Shutting off the heat
05-28-2009, 08:11
So, how do I shut the heat off in this 85 PT40? I've turned off all know
switches on dash and panels above. But, we are still getting heat out of the
vents. I'm guessing it's coming from the chassis heating system since all the
others are off. Surely their must be a valve to shut off somewhere. . .
When it's 100 degrees outside I would rather not have any heat on. . .
Jerry
85 PT40
05-28-2009, 08:32
My '86 has water valves in the engine compartment, left side. I don't
know which ones go where, though, but this is what they're for.
-Ryan
'86 PT-40 8V92
> the others are off. Surely their must be a valve to shut off somewhere. . .
05-28-2009, 08:36
I do see some valves in the engine compartment but I don't want to shut off
something that shouldn't be shut off. I have the 6V92.
Jerry
85 PT40
> -Ryan
> '86 PT-40 8V92
05-28-2009, 08:51
Jerry:
Switch the Chasis thermostat to the off position and be sure the black
chassis heater switch is in the off position. There will be a set of 2
switches at each chassis heater one is on off the other is low/high
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
>the vents. I'm guessing it's coming from the chassis heating system since
>all the others are off. Surely their must be a valve to shut off
>somewhere. . .
>Jerry
>85 PT40
05-28-2009, 09:38
> Jerry
> 85 PT40
Jerry,
There are four valves in the engine compartment. Two of which control the
pilot/copilot heat, the other two supply coolant to all the other
chassis heaters. My bluebook says three are located on the rear of the engine
and one is on the left bank, about 1/2 way up the side
of the engine. Never could find that one. I located the 4th one also in the rear
of the engine. Two are visible, two are down in front of the rear bumper,
practicly invisible. If all you want is to shut of heat, Ralph's post is a damn
sight easier
Art Weatherly
Riverside Ca.
'85 PT 36
05-28-2009, 10:28
Check the Winter/Summer switch?? if you have one??
there may also be defective Sprolan valves in the coolant lines.
Bill 88 FC Michigan.
--- In WanderlodgeForum@yahoogroups.com, "amweatherly@..."
> > Jerry
> > 85 PT40
> Jerry,
rear of the engine. Two are visible, two are down in front of the rear bumper,
sight easier
> Art Weatherly
> Riverside Ca.
> '85 PT 36
05-28-2009, 15:56
There is a summer/winter rocker switch on the left side of the overhead dash area, if it is set to summer the chassis heat system will be off.
Wayne
1985 PT40
Sent: Thursday, May 28, 2009 4:38:27 PM
Subject: [WanderlodgeForum] Re: Shutting off the heat
--- In "WanderlodgeForum%40yahoogroups.com", "jburgessx2" wrote:
> So, how do I shut the heat off in this 85 PT40? I've turned off all know switches on dash and panels above. But, we are still getting heat out of the vents. I'm guessing it's coming from the chassis heating system since all the others are off. Surely their must be a valve to shut off somewhere. . .
> Jerry
> 85 PT40
Jerry,
There are four valves in the engine compartment. Two of which control the pilot/copilot heat, the other two supply coolant to all the other
chassis heaters. My bluebook says three are located on the rear of the engine and one is on the left bank, about 1/2 way up the
side
of the engine. Never could find that one. I located the 4th one also in the rear of the engine. Two are visible, two are down in front of the rear bumper, practicly invisible. If all you want is to shut of heat, Ralph's post is a damn sight easier
Art Weatherly
Riverside Ca.
'85 PT 36
05-28-2009, 17:48
Wayne,
I have it set to summer but it still seems to poor the heat out. We are on I-5
heading back to Port Hueneme and it was a hot one today. My wife set a
thermometer by her feet to check the temp - 105 degrees at the co-pilots seat
feet!!! My feet were at 87 degrees. I had the generator running with two of
the AC's going trying to cool it down. My dash AC doesn't work and I haven't
fixed it yet. I was hoping there was some way to turn the heat off at the
engine.
I don't think the heat of the generator and the heat of the road could produce
105 degrees in the passengers seat but I could be wrong.
Oh well, we will be home by noon tomorrow and I guess I can look into it
further. Maybe I have a stuck valve somewhere that isn't allowing the
winter/summer switch to work properly.
Jerry
85 PT40
> Wayne
> 1985 PT40
> From: "amweatherly@..."
> --- In WanderlodgeForum@ yahoogroups. com, "jburgessx2"
> > Jerry
> > 85 PT40
> Jerry,
sight easier
> Art Weatherly
> Riverside Ca.
> '85 PT 36
05-28-2009, 23:06
If you turn your engine off and turn the key to the on position, go to back of coach and see if those 2 little pumps on the street side of coach, which control the coolant flow are spinning. your switch may be bad and stuck on. the other alternative is to close those 4 valves which ddirect coolant to your chassis heaters and have no bearing on your coolant flow to radiator
83PT40
Wanderlodge
Date: Friday, May 29, 2009, 12:48 AM
Wayne,
I have it set to summer but it still seems to poor the heat out. We are on I-5 heading back to Port Hueneme and it was a hot one today. My wife set a thermometer by her feet to check the temp - 105 degrees at the co-pilots seat feet!!! My feet were at 87 degrees. I had the generator running with two of the AC's going trying to cool it down. My dash AC doesn't work and I haven't fixed it yet. I was hoping there was some way to turn the heat off at the engine.
I don't think the heat of the generator and the heat of the road could produce 105 degrees in the passengers seat but I could be wrong.
Oh well, we will be home by noon tomorrow and I guess I can look into it further. Maybe I have a stuck valve somewhere that isn't allowing the winter/summer switch to work properly.
Jerry
85 PT40
> Wayne
> 1985 PT40
> ____________ _________ _________ __
> From: "amweatherly@ ..."
> To: WanderlodgeForum@ yahoogroups. com
> --- In WanderlodgeForum@ yahoogroups. com, "jburgessx2" wrote:
> > So,
> > Jerry
> > 85 PT40
> Jerry,
> chassis heaters. My bluebook says three are located on the rear of the engine and one is on the left bank, about 1/2 way up the side
> Art Weatherly
> Riverside Ca.
> '85 PT 36
05-29-2009, 01:21
Hi Jerry,
Kelly and I had a good laugh this morning- at your expense of course- We
couldn't figure ours out either and used to roast up front all summer. I finally
realized that you have to shut off the 4 valves in the engine compartment to
completely turn the heat off. Otherwise, the hot coolant seems to keep
circulating- even with the summer/winter switch on summer and the front heat
dash switch off. It sounds like others have clued you into this as well.
Shane Fedeli
85PT40
On the road in San Antonio
> Jerry
> 85 PT40
