Goodyear tires - BAD
07-01-2009, 11:46
We bought a set of 8 Goodyear Tires (80 R 22.5) in November 2008. With less than 5,000 miles, we found three of the tires were separating. With worries of the other Goodyears going bad as we drove, we put new Michelin's on our 2000 LXI. Goodyear will not stand behind the tires, Has anyone else had a problem with them?
From: Ron Thompson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 1, 2009 12:04:24 AM Subject: Re: [WanderlodgeForum] New problem,,,,lost one of my Freedom Inverters
07-01-2009, 12:38
We purchased 8 new Goodyear (80 R 22.5)for our 2000 LXI in August of 2008. With
very little mileage, three of the tires have separated. Goodyear is not cooperating with us at all. Has anyone else had trouble with Goodyears? |
07-01-2009, 23:04
--- In WanderlodgeForum@yahoogroups.com, "kkjames47"
> > We purchased 8 new Goodyear (80 R 22.5)for our 2000 LXI in August of 2008. With very little mileage, three of the tires have separated. Goodyear is not cooperating with us at all. Has anyone else had trouble with Goodyears? > That is indeed disturbing news - I had decided to put new Goodyears on my 'Bird before a trip to Seattle later this summer. Why did Goodyear refuse to warranty the bad tires? Tommy |
07-01-2009, 23:37
I had tred seperation on Goodyears, three instances in less than 5K miles. In two cases I took the tire back and the replaced the tire and paid for the damage to the coach. On the third I insisted they give me my money back as I did not trust the tires. The offered to replace the other original tires, but with the same model GY's. I wouldn't Agee, got disgusted and replaces them with new Michelins. If you look in out archived posts, you will see my previous comments on the subject. Roger Webb 91 WL Cedar Rapids, IA
RWW
On Jul 1, 2009, at 8:38 PM, "kkjames47" <"kkjames47@yahoo.com"> wrote:
07-02-2009, 00:02
The new Internet Explorer® 8 - Faster, safer, easier. Optimized for Yahoo! Get it Now for Free! |
07-02-2009, 00:19
Signature? Sounds like a classic case of improper air pressure. What are your
position weights at each of the 6 positions? What air pressure do you carry at each position? How do you check the pressure, and how often? No tire manufacturer will routinely stand behind tire failure due to improper air pressure. Gary SOB --- In WanderlodgeForum@yahoogroups.com, "kkjames47" > > We purchased 8 new Goodyear (80 R 22.5)for our 2000 LXI in August of 2008. With very little mileage, three of the tires have separated. Goodyear is not cooperating with us at all. Has anyone else had trouble with Goodyears? > |
07-02-2009, 00:39
I believe the GY's I had were G149's. You can look in the archived posts to confirm. I have all my documentation at my office, but will not be back there until Monday. Roger Webb 91 WL Cedar Rapids, IA
On Jul 2, 2009, at 8:02 AM, Brian Johnson <"wanderbuddy@yahoo.ca"> wrote: = |
07-02-2009, 02:53
The tire pressure was routinely checked and we never ran them if they were low. The tires had only 4,000 miles on them. All eight were purchased at the same time and were the same batch number.. We did not feel safe running on them so replaced them with Michelin.. (an expensive lesson, needless to say!)
From: trekkersmith1 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 2, 2009 6:19:04 AM Subject: [WanderlodgeForum] Re: Goodyear Tires - BAD Signature? Sounds like a classic case of improper air pressure. What are your position weights at each of the 6 positions? What air pressure do you carry at each position? How do you check the pressure, and how often? No tire manufacturer will routinely stand behind tire failure due to improper air pressure. Gary SOB --- In "WanderlodgeForum%40yahoogroups.com", "kkjames47" > > We purchased 8 new Goodyear (80 R 22.5)for our 2000 LXI in August of 2008. With very little mileage, three of the tires have separated. Goodyear is not cooperating with us at all. Has anyone else had trouble with Goodyears? > |
07-02-2009, 02:59
The model number was 80 R 22.5 G670 RE, Load range L.
From: Brian Johnson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 2, 2009 6:02:20 AM Subject: Re: [WanderlodgeForum] Goodyear Tires - BAD
07-02-2009, 07:33
I can guess what it is, but I'd rather not - what is the missing 3 digit number
in front of 80 (usually xxx/80) for these tires? That missing number is the size, and 80 is just ratio of height to width. On 7/2/2009 at 7:59 AM Karen James wrote: >The model number was 80 R 22.5 G670 RE, Load range L. |
