text portions of this message have been removed] |
06-06-2005, 13:07
batery saver switch
Send me an email. I have part of the BB bulletin that says how to install a
switch that will do as we need. Also says it should have been done prior to our birds MFG. I'm in KC close to Liberty and would love to see a bird close to mine. Its the only one I've ever been around and it ain't like anything I've ever had dealings with. (SOB's) Glenn Shehorn 83FC35 RB Kansas City MO ( Tornado Alley) ----- Original Message ----- From: dwalks@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 06, 2005 4:38 PM Subject: Re: [WanderlodgeForum] Re: batery saver switch Glenn, Phil is right. On my 84fc it is just where he said. Only it doesn't shut off everything in my bird. I shut off both master switch's, the other being by your right knee, under the dash. Wish I knew how I can shut off the total deal without taking a battery cable off. Any help on this ???????? walker 84FC35 kcmo [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-06-2005, 20:02
batery saver switch
thanks Day. good advice. I'll do it
walker 84fc35 kcmo [Non-text portions of this message have been removed] |
User(s) browsing this thread: 10 Guest(s)
