GENERATOR INFO NEEDED PLEASE HELP
05-21-2009, 06:23
I HAVE A 1990 WB40 BIRD WITH A KOHLER YANMAR POWERED GENERATOR FOR SOME RESON IT
WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I DONT USE IT TO MUCH BUT I
ALWAYS START IT HERE AND THER BUT THIS TIME NO GO
I FIGURE IT COULD BE THE FUEL
ANYWAY THE BOOK SAID IT SHOULD HAVE A FUEL FILTER # 252765 WHICH I CANT FIND
DOSE ANYONE KNOW WHER I CAN GET THE RIGHT FILTER ALSO I NEED THE AIR FILTER
#258646
ALSO LOOKING FOR REPAIR MANUAL
THANKS FOR YOUR HELP
JAMIE BRANDT
1990 WB40
PORT CHARLOTTE FLORIDA
JAMIE@...
05-21-2009, 06:38
Check you air filter to see that it is not
plugged. That happened to mine a year or so ago.
Steve Quandt
1993 PT-40
Iron Mountain, MI
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of gasparillaglass
Sent: Thursday, May 21, 2009 1:24
PM
To:
Subject: [WanderlodgeForum]
GENERATOR FOR SOME RESON IT WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I
DONT USE IT TO MUCH BUT I ALWAYS START IT HERE AND THER BUT THIS TIME NO GO
#258646
JAMIE BRANDT
1990 WB40
"JAMIE%40GASPARILLAGLASS.COM"
05-21-2009, 07:18
Hi Jamie, I have a 88XXV with the same gen set. Check
a few things. Go to the basement and turn off the breakers from the gen
set. If there is a short the Gen won't run. On the gen it self, there is
a solenoid to keep the fuel control throttle open. The wire can vibrate off or
have grease on it. There are sensors to turn off the gen if you loose oil
pressure or the gen gets to hot. If any are not working they would keep the gen
from running. I have had the breaker, solenoid, and hot sensor have
problems. Most were loose wires. For the Filters, mine has a Racor filter
canister. It's located on the right side of the gen set conected to the coach
. If this is what you have let me know and I'll send you the numbers for the filter.
Paul Williams
seekingoz 88XXV
8V92
South Lake Tahoe, Ca
-----Original Message-----
Sent: Thu, 21 May 2009 11:23 am
Subject: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP
I HAVE A 1990 WB40 BIRD WITH A KOHLER YANMAR POWERED GENERATOR FOR SOME RESON IT WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I DONT USE IT TO MUCH BUT I ALWAYS START IT HERE AND THER BUT THIS TIME NO GO
ANYWAY THE BOOK SAID IT SHOULD HAVE A FUEL FILTER # 252765 WHICH I CANT FIND DOSE ANYONE KNOW WHER I CAN GET THE RIGHT FILTER ALSO I NEED THE AIR FILTER #258646
JAMIE BRANDT
1990 WB40
05-21-2009, 10:10
Check the air filter. Black smoke is a sign that the engine isn't getting enough air.
NAPA Auto parts (and many other auto parts stores) will have cross reference lists for filters, if someone on this list doesn't have the right numbers.
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
JAMIE BRANDT
1990 WB40
"JAMIE@GASPARILLAGLASS.COM"
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:WanderlodgeForum-digest@yahoogroups.com
mailto:WanderlodgeForum-fullfeatured@yahoogroups.com
05-21-2009, 10:30
Wix
42276
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
JAMIE BRANDT
1990 WB40
Yahoo! Groups Links
   mailto:"WanderlodgeForum-digest@yahoogroups.com"
   mailto:"WanderlodgeForum-fullfeatured@yahoogroups.com"
   "WanderlodgeForum-unsubscribe@yahoogroups.com"
05-21-2009, 11:06
im not sure what you mein by the basement
But I do get the idea
I will check all cenections
are you saying if i turn the breakers off that it will run??
From: "PRWillms@..." To: WanderlodgeForum@yahoogroups.com
Sent: Thursday, May 21, 2009 3:18:25 PM
Subject: Re: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP
Hi Jamie, I have a 88XXV with the same gen set. Check a few things. Go to the basement and turn off the breakers from the gen set. If there is a short the Gen won't run. On the gen it self, there is a solenoid to keep the fuel control throttle open. The wire can vibrate off or have grease on it. There are sensors to turn off the gen if you loose oil pressure or the gen gets to hot. If any are not working they would keep the gen from running. I have had the breaker, solenoid, and hot sensor have problems. Most were loose wires. For the Filters, mine has a Racor filter canister. It's located on the right side of the gen set conected to the coach. If this is what you have let me know and I'll send you the numbers for the filter.
Paul Williams
seekingoz 88XXV
8V92
JAMIE BRANDT
1990 WB40
05-21-2009, 11:35
Hi I had some work done on the coach. In my storage area, front left is a breaker box. There are only 2 breakers that are 50 amp each. They are for each leg in the coach. If you have a short in the lines to the coach from the Gen, the gen engine will not run.
Paul Williams
seekingoz 88XXV
8V92
Sent: Thu, 21 May 2009 4:06 pm
Paul Williams
seekingoz 88XXV
8V92
JAMIE BRANDT
1990 WB40
05-21-2009, 12:35
Paul, do you have a photo of your coach that we can use for the home page?
83PT40
Wanderlodge
--- On Thu, 5/21/09, PRWillms@... wrote:
From: PRWillms@... Subject: Re: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP
Date: Thursday, May 21, 2009, 6:35 PM
Paul Williams
seekingoz 88XXV
8V92
From: "PRWillms@aol. com" To: WanderlodgeForum@ yahoogroups. com
Paul Williams
seekingoz 88XXV
8V92
JAMIE BRANDT
1990 WB40
05-21-2009, 13:37
Here is a Pic of our coach, "SeekingOz", in South Lake Tahoe, Ca
Paul Williams
SeekingOz 88XXV
8V92
Sent: Thu, 21 May 2009 5:35 pm
83PT40
Wanderlodge
Paul Williams
seekingoz 88XXV
8V92
Paul Williams
seekingoz 88XXV
8V92
JAMIE BRANDT
1990 WB40
05-22-2009, 08:14
Did anyone mention a stuck injector? Load the two filters with Howe's meaner cleaner in a 15% concentration, bleed the system and run it for all it is worth, smoke and all. You could have a stuck injector or pump. The Howe's is good stuff though some swear by Lucas.
Gary
Date: Thursday, May 21, 2009, 7:06 PM
Paul Williams
seekingoz 88XXV
8V92
JAMIE BRANDT
1990 WB40
JAMIE@GASPARILLAGLA SS.COM
