tires
07-05-2009, 13:44
Post: #81
tires
It just you Ernie. LOL
Your right MICHELIN is better. The last time the subject about tires on the forum was discussed it got personal. Some folks have a problem with Michelin being French Company; some folks have problems with Mexican painters. Etc. I have a problem with getting the most bang for my buck. I don't much care were it's made or who made it, as long as it's the best I can get for my $$$$$$"SSSSSSS Bridgstone is owned by Michelin, so for a few more bucks I'd go Michelin. Goodyear is only used by necessity not by choice. Michelin is standard equipment on Prevost Firestone makes a tire for Greyhound that has an extra strong sidewall, due to the fact that the Dogs pull up to the curb several times a day and scuffing is a problem. Your rotation schedule sounds good. I've been doing that every year since I've owned my coach. Two new steers yearly, In another year I'll have nothing older that 4 years on the bird. With good trade in value to boot. If you go back and check some of the older threads on this forum you'll see lots of ideas, see if your tire guy will not take the old tires that have good tread and not too old in on trade, don't just give them up they are worth something, Local truckers and farmers would probably give $100 bucks or more for a tire with good tread that are only three or four years old. There are other choices as well, Kumho & Toyo are as good as the other brands. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > Don't Bridgestones have a harder sidewall then the others? > I had B's on my van and they were stiif. Put M's on and ride is better. Or is is me? > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos.groups.yahoo.com/group/erni...gandrepair > > --- On Sun, 7/5/09, tommy.rountree > > > From: tommy.rountree > Subject: [WanderlodgeForum] Re: tires > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, July 5, 2009, 5:33 PM > > > > > > > > > O.K, everyone.... . > > I'm now throughly confused. I have Michelins all the way around on my 94 WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. No cracks, good tread. I was wanting to replace my steers and had figured on two Goodyears for thew steers and moving the michelins to the Drive and the best of the drives to the Tag. > > My tire man here at home (does tires for a couple of churches one has a Prevost Tour Bus and the other has a BB) recommends Goodyears, Firestones and Bridgestones in that order. Does not recommend Michelins. Prices: > > Goodyears $508.00 each including new ss valve stems and mounting. > Firestones $465.00 each, include ss valve stems and mounting. > Bridgestones $561.00 each, includes new ss valve stems and mounting. > > The tire debate goes no, but I not choosy - just want the best tire for the money. > > Help! > > Tommy Rountree > |
07-05-2009, 15:49
Post: #82
tires
Jay, I live in Jeff, on Court Ave, Bird in DW stop by.
John McGinnis 88FC35 Jeffersonville, IN/Louisville, KY |
07-05-2009, 17:58
Post: #83
tires
rotate in two new tires every other year, then you never steer on older than 24
month old rubber, and never have older than 8 year old in the mix (8 tire tag mix). I found best price and newest stock from Manny Moe and Jack. Pepboys manager can sell the tires from American tire distributor but they don't install. Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "birdshill123" wrote: > > You will not find them for $500 unless they are "hot". I think Michelin just raised their prices again. Somewhere around $650 each out the door is a good price. I have been quoted more! > > Bruce > > 1988 FC35 > |
07-05-2009, 23:32
Post: #84
tires
Hi Guys, Ya have me concerned. I have the GY 159 12R22.5 on my coach. About
three years old, maybe less then 10k miles. I want to replace them for peace of mind if for no other reason. My plan is to do the steer tires now and then next year the drives and the following the tag. I just can't swing the entire set of 8 at one shot. My question is one of the fellow replaced his 12R with 315/80/R 22.5 and feels the larger tires a significant benefit. Sounds reasonable. Since I am not doing all 8 at one time do you see a problem mixing the different size tires as I proceed with my plan? Obviously when I do the drive axle I would not mix sizes there. Anyone see a problem with either the larger size or the mixing as I go. Thanks I intend to buy Michelin ZXA2 tires. John Heckman Shippensburg Pa 1987 PT 36 > > > > It just you Ernie. LOL > > Your right MICHELIN is better. > > The last time the subject about tires on the forum was discussed it got personal. > > Some folks have a problem with Michelin being French Company; some folks have problems with Mexican painters. Etc. > > I have a problem with getting the most bang for my buck. > > I don't much care were it's made or who made it, as long as it's the best I can get for my $$$$$$"SSSSSSS > > Bridgstone is owned by Michelin, so for a few more bucks I'd go Michelin. > > Goodyear is only used by necessity not by choice. > > Michelin is standard equipment on Prevost > > Firestone makes a tire for Greyhound that has an extra strong sidewall, due to the fact that the Dogs pull up to the curb several times a day and scuffing is a problem. > > Your rotation schedule sounds good. I've been doing that every year since I've owned my coach. Two new steers yearly, In another year I'll have nothing older that 4 years on the bird. With good trade in value to boot. > > If you go back and check some of the older threads on this forum you'll see lots of ideas, see if your tire guy will not take the old tires that have good tread and not too old in on trade, don't just give them up they are worth something, > > Local truckers and farmers would probably give $100 bucks or more for a tire with good tread that are only three or four years old. > > There are other choices as well, Kumho & Toyo are as good as the other brands. > > Kurt Horvath > 95 PT 42 > 10AC > > --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > > > Don't Bridgestones have a harder sidewall then the others? > > I had B's on my van and they were stiif. Put M's on and ride is better. Or is is me? > > > > > > Ernie Ekberg > > 83PT40 > > Wanderlodge > > Weatherford, Tx > > http://autos.groups.yahoo.com/group/erni...gandrepair > > > > --- On Sun, 7/5/09, tommy.rountree > > > > > > From: tommy.rountree > > Subject: [WanderlodgeForum] Re: tires > > To: WanderlodgeForum@yahoogroups.com > > Date: Sunday, July 5, 2009, 5:33 PM > > > > > > > > > > > > > > > > > > O.K, everyone.... . > > > > I'm now throughly confused. I have Michelins all the way around on my 94 WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. No cracks, good tread. I was wanting to replace my steers and had figured on two Goodyears for thew steers and moving the michelins to the Drive and the best of the drives to the Tag. > > > > My tire man here at home (does tires for a couple of churches one has a Prevost Tour Bus and the other has a BB) recommends Goodyears, Firestones and Bridgestones in that order. Does not recommend Michelins. Prices: > > > > Goodyears $508.00 each including new ss valve stems and mounting. > > Firestones $465.00 each, include ss valve stems and mounting. > > Bridgestones $561.00 each, includes new ss valve stems and mounting. > > > > The tire debate goes no, but I not choosy - just want the best tire for the money. > > > > Help! > > > > Tommy Rountree > > > |
07-06-2009, 02:13
Post: #85
tires
John,
When I purchased our coach it had 159s on it. I never had a tire failure. I replace them after about two years due to the age of the tires. In those two years they were in 114 degree desert heat and sub zero winter weather.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 Sent: Monday, July 06, 2009 6:33 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: tires Hi Guys, Ya have me concerned. I have the GY 159 12R22.5 on my coach. About three years old, maybe less then 10k miles. I want to replace them for peace of mind if for no other reason. My plan is to do the steer tires now and then next year the drives and the following the tag. I just can't swing the entire set of 8 at one shot. My question is one of the fellow replaced his 12R with 315/80/R 22.5 and feels the larger tires a significant benefit. Sounds reasonable. Since I am not doing all 8 at one time do you see a problem mixing the different size tires as I proceed with my plan? Obviously when I do the drive axle I would not mix sizes there. Anyone see a problem with either the larger size or the mixing as I go. Thanks I intend to buy Michelin ZXA2 tires. John Heckman Shippensburg Pa 1987 PT 36 > > > > It just you Ernie. LOL > > Your right MICHELIN is better. > > The last time the subject about tires on the forum was discussed it got personal. > > Some folks have a problem with Michelin being French Company; some folks have problems with Mexican painters. Etc. > > I have a problem with getting the most bang for my buck. > > I don't much care were it's made or who made it, as long as it's the best I can get for my $$$$$$"SSSSSSS > > Bridgstone is owned by Michelin, so for a few more bucks I'd go Michelin. > > Goodyear is only used by necessity not by choice. > > Michelin is standard equipment on Prevost > > Firestone makes a tire for Greyhound that has an extra strong sidewall, due to the fact that the Dogs pull up to the curb several times a day and scuffing is a problem. > > Your rotation schedule sounds good. I've been doing that every year since I've owned my coach. Two new steers yearly, In another year I'll have nothing older that 4 years on the bird. With good trade in value to boot. > > If you go back and check some of the older threads on this forum you'll see lots of ideas, see if your tire guy will not take the old tires that have good tread and not too old in on trade, don't just give them up they are worth something, > > Local truckers and farmers would probably give $100 bucks or more for a tire with good tread that are only three or four years old. > > There are other choices as well, Kumho & Toyo are as good as the other brands. > > Kurt Horvath > 95 PT 42 > 10AC > > --- In "WanderlodgeForum%40yahoogroups.com", Ernie Ekberg > > > > Don't Bridgestones have a harder sidewall then the others? > > I had B's on my van and they were stiif. Put M's on and ride is better. Or is is me? > > > > > > Ernie Ekberg > > 83PT40 > > Wanderlodge > > Weatherford, Tx > > http://autos. > > > > --- On Sun, 7/5/09, tommy.rountree > > > > > > From: tommy.rountree > > Subject: [WanderlodgeForum] Re: tires > > To: "WanderlodgeForum%40yahoogroups.com" > > Date: Sunday, July 5, 2009, 5:33 PM > > > > > > > > > > > > > > > > > > O.K, everyone.... . > > > > I'm now throughly confused. I have Michelins all the way around on my 94 WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. No cracks, good tread. I was wanting to replace my steers and had figured on two Goodyears for thew steers and moving the michelins to the Drive and the best of the drives to the Tag. > > > > My tire man here at home (does tires for a couple of churches one has a Prevost Tour Bus and the other has a BB) recommends Goodyears, Firestones and Bridgestones in that order. Does not recommend Michelins. Prices: > > > > Goodyears $508.00 each including new ss valve stems and mounting. > > Firestones $465.00 each, include ss valve stems and mounting. > > Bridgestones $561.00 each, includes new ss valve stems and mounting. > > > > The tire debate goes no, but I not choosy - just want the best tire for the money. > > > > Help! > > > > Tommy Rountree > > > |
07-06-2009, 02:24
Post: #86
tires
I replaced my steers with 315/80 XZA-2 a couple of months ago, and just hit the
road yesterday. With 12Rs I had to run at least 115 on a 120-lb rated tire, and they would run as high as 140 down the road (Pressure Pro reporting). With the 315/80 I set them at 105 to carry the same weight on a 130-lb rated tire, and the highest I saw yesterday was 124 running in 100-degree temps at 60mph. Ride when hitting bumps much better. I will be replacing the drivers next year, and will stay with 12R, XZE*. Shane runs 315/80 on his drivers also, but has to run them at high pressure to keep separation with 8.25-inch rims. I don't see any reason to do that, as 90psi on the 12R is correct for my weight. Tags get replaced with rotated steers, so in a couple of years I will have 315/80 on the tags. Again not needed, but not a problem. My preference is to not have different-age tires on the drivers, so for me the rotation is 2-4-2-2-4-2-2-4 rather than straight 2-2-2-2. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Susanville, CA My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 7/6/2009 at 11:32 AM bubblerboy64 wrote: >Hi Guys, Ya have me concerned. I have the GY 159 12R22.5 on my coach. >About three years old, maybe less then 10k miles. I want to replace them >for peace of mind if for no other reason. My plan is to do the steer >tires now and then next year the drives and the following the tag. I >just can't swing the entire set of 8 at one shot. My question is one of >the fellow replaced his 12R with 315/80/R 22.5 and feels the larger tires >a significant benefit. Sounds reasonable. Since I am not doing all 8 at >one time do you see a problem mixing the different size tires as I proceed >with my plan? Obviously when I do the drive axle I would not mix sizes >there. Anyone see a problem with either the larger size or the mixing as >I go. Thanks I intend to buy Michelin ZXA2 tires. > >John Heckman >Shippensburg Pa >1987 PT 36 > > > > > > > >> >> >> >> It just you Ernie. LOL >> >> Your right MICHELIN is better. >> >> The last time the subject about tires on the forum was discussed it got >personal. >> >> Some folks have a problem with Michelin being French Company; some folks >have problems with Mexican painters. Etc. >> >> I have a problem with getting the most bang for my buck. >> >> I don't much care were it's made or who made it, as long as it's the >best I can get for my $$$$$$"SSSSSSS >> >> Bridgstone is owned by Michelin, so for a few more bucks I'd go Michelin. >> >> Goodyear is only used by necessity not by choice. >> >> Michelin is standard equipment on Prevost >> >> Firestone makes a tire for Greyhound that has an extra strong sidewall, >due to the fact that the Dogs pull up to the curb several times a day and >scuffing is a problem. >> >> Your rotation schedule sounds good. I've been doing that every year >since I've owned my coach. Two new steers yearly, In another year I'll >have nothing older that 4 years on the bird. With good trade in value to >boot. >> >> If you go back and check some of the older threads on this forum you'll >see lots of ideas, see if your tire guy will not take the old tires that >have good tread and not too old in on trade, don't just give them up they >are worth something, >> >> Local truckers and farmers would probably give $100 bucks or more for a >tire with good tread that are only three or four years old. >> >> There are other choices as well, Kumho & Toyo are as good as the other >brands. >> >> Kurt Horvath >> 95 PT 42 >> 10AC >> >> --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg >> > >> > Don't Bridgestones have a harder sidewall then the others? >> > I had B's on my van and they were stiif. Put M's on and ride is >better. Or is is me? >> > >> > >> > Ernie Ekberg >> > 83PT40 >> > Wanderlodge >> > Weatherford, Tx >> > http://autos.groups.yahoo.com/group/erni...gandrepair >> > >> > --- On Sun, 7/5/09, tommy.rountree >> > >> > >> > From: tommy.rountree >> > Subject: [WanderlodgeForum] Re: tires >> > To: WanderlodgeForum@yahoogroups.com >> > Date: Sunday, July 5, 2009, 5:33 PM >> > >> > >> > >> > >> > >> > >> > >> > >> > O.K, everyone.... . >> > >> > I'm now throughly confused. I have Michelins all the way around on my >94 WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years >old. No cracks, good tread. I was wanting to replace my steers and had >figured on two Goodyears for thew steers and moving the michelins to the >Drive and the best of the drives to the Tag. >> > >> > My tire man here at home (does tires for a couple of churches one has >a Prevost Tour Bus and the other has a BB) recommends Goodyears, >Firestones and Bridgestones in that order. Does not recommend Michelins. >Prices: >> > >> > Goodyears $508.00 each including new ss valve stems and mounting. >> > Firestones $465.00 each, include ss valve stems and mounting. >> > Bridgestones $561.00 each, includes new ss valve stems and mounting. >> > >> > The tire debate goes no, but I not choosy - just want the best tire >for the money. >> > >> > Help! >> > >> > Tommy Rountree >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
07-06-2009, 02:47
Post: #87
tires
John,
I would not replace your tires just on the fear of a problem, "three years old, maybe less then 10k miles." If you haven't had a problem by now you most likely don't have a problem. These tires have a lot of life left in them, granted they my not be your first choice in a tire, yea I'm one of those guys that doesn't like Goodyear, but their not chopped liver either. I wouldn't take the one Goodyear off my coach; I'm too practical for that, read in here, cheap, LOL. If you do go for the new rubber, stick to the original size tire, the 315's are higher rated that the 12.5's but do you need that extra capacity on a PT 36? You should be able to get a good trade in price for your old skins with such little wear. If the dealer won't deal, sell them to a local trucker or farmer. Kurt Horvath 95 PT 42 10AC 7 Michelins, 1 Goodyear --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > John, > > When I purchased our coach it had 159s on it. I never had a tire failure. > I replace them after about two years due to the age of the tires. In those > two years they were in 114 degree desert heat and sub zero winter weather. > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 > Sent: Monday, July 06, 2009 6:33 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: tires > > > > > > > Hi Guys, Ya have me concerned. I have the GY 159 12R22.5 on my coach. About > three years old, maybe less then 10k miles. I want to replace them for peace > of mind if for no other reason. My plan is to do the steer tires now and > then next year the drives and the following the tag. I just can't swing the > entire set of 8 at one shot. My question is one of the fellow replaced his > 12R with 315/80/R 22.5 and feels the larger tires a significant benefit. > Sounds reasonable. Since I am not doing all 8 at one time do you see a > problem mixing the different size tires as I proceed with my plan? Obviously > when I do the drive axle I would not mix sizes there. Anyone see a problem > with either the larger size or the mixing as I go. Thanks I intend to buy > Michelin ZXA2 tires. > > John Heckman > Shippensburg Pa > 1987 PT 36 > > > > > > > > > It just you Ernie. LOL > > > > Your right MICHELIN is better. > > > > The last time the subject about tires on the forum was discussed it got > personal. > > > > Some folks have a problem with Michelin being French Company; some folks > have problems with Mexican painters. Etc. > > > > I have a problem with getting the most bang for my buck. > > > > I don't much care were it's made or who made it, as long as it's the best > I can get for my $$$$$$"SSSSSSS > > > > Bridgstone is owned by Michelin, so for a few more bucks I'd go Michelin. > > > > Goodyear is only used by necessity not by choice. > > > > Michelin is standard equipment on Prevost > > > > Firestone makes a tire for Greyhound that has an extra strong sidewall, > due to the fact that the Dogs pull up to the curb several times a day and > scuffing is a problem. > > > > Your rotation schedule sounds good. I've been doing that every year since > I've owned my coach. Two new steers yearly, In another year I'll have > nothing older that 4 years on the bird. With good trade in value to boot. > > > > If you go back and check some of the older threads on this forum you'll > see lots of ideas, see if your tire guy will not take the old tires that > have good tread and not too old in on trade, don't just give them up they > are worth something, > > > > Local truckers and farmers would probably give $100 bucks or more for a > tire with good tread that are only three or four years old. > > > > There are other choices as well, Kumho & Toyo are as good as the other > brands. > > > > Kurt Horvath > > 95 PT 42 > > 10AC > > > > --- In WanderlodgeForum@ > yahoogroups.com, Ernie Ekberg > > > > > > Don't Bridgestones have a harder sidewall then the others? > > > I had B's on my van and they were stiif. Put M's on and ride is better. > Or is is me? > > > > > > > > > Ernie Ekberg > > > 83PT40 > > > Wanderlodge > > > Weatherford, Tx > > > http://autos. > <http://autos.groups.yahoo.com/group/erni...gandrepair> > groups.yahoo.com/group/erniesremodelingandrepair > > > > > > --- On Sun, 7/5/09, tommy.rountree > > > > > > > > > From: tommy.rountree > > > Subject: [WanderlodgeForum] Re: tires > > > To: WanderlodgeForum@ > yahoogroups.com > > > Date: Sunday, July 5, 2009, 5:33 PM > > > > > > > > > > > > > > > > > > > > > > > > > > > O.K, everyone.... . > > > > > > I'm now throughly confused. I have Michelins all the way around on my 94 > WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. > No cracks, good tread. I was wanting to replace my steers and had figured on > two Goodyears for thew steers and moving the michelins to the Drive and the > best of the drives to the Tag. > > > > > > My tire man here at home (does tires for a couple of churches one has a > Prevost Tour Bus and the other has a BB) recommends Goodyears, Firestones > and Bridgestones in that order. Does not recommend Michelins. Prices: > > > > > > Goodyears $508.00 each including new ss valve stems and mounting. > > > Firestones $465.00 each, include ss valve stems and mounting. > > > Bridgestones $561.00 each, includes new ss valve stems and mounting. > > > > > > The tire debate goes no, but I not choosy - just want the best tire for > the money. > > > > > > Help! > > > > > > Tommy Rountree > > > > > > |
07-06-2009, 03:09
Post: #88
tires
As I was looking for links tohelp answer another question on this forum, I ran into one I had booked marked about 'Dangerous' Goodyear G159 tires -- it is a bit dated (2006). I hadkept this article as part of my research when wrestling with Goodyear about my G149 issues detailed in earlier posts.
Roger Webb
91WL
Cedar Rapids, IA
In a message dated 7/6/2009 6:33:06 A.M. Central Daylight Time, jehdds@... writes:
07-06-2009, 04:28
Post: #89
tires
There should be no problem mixing metric (315/80) with 12R tires, if each axle carries the same size/type tire. i.e. replacing tires as you suggest should be no problem.
The only concern is that the 315s, which are about .4 inches wider than the 12R may not have sufficient clearance on the duals ... but that's something to discuss with the tire installer -- I note that several 'bird owners have moved to the metric size tires without problems. Note that we're referring to all tires as having the radial design. Mixing bias ply tires and radials on the same vehicle can result in some poor handling characteristics. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jul 6, 2009, at 4:32 AM, bubblerboy64 wrote:
07-06-2009, 06:51
Post: #90
tires
Kurt, I realize I am being a little reactionary about this stuff. I am going
to replace the steers now and rotate the take offs to the tag, (which I think are the oldest tires on the coach) and then basically follow Greg's suggestion. I watched his video on how to control a coach in a blow out situation and that gives me the creeps. I'd rather spend the money then have that what I would think would be a heart in your throat experience of having that front wheel drop six inches. And how a fellow would have the fore thought to step on the "gas" and not the brake is a little beyond me. John Heckman 1987 PT 36 Shbg Pa > > > John, > > I would not replace your tires just on the fear of a problem, "three years old, maybe less then 10k miles." If you haven't had a problem by now you most likely don't have a problem. These tires have a lot of life left in them, granted they my not be your first choice in a tire, yea I'm one of those guys that doesn't like Goodyear, but their not chopped liver either. I wouldn't take the one Goodyear off my coach; I'm too practical for that, read in here, cheap, LOL. If you do go for the new rubber, stick to the original size tire, the 315's are higher rated that the 12.5's but do you need that extra capacity on a PT 36? You should be able to get a good trade in price for your old skins with such little wear. If the dealer won't deal, sell them to a local trucker or farmer. > > Kurt Horvath > 95 PT 42 > 10AC > 7 Michelins, 1 Goodyear > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > > > John, > > > > When I purchased our coach it had 159s on it. I never had a tire failure. > > I replace them after about two years due to the age of the tires. In those > > two years they were in 114 degree desert heat and sub zero winter weather. > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > > > > > > _____ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 > > Sent: Monday, July 06, 2009 6:33 AM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: tires > > > > > > > > > > > > > > Hi Guys, Ya have me concerned. I have the GY 159 12R22.5 on my coach. About > > three years old, maybe less then 10k miles. I want to replace them for peace > > of mind if for no other reason. My plan is to do the steer tires now and > > then next year the drives and the following the tag. I just can't swing the > > entire set of 8 at one shot. My question is one of the fellow replaced his > > 12R with 315/80/R 22.5 and feels the larger tires a significant benefit. > > Sounds reasonable. Since I am not doing all 8 at one time do you see a > > problem mixing the different size tires as I proceed with my plan? Obviously > > when I do the drive axle I would not mix sizes there. Anyone see a problem > > with either the larger size or the mixing as I go. Thanks I intend to buy > > Michelin ZXA2 tires. > > > > John Heckman > > Shippensburg Pa > > 1987 PT 36 > > > > > > > > > > > > > > It just you Ernie. LOL > > > > > > Your right MICHELIN is better. > > > > > > The last time the subject about tires on the forum was discussed it got > > personal. > > > > > > Some folks have a problem with Michelin being French Company; some folks > > have problems with Mexican painters. Etc. > > > > > > I have a problem with getting the most bang for my buck. > > > > > > I don't much care were it's made or who made it, as long as it's the best > > I can get for my $$$$$$"SSSSSSS > > > > > > Bridgstone is owned by Michelin, so for a few more bucks I'd go Michelin. > > > > > > Goodyear is only used by necessity not by choice. > > > > > > Michelin is standard equipment on Prevost > > > > > > Firestone makes a tire for Greyhound that has an extra strong sidewall, > > due to the fact that the Dogs pull up to the curb several times a day and > > scuffing is a problem. > > > > > > Your rotation schedule sounds good. I've been doing that every year since > > I've owned my coach. Two new steers yearly, In another year I'll have > > nothing older that 4 years on the bird. With good trade in value to boot. > > > > > > If you go back and check some of the older threads on this forum you'll > > see lots of ideas, see if your tire guy will not take the old tires that > > have good tread and not too old in on trade, don't just give them up they > > are worth something, > > > > > > Local truckers and farmers would probably give $100 bucks or more for a > > tire with good tread that are only three or four years old. > > > > > > There are other choices as well, Kumho & Toyo are as good as the other > > brands. > > > > > > Kurt Horvath > > > 95 PT 42 > > > 10AC > > > > > > --- In WanderlodgeForum@ > > yahoogroups.com, Ernie Ekberg > > > > > > > > Don't Bridgestones have a harder sidewall then the others? > > > > I had B's on my van and they were stiif. Put M's on and ride is better. > > Or is is me? > > > > > > > > > > > > Ernie Ekberg > > > > 83PT40 > > > > Wanderlodge > > > > Weatherford, Tx > > > > http://autos. > > <http://autos.groups.yahoo.com/group/erni...gandrepair> > > groups.yahoo.com/group/erniesremodelingandrepair > > > > > > > > --- On Sun, 7/5/09, tommy.rountree > > > > > > > > > > > > From: tommy.rountree > > > > Subject: [WanderlodgeForum] Re: tires > > > > To: WanderlodgeForum@ > > yahoogroups.com > > > > Date: Sunday, July 5, 2009, 5:33 PM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > O.K, everyone.... . > > > > > > > > I'm now throughly confused. I have Michelins all the way around on my 94 > > WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. > > No cracks, good tread. I was wanting to replace my steers and had figured on > > two Goodyears for thew steers and moving the michelins to the Drive and the > > best of the drives to the Tag. > > > > > > > > My tire man here at home (does tires for a couple of churches one has a > > Prevost Tour Bus and the other has a BB) recommends Goodyears, Firestones > > and Bridgestones in that order. Does not recommend Michelins. Prices: > > > > > > > > Goodyears $508.00 each including new ss valve stems and mounting. > > > > Firestones $465.00 each, include ss valve stems and mounting. > > > > Bridgestones $561.00 each, includes new ss valve stems and mounting. > > > > > > > > The tire debate goes no, but I not choosy - just want the best tire for > > the money. > > > > > > > > Help! > > > > > > > > Tommy Rountree > > > > > > > > > > |
