reverse polarity/general maintenance
07-01-2009, 04:47
07-01-2009, 05:37
What is the amperage of the socket you are connecting to? Long extension cord?
On 7/1/2009 at 9:47 AM Randal Akers wrote: >I recently purchased an 86 38' BB from Scott Forman. He told me about >this forum.  The coach has developed a problem in the electrical system. >Everytime I try to plug it in to an outlet it throws a breaker at my >house. The problem is not at my house. Also, I'd like to find someone >that knows Bluebirds to do maintenance on mine. Thanks. Randy Akers |
07-01-2009, 08:30
07-01-2009, 14:18
07-01-2009, 22:41
07-02-2009, 01:24
Try Coachcraft in Columbus, Ga. They owna Bluebird and work on them.
Â
Jerry Smith
2005 450 LXI
On Wed, Jul 1, 2009 at 10:18 PM, Randal Akers <"randalakers@yahoo.com"> wrote:
07-02-2009, 07:00
07-02-2009, 09:03
You could try Blaekley(sp) in Unidilla, if that's close.
They were BB dealer and they still have some used birds there, as well as some of the old factory people. They also have one of the first birds built. Steve Gureasko 90WBWL401/2 Jus Chillin Ponchatoula, La. |
07-02-2009, 10:53
You might try to first shut down the water heater breaker and the charger
circuit breaker in the bus prior to plugging it in. They probably come on right away and may be too much of a draw for your setup. If that doesnt work shut the entire panel off then plug it in. if it pops then your transfer switch or plug wires may be where the prob is. you may also try using a source that is not on a gfi from the house. if it energizes with a non gfi, could prove a ground fault or improper bonding. Remember the bus electrical box "is not" where the neutral and ground bond. Ground bonding is done at the house. the bus is treated just like a big appliance. Turn it in under warranty, if the condition is contrary to the statement of condition. You can find a slew of hints to recent work on your bus here, just search Forman. recent work is the biggest clue to a repair Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Randal Akers > > I recently purchased an 86 38' BB from Scott Forman. He told me about this forum. Â The coach has developed a problem in the electrical system. Everytime I try to plug it in to an outlet it throws a breaker at my house. The problem is not at my house. Also, I'd like to find someone that knows Bluebirds to do maintenance on mine. Thanks. Randy Akers > |
07-02-2009, 11:12
RonM does oil analysis . how's that working
Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > Check if there is a Speedco by you. They have a pit and can do oil analysis. > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos.groups.yahoo.com/group/erni...gandrepair > > --- On Wed, 7/1/09, Randal Akers > > > From: Randal Akers > Subject: Re: [WanderlodgeForum] reverse polarity/general maintenance > To: WanderlodgeForum@yahoogroups.com > Date: Wednesday, July 1, 2009, 9:18 PM > > > > > > > > > > > > > As far as the maintenance, I live in Kennesaw, GA, and would like to find someone nearby. > > --- On Wed, 7/1/09, Ernie Ekberg > > > From: Ernie Ekberg > Subject: Re: [WanderlodgeForum] reverse polarity/general maintenance > To: WanderlodgeForum@ yahoogroups. com > Date: Wednesday, July 1, 2009, 4:30 PM > > > > > > > > > Randall, we work on Bluebirds. What do you need fixed? > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos. groups.yahoo. com/group/ erniesremodeling andrepair > > --- On Wed, 7/1/09, Randal Akers > > > From: Randal Akers > Subject: [WanderlodgeForum] reverse polarity/general maintenance > To: WanderlodgeForum@ yahoogroups. com > Date: Wednesday, July 1, 2009, 11:47 AM > > > > > > > > > I recently purchased an 86 38' BB from Scott Forman. He told me about this forum. Â The coach has developed a problem in the electrical system. Everytime I try to plug it in to an outlet it throws a breaker at my house. The problem is not at my house. Also, I'd like to find someone that knows Bluebirds to do maintenance on mine. Thanks. Randy Akers > |
