Jake Brake
05-12-2009, 12:25
Jake Brake
Hi group,
On our way here to Fla from Texas,I have noticed the jake brake quit working on
the high position. That is the one I mainly use, very rarely the low position.
Thing is, the low position sounds like it has the high setting.
I changed out the switch figuring it's 25 years old and fried itself.
Didn't help.
My next thought is that there is a solinoid in the engine compartment that has
bit the dust. Problem is, where do I look for it?
I would think this part is pretty available, but I have to find it first.
Any thoughts on where to look?
Bob Lawrence
84 PT36
Tallahassee, Fla
05-12-2009, 13:10
Jake Brake
Bob - A friend with a 6v92 powered County Coach was having a very similar
problem. Turns out the solenoids that respond to the electric signal are under
the valve covers. The same local truck shop that does some work on our Bird
fixed the problem right up.
The situation with yours could be different of course.
Bob Griesel '84 FC31 WLII WA
> Hi group,
on the high position. That is the one I mainly use, very rarely the low
position.
> Didn't help.
> Bob Lawrence
> 84 PT36
> Tallahassee, Fla
05-12-2009, 13:53
Jake Brake
Bob: I would bet that you just have a loose or corroded connection on a wire
controlling the Jake.
> Hi group,
position.
> Didn't help.
> Bob Lawrence
> 84 PT36
> Tallahassee, Fla
05-12-2009, 23:47
Jake Brake
I'd like to find the solution to this also. I haven't had one since I had the gasket the turbo sits on replaced.
83PT40
Wanderlodge
--- On Tue, 5/12/09, ronmarabito2002 wrote:
Subject: [WanderlodgeForum] Re: Jake Brake
Date: Tuesday, May 12, 2009, 8:53 PM
Bob: I would bet that you just have a loose or corroded connection on a wire controlling the Jake.
--- In "WanderlodgeForum%40yahoogroups.com", "Bob Lawrence" wrote:
> Hi group,
> On our way here to Fla from Texas,I have noticed the jake brake quit working on the high position. That is the one I mainly use, very rarely the low position.
> Didn't help.
> My next thought is that there is a solinoid in the engine compartment that has bit the dust. Problem is, where do I look for it?
look?
> Bob Lawrence
> 84 PT36
> Tallahassee, Fla
05-13-2009, 00:48
Jake Brake
Could be, Ron.....now if I can just find where it connects to the solenoids.
Also, thanks, Bob, as a last resort I will hit a truck repair place to look
under valve covers.
Bob
84 PT36
Tallahassee, Fla
> --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" wrote:
> > Hi group,
position.
> > Didn't help.
> > My next thought is that there is a solenoid in the engine compartment that
> > Bob Lawrence
> > 84 PT36
> > Tallahassee, Fla
05-13-2009, 01:11
Jake Brake
I'd like to locate a Jake Brake unit for the mechanical 8V92...another project.
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
83PT40
Wanderlodge
> Hi group,
> Didn't help.
look?
> Bob Lawrence
> 84 PT36
> Tallahassee, Fla
06-16-2009, 06:47
Jake Brake
I'm toying with the thought/research to add a Jake Brake to our 8V92. Thoughts, experiences, complete system or parts available?
I uploaded a few Jake Brake PDFs to the forum. Click on Attachments.
Curt Sprenger
Anaheim Hills, CA
