1995 WLWB 42, LPG GAS Main Shut off Valve.
06-15-2009, 04:30
06-15-2009, 04:49
Mine is aft of the fuel door on drivers side. there are 2 doors the back one is LP
Scooter 2000LX Ocqueoc,MI To: WanderlodgeForum@yahoogroups.com From: cockyfox@... Date: Mon, 15 Jun 2009 09:30:11 -0700 Subject: [WanderlodgeForum] 1995 WLWB 42, LPG GAS Main Shut off Valve.
06-15-2009, 05:06
06-15-2009, 06:18
06-15-2009, 07:20
--- In WanderlodgeForum@yahoogroups.com, Ron Thompson
On my coach there is an electric solenoid control at the dinette that shuts off the gas inside. Ie. the stove will not work without it on, but the fridge will. The main manual shutoff is on the tank itself. There is another shut off valve for the reefer inside the louvered vent on the side of the coach, which is behind the fridge. If the fridge has not been operating on gas for awhile it will take several starts for it to get going if everything it ok. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion > > I have never used the LPG gas since I have had this coach and I have an absolutely stupid question. Â Where the heck is the main LPG Shut off Valve on a 1995 WLWB 42? > > Does the Master LPG Switch that is located in the counter right in front of the sink the only switch that controls the gas supply on and off. When I turn the Alarm switch on it buzzes. There is no gas leak that I can detect anywhere so it must be buzzing because the gas supply is turned off. > > Oh, the refrigerator is running when the Inverter is on and also when the generator is on or the shore line is hooked up. It is just the Lpg mode on the frig that does not work. When You set it to lpg operation it waits about 45 seconds then the check light comes on. The LPG level indicator shows almost full of gas. The only thing I can think of is that the main shut off valve is off. > > Appreciate any help from someone who is familiar with this coach. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > |
06-15-2009, 13:08
Ron:
On my 94 WB, there is a valve, identical to the one on the top of an LP Gas Tank in the wash station compartment street side. Turn in the direction of the arrow pointing to close and in the direction pointing to open. This is the master cut off valve and has nothing to do with the switches inside. It took me forever to find mine when it was right there all along. I would imagine yours is alomost like mine if not the same. Best wishes |
06-16-2009, 02:05
MY switch is in the same door as the LPfill. It is a simple on off switch that it by the way mine is a LX if in fact that makes a difference.
Al Scudder (734)637-0112 cell 734 453-1074 office To: WanderlodgeForum@yahoogroups.com From: cockyfox@... Date: Mon, 15 Jun 2009 10:06:05 -0700 Subject: RE: [WanderlodgeForum] 1995 WLWB 42, LPG GAS Main Shut off Valve.
06-16-2009, 04:09
absolutely stupid question. Where the heck is the main LPG Shut off Valve on a 1995 WLWB 42? - Road side, second bay compartment door, back wall right in front of the aquahot, there is a 12x12 inch panel with machine screws, remove it and it will expose the valve on the tank itself and the inli ne dual stage regulator Does the Master LPG Switch that is located in the counter right in front of the sink the only switch that controls the gas supply on and off. When I turn the Alarm switch on it buzzes. There is no gas leak that I can detect anywhere so it must be buzzing because the gas supply is turned off. -as others have stated, the master propane switch in from of the sink and in the road side fuel door controls the flow of propane via another valve in addition to the mechanical one on the tank. IF you are referring to the "alarm" switch in from of the sink on the same panel as the master propane switch, that alarm if for the refrigerator....temp sensor and goes off if the frig is too warm, nothing to do with propane.....propane senors on the floor and wall cabin......with auto shutoffs Oh, the refrigerator is running when the Inverter is on and also when the generator is on or the shore line is hooked up. It is just the Lpg mode on the frig that does not work. When You set it to lpg operation it waits about 45 seconds then the check light comes on. The LPG level indicator shows almost full of gas. The only thing I can think of is that the main shut off valve is off. -sounds like the "propane side / circuit / parts" of the fridge needs service.... flue clogged,valve clogged, etc.... prior posts on this..... Pete Chin 95 42' Daytona beach --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > I have never used the LPG gas since I have had this coach and I have an absolutely stupid question. Â Where the heck is the main LPG Shut off Valve on a 1995 WLWB 42? > > Does the Master LPG Switch that is located in the counter right in front of the sink the only switch that controls the gas supply on and off. When I turn the Alarm switch on it buzzes. There is no gas leak that I can detect anywhere so it must be buzzing because the gas supply is turned off. > > Oh, the refrigerator is running when the Inverter is on and also when the generator is on or the shore line is hooked up. It is just the Lpg mode on the frig that does not work. When You set it to lpg operation it waits about 45 seconds then the check light comes on. The LPG level indicator shows almost full of gas. The only thing I can think of is that the main shut off valve is off. > > Appreciate any help from someone who is familiar with this coach. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > |
06-16-2009, 07:37
Ron,
I haven't had mine as long as Pete has, so he'll have more detailed info. But at the LPG fill door is a simple switch to turn the LPG on and off. As I recall, mine is "backwards", meaning it needs to be flipped down to be on and flipped up to be off. Then the inside switch there below the sink needs to be on and the LPG detector needs to be on. Then you should have gas. I check by turning the stovetop on to see that it lights and burns. Then you should be able to have the fridge on gas. That being said, if rust has formed inside the burner exhaust, it will flake off and block the flame sensor from operating. Mine did this this past weekend. Open the door outside the back of the fridge (assuming your fridge is flat against an outer wall) remove the cover over the burner (it should be a flat plate with 2 phillips screws at the bottom). There's then a small cover that just sits on top of the burner assembly, held in place by the panel you just removed. Pull it off and clean the rust flakes out of the way. I vacuumed mine out. Put it all back together and see what happens. That fixed mine the first time, but now something else has occurred so it won't stay lit anyway! Something else to do in my "spare time"! Hope this helps. John --- In WanderlodgeForum@yahoogroups.com, "pgchd" > > I have never used the LPG gas since I have had this coach and I have an absolutely stupid question. Where the heck is the main LPG Shut off Valve on a 1995 WLWB 42? > - Road side, second bay compartment door, back wall right in front of the aquahot, there is a 12x12 inch panel with machine screws, remove it and it will expose the valve on the tank itself and the inli ne dual stage regulator > > Does the Master LPG Switch that is located in the counter right in front of the sink the only switch that controls the gas supply on and off. When I turn the Alarm switch on it buzzes. There is no gas leak that I can detect anywhere so it must be buzzing because the gas supply is turned off. > -as others have stated, the master propane switch in from of the sink and in the road side fuel door controls the flow of propane via another valve in addition to the mechanical one on the tank. IF you are referring to the "alarm" switch in from of the sink on the same panel as the master propane switch, that alarm if for the refrigerator....temp sensor and goes off if the frig is too warm, nothing to do with propane.....propane senors on the floor and wall cabin......with auto shutoffs > > Oh, the refrigerator is running when the Inverter is on and also when the generator is on or the shore line is hooked up. It is just the Lpg mode on the frig that does not work. When You set it to lpg operation it waits about 45 seconds then the check light comes on. The LPG level indicator shows almost full of gas. The only thing I can think of is that the main shut off valve is off. > -sounds like the "propane side / circuit / parts" of the fridge needs service.... flue clogged,valve clogged, etc.... prior posts on this..... > > Pete Chin > 95 42' Daytona beach > > > > > > --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > > > I have never used the LPG gas since I have had this coach and I have an absolutely stupid question. Â Where the heck is the main LPG Shut off Valve on a 1995 WLWB 42? > > > > Does the Master LPG Switch that is located in the counter right in front of the sink the only switch that controls the gas supply on and off. When I turn the Alarm switch on it buzzes. There is no gas leak that I can detect anywhere so it must be buzzing because the gas supply is turned off. > > > > Oh, the refrigerator is running when the Inverter is on and also when the generator is on or the shore line is hooked up. It is just the Lpg mode on the frig that does not work. When You set it to lpg operation it waits about 45 seconds then the check light comes on. The LPG level indicator shows almost full of gas. The only thing I can think of is that the main shut off valve is off. > > > > Appreciate any help from someone who is familiar with this coach. > > > > Ron Thompson -Waller, Tx. > > > > 1995 WLWB 42' > > > > (cockyfox@) > > > |
06-17-2009, 08:55
