Electroluminescent Dashboard Gremlins
07-19-2009, 09:40
I've been working on this one for a while. Here' an update.EL went back in April. They would light briefly when the headlight were turned on, but would then go out. I have replaced the inverters, the dimmer functions correctly, headlight switch functions correctly I had no power to the dimmer and after searching the blueprint several times I don't have the correct print that shows anything in the EL/Generator Bay. If anyone has that Blueprint or a blueprint of the wiring for the dashboard please post it or e-mail it to me. Power problem was solved by George Morris @ Bleakley's suggestion wire it to an open slot in a bus bar with a 5 amp fuse. This worked Great!!! The EL fired up and were home free. That great success was short lived. The EL`s out again. The dimmer is powered, the fuse did not blow, the dimmer functions correctly, good ground, one inverter has power the other does not.. Any idea on where to go from here? Kurt Horvath 95 PT 42 10AC |
07-24-2009, 23:44
07-25-2009, 07:58
Gary,
I just unplugged and cleaned all the plugs and applied dielectric grease to all the pins. I did not help the EL lights, but it did get the high idle to function better, It's a bit temperamental, it's no wonder some of the pins were very corroded, with a light white powdery coating. So it may help in other areas as well, you know how some things work intermittently, Gremlins! Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, GARY MINKER > > You could be a victim of a large Molex plug failure. > Caig Labs makes a good pin protectant > re seat all the front area Molex connectors > > --- On Sun, 7/19/09, Kurt Horvath > > From: Kurt Horvath > Subject: [WanderlodgeForum] Electroluminescent Dashboard Gremlins > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, July 19, 2009, 5:40 PM > > > > > > > Â > > > > > > Electroluminescent Dashboard Gremlins > > > > I've been working on this one for a while. > > > > Here' an update.EL went back in April. > > > > They would light briefly when the headlight were turned on, but would then go out. I have replaced the inverters, the dimmer functions correctly, headlight switch functions correctly > > > > I had no power to the dimmer and after searching the blueprint several times I don't have the correct print that shows anything in the EL/Generator Bay. If anyone has that Blueprint or a blueprint of the wiring for the dashboard please post it or e-mail it to me. > > > > Power problem was solved by George Morris @ Bleakley's suggestion wire it to an open slot in a bus bar with a 5 amp fuse. This worked Great!!! The EL fired up and were home free. > > > > That great success was short lived. The EL`s out again. The dimmer is powered, the fuse did not blow, the dimmer functions correctly, good ground, one inverter has power the other does not.. > > > > Any idea on where to go from here? > > > > Kurt Horvath > > 95 PT 42 > > 10AC > |
07-26-2009, 11:28
07-26-2009, 11:37
07-26-2009, 11:50
you don't have to use a certain or specific cleaner on molex connectors
if the pins are clean by all means use silicone as well as being an insulator it acts as a non-hardening sealant to stop air infiltration the cause of the corrosion --- In WanderlodgeForum@yahoogroups.com, GARY MINKER > > YOW, silicon grease is very bad. You must use the Caig Labs cramolin cleaner on molex pins. I have not found anything that works besides mechanical abrasion and this stuff. The silicon grease is an insulator and will louse up your metering and low current connections. You can have several big connectors in a line to go from here to there. You have to get to them all. My door bell keeps quitting because of one. > > --- On Sat, 7/25/09, Kurt Horvath > > From: Kurt Horvath > Subject: [WanderlodgeForum] Re: Electroluminescent Dashboard Gremlins > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, July 25, 2009, 3:58 PM > > > > > > >  > > > > > > > > Gary, > > > > I just unplugged and cleaned all the plugs and applied dielectric grease to all the pins. > > > > I did not help the EL lights, but it did get the high idle to function better, It's a bit temperamental, it's no wonder some of the pins were very corroded, with a light white powdery coating. > > > > So it may help in other areas as well, you know how some things work intermittently, Gremlins! > > > > Kurt Horvath > > 95 PT 42 > > 10AC > > > > --- In WanderlodgeForum@ yahoogroups. com, GARY MINKER wrote: > > > > > > You could be a victim of a large Molex plug failure. > > > Caig Labs makes a good pin protectant > > > re seat all the front area Molex connectors > > > > > > --- On Sun, 7/19/09, Kurt Horvath > > > > > > From: Kurt Horvath > > > Subject: [WanderlodgeForum] Electroluminescent Dashboard Gremlins > > > To: WanderlodgeForum@ yahoogroups. com > > > Date: Sunday, July 19, 2009, 5:40 PM > > > > > > > > > > > > > > > > > > > > >  > > > > > > > > > > > > > > > > > > Electroluminescent Dashboard Gremlins > > > > > > > > > > > > I've been working on this one for a while. > > > > > > > > > > > > Here' an update.EL went back in April. > > > > > > > > > > > > They would light briefly when the headlight were turned on, but would then go out. I have replaced the inverters, the dimmer functions correctly, headlight switch functions correctly > > > > > > > > > > > > I had no power to the dimmer and after searching the blueprint several times I don't have the correct print that shows anything in the EL/Generator Bay. If anyone has that Blueprint or a blueprint of the wiring for the dashboard please post it or e-mail it to me. > > > > > > > > > > > > Power problem was solved by George Morris @ Bleakley's suggestion wire it to an open slot in a bus bar with a 5 amp fuse. This worked Great!!! The EL fired up and were home free. > > > > > > > > > > > > That great success was short lived. The EL`s out again. The dimmer is powered, the fuse did not blow, the dimmer functions correctly, good ground, one inverter has power the other does not.. > > > > > > > > > > > > Any idea on where to go from here? > > > > > > > > > > > > Kurt Horvath > > > > > > 95 PT 42 > > > > > > 10AC > > > > |
07-27-2009, 02:18
Steve, I agree with making a dry clean connection then keeping the union
protected. I found straight up silicon caulk to be the best. If you make a clean connection and use plastic spraypaint that works good too. I use plastic spraypaint on cables then tape it off. only problem is if you need to refit its a pain to clean. wd40 works good on some of the cheap stuff to clean it off. using the dielectric crap in the engine compartment doesnt work (volvo taillight experience)as the heat dries it out and the solvents leave the powery cakey dielectric grease on the union. the good stuff the electric company uses cant be exposed to air for that reason. however: silicone caulk needs to be exposed to air prior to taping off. I use the hard silicon caulk for trailer connections and just cut them off if I need to repair. when I fit a plug on a trailer the hard silicon found at homedepot, helps keep the wires on the screws if some reason the wire is tugged. the hard stuff wont clean off for a repair at all. but, a repair is not often needed once the hard stuff sets. dont use wd40 under the silicon, wash the fittings with soap and water first, not sure that brake cleaner of electrical contact cleaner works better or at all. soap and water then air is how I clean most things. I even use laundry soap to stain/hullrott grassseed. water is the universial solvent the 02 is the problem as it oxidizes once contact is made. metal with a bit of oxidizing paints better and the paint holds longer, so oxidizing isnt always a bad thing unless it is progressing and continual Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" wrote: > > you don't have to use a certain or specific cleaner on molex connectors > if the pins are clean by all means use silicone as well as being an insulator it acts as a non-hardening sealant to stop air infiltration > the cause of the corrosion > > > > --- In WanderlodgeForum@yahoogroups.com, GARY MINKER > > > > YOW, silicon grease is very bad. You must use the Caig Labs cramolin cleaner on molex pins. I have not found anything that works besides mechanical abrasion and this stuff. The silicon grease is an insulator and will louse up your metering and low current connections. You can have several big connectors in a line to go from here to there. You have to get to them all. My door bell keeps quitting because of one. > > > > --- On Sat, 7/25/09, Kurt Horvath > > > > From: Kurt Horvath > > Subject: [WanderlodgeForum] Re: Electroluminescent Dashboard Gremlins > > To: WanderlodgeForum@yahoogroups.com > > Date: Saturday, July 25, 2009, 3:58 PM > > > > > > > > > > > > > >  > > > > > > > > > > > > > > > > Gary, > > > > > > > > I just unplugged and cleaned all the plugs and applied dielectric grease to all the pins. > > > > > > > > I did not help the EL lights, but it did get the high idle to function better, It's a bit temperamental, it's no wonder some of the pins were very corroded, with a light white powdery coating. > > > > > > > > So it may help in other areas as well, you know how some things work intermittently, Gremlins! > > > > > > > > Kurt Horvath > > > > 95 PT 42 > > > > 10AC > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, GARY MINKER wrote: > > > > > > > > > > You could be a victim of a large Molex plug failure. > > > > > Caig Labs makes a good pin protectant > > > > > re seat all the front area Molex connectors > > > > > > > > > > --- On Sun, 7/19/09, Kurt Horvath > > > > > > > > > > From: Kurt Horvath > > > > > Subject: [WanderlodgeForum] Electroluminescent Dashboard Gremlins > > > > > To: WanderlodgeForum@ yahoogroups. com > > > > > Date: Sunday, July 19, 2009, 5:40 PM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >  > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Electroluminescent Dashboard Gremlins > > > > > > > > > > > > > > > > > > > > I've been working on this one for a while. > > > > > > > > > > > > > > > > > > > > Here' an update.EL went back in April. > > > > > > > > > > > > > > > > > > > > They would light briefly when the headlight were turned on, but would then go out. I have replaced the inverters, the dimmer functions correctly, headlight switch functions correctly > > > > > > > > > > > > > > > > > > > > I had no power to the dimmer and after searching the blueprint several times I don't have the correct print that shows anything in the EL/Generator Bay. If anyone has that Blueprint or a blueprint of the wiring for the dashboard please post it or e-mail it to me. > > > > > > > > > > > > > > > > > > > > Power problem was solved by George Morris @ Bleakley's suggestion wire it to an open slot in a bus bar with a 5 amp fuse. This worked Great!!! The EL fired up and were home free. > > > > > > > > > > > > > > > > > > > > That great success was short lived. The EL`s out again. The dimmer is powered, the fuse did not blow, the dimmer functions correctly, good ground, one inverter has power the other does not.. > > > > > > > > > > > > > > > > > > > > Any idea on where to go from here? > > > > > > > > > > > > > > > > > > > > Kurt Horvath > > > > > > > > > > 95 PT 42 > > > > > > > > > > 10AC > > > > > > > > |
