Air Springs Replaced
06-10-2005, 02:33
A couple days ago the air springs on the drive and front axles were
replaced. Prior to the R&R the front/drive suspension would leak down within an hour. Now the front stays up. The drive still settles. I've checked but haven't located any air leaks. Ideas??? -- Curt Sprenger â87PT38, Anaheim, Calif. |
06-10-2005, 02:52
Curt, On my Bird I found the 65 psi regulator was leaking. It is a real
bear to get to. It's on top of the passenger air tank back by the drives. I have yet to tackle the job. It looks like the grey water tank must come down to get at it. Have you also checked your ride height adjuster? They tend to leak at the arms. Oene Pomper |
06-10-2005, 03:04
Thanks Oene. I did check the ride height adjusters and no leaks. I'll
look for the 65 PSI regulator you mentioned. -- Curt Sprenger â87PT38, Anaheim, Calif. Oene Pomper wrote: > Curt, On my Bird I found the 65 psi regulator was leaking. It is a real > bear to get to. It's on top of the passenger air tank back by the > drives. I have yet to tackle the job. It looks like the grey water tank > must come down to get at it. Have you also checked your ride height > adjuster? They tend to leak at the arms. > Oene Pomper |
06-10-2005, 03:06
Drop the suspension when you park, that's my solution.
Mike Hohnstein ----- Original Message ----- From: "Curt Sprenger" To: Sent: Friday, June 10, 2005 9:33 AM Subject: [WanderlodgeForum] Air Springs Replaced > A couple days ago the air springs on the drive and front axles were > replaced. Prior to the R&R the front/drive suspension would leak down > within an hour. Now the front stays up. The drive still settles. I've > checked but haven't located any air leaks. Ideas??? > > -- > Curt Sprenger â87PT38, Anaheim, Calif. > > > > > > > Yahoo! Groups Links > > > > > > > |
06-10-2005, 15:52
Mike,
Okay, I'll drop the suspension...and stop trying to eliminate all the air leaks...maybe. Actually, I'm doing good with the air leaks, have gone from 4 minute compressor recycling to about 22 minutes. Should be good to go now. Curt Sprenger â87PT38, Anaheim, Calif. Mike Hohnstein wrote: >Drop the suspension when you park, that's my solution. >Mike Hohnstein >----- Original Message ----- >From: "Curt Sprenger" >To: >Sent: Friday, June 10, 2005 9:33 AM >Subject: [WanderlodgeForum] Air Springs Replaced > > > > >>A couple days ago the air springs on the drive and front axles were >>replaced. Prior to the R&R the front/drive suspension would leak down >>within an hour. Now the front stays up. The drive still settles. I've >>checked but haven't located any air leaks. Ideas??? >> >>-- >>Curt Sprenger â87PT38, Anaheim, Calif. >> >> >> >> >> >> >>Yahoo! Groups Links >> >> >> >> >> >> >> >> >> > > > > > > >Yahoo! Groups Links > > > > > > > > > > -- |
06-11-2005, 23:23
When I drop the suspension and later reinflate, I hear a loud popping
noise coming from the front airbags----- this leads me to believe they are getting pinched somehow during deflation? Is this anything to be concerned? Thanks for your advise Kurt '83FC35SB in NH --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > Drop the suspension when you park, that's my solution. > Mike Hohnstein > ----- Original Message ----- > From: "Curt Sprenger" > To: > Sent: Friday, June 10, 2005 9:33 AM > Subject: [WanderlodgeForum] Air Springs Replaced > > > > A couple days ago the air springs on the drive and front axles were > > replaced. Prior to the R&R the front/drive suspension would leak down > > within an hour. Now the front stays up. The drive still settles. I've > > checked but haven't located any air leaks. Ideas??? > > > > -- > > Curt Sprenger `87PT38, Anaheim, Calif. > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > |
06-12-2005, 01:49
I don't hear anything like that out of my front suspension. If I did I might
get out the flash light and visually monitor things while an assistant cycles the switch. I'd want to know if my bags were getting pinched or not. That couldn't be good. Mike Hohnstein Germantown, WI 85FC35 ----- Original Message ----- From: Kurt Achenbach To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 12, 2005 6:23 AM Subject: [WanderlodgeForum] Re: Air Springs Replaced When I drop the suspension and later reinflate, I hear a loud popping noise coming from the front airbags----- this leads me to believe they are getting pinched somehow during deflation? Is this anything to be concerned? Thanks for your advise Kurt '83FC35SB in NH --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > Drop the suspension when you park, that's my solution. > Mike Hohnstein > ----- Original Message ----- > From: "Curt Sprenger" > To: > Sent: Friday, June 10, 2005 9:33 AM > Subject: [WanderlodgeForum] Air Springs Replaced > > > > A couple days ago the air springs on the drive and front axles were > > replaced. Prior to the R&R the front/drive suspension would leak down > > within an hour. Now the front stays up. The drive still settles. I've > > checked but haven't located any air leaks. Ideas??? > > > > -- > > Curt Sprenger `87PT38, Anaheim, Calif. > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-12-2005, 14:49
I have to agree with Mike, not normal at all!
Could be airbag related, could also be the panhard bar bolts/bushings or trailing-arm bushings seized, which would be dangerous, in fact any abnormal noise in the front suspension could be a warning of an unsafe condition. If you can't identify the source, pay a heavy-truck / bus facility to check it out, they should be able to diagnose it for under $50. Fixing it on the other hand, ... - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > I don't hear anything like that out of my front suspension. If I did I might get out the flash light and visually monitor things while an assistant cycles the switch. I'd want to know if my bags were getting pinched or not. That couldn't be good. > Mike Hohnstein > Germantown, WI > 85FC35 > ----- Original Message ----- > From: Kurt Achenbach > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, June 12, 2005 6:23 AM > Subject: [WanderlodgeForum] Re: Air Springs Replaced > > > > > When I drop the suspension and later reinflate, I hear a loud popping > noise coming from the front airbags----- this leads me to believe > they are getting pinched somehow during deflation? Is this anything > to be concerned? > Thanks for your advise > Kurt > '83FC35SB in NH > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@w...> wrote: > > Drop the suspension when you park, that's my solution. > > Mike Hohnstein > > ----- Original Message ----- > > From: "Curt Sprenger" > > To: > > Sent: Friday, June 10, 2005 9:33 AM > > Subject: [WanderlodgeForum] Air Springs Replaced > > > > > > > A couple days ago the air springs on the drive and front axles > were > > > replaced. Prior to the R&R the front/drive suspension would leak > down > > > within an hour. Now the front stays up. The drive still settles. > I've > > > checked but haven't located any air leaks. Ideas??? > > > > > > -- > > > Curt Sprenger `87PT38, Anaheim, Calif. > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
06-12-2005, 21:49
Thank you Mike and Jeff, will check it out at the next possible
oportunity. Kurt --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > I have to agree with Mike, not normal at all! > > Could be airbag related, could also be the panhard bar bolts/bushings > or trailing-arm bushings seized, which would be dangerous, in fact > any abnormal noise in the front suspension could be a warning of an > unsafe condition. > > If you can't identify the source, pay a heavy-truck / bus facility to > check it out, they should be able to diagnose it for under $50. > Fixing it on the other hand, ... > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@w...> wrote: > > I don't hear anything like that out of my front suspension. If I > did I might get out the flash light and visually monitor things while > an assistant cycles the switch. I'd want to know if my bags were > getting pinched or not. That couldn't be good. > > Mike Hohnstein > > Germantown, WI > > 85FC35 > > ----- Original Message ----- > > From: Kurt Achenbach > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, June 12, 2005 6:23 AM > > Subject: [WanderlodgeForum] Re: Air Springs Replaced > > > > > > > > > > When I drop the suspension and later reinflate, I hear a loud > popping > > noise coming from the front airbags----- this leads me to believe > > they are getting pinched somehow during deflation? Is this > anything > > to be concerned? > > Thanks for your advise > > Kurt > > '83FC35SB in NH > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > <MHOHNSTEIN@w...> wrote: > > > Drop the suspension when you park, that's my solution. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: "Curt Sprenger" > > > To: > > > Sent: Friday, June 10, 2005 9:33 AM > > > Subject: [WanderlodgeForum] Air Springs Replaced > > > > > > > > > > A couple days ago the air springs on the drive and front > axles > > were > > > > replaced. Prior to the R&R the front/drive suspension would > leak > > down > > > > within an hour. Now the front stays up. The drive still > settles. > > I've > > > > checked but haven't located any air leaks. Ideas??? > > > > > > > > -- > > > > Curt Sprenger `87PT38, Anaheim, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------ -- > ---------- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > > [Non-text portions of this message have been removed] |
