ADDING PROPANE INJECTION TO THE CAT 3208 TURBO SP
09-29-2009, 02:30
Forum members:
Oneof our 89SP owners added propane injection to his CAT and loves it! Cost about $1200 before labor....... better fuel mileage and more power. Anybody into this? I am considering putting propane injection on my 90SP in the future. Regards, Hank Hannigan 90SP36 In Illinois |
09-29-2009, 03:53
Propane injection wont hurt the engine but it adds more hp to the equation and
may tax the trans. the zf was used because the allison wouldnt hang with 300hp, could be that the zf is set up for 500 hp and things would be ok?????. the short drive shaft wont absorb any twist so all the torque added is at the ring gear and the transmission. I tuned down the hp in a dump truck because I twisted a drive shaft when spinning tires caught traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, just go with the best and save the money trying to make your underpower rig run like a pt Greg of Tim&Greg or 'Same' as you refer to me. 94ptca- -- In WanderlodgeForum@yahoogroups.com, "HANK" > > Forum members: > Oneof our 89SP owners added propane injection to his CAT and loves it! > Cost about $1200 before labor....... > better fuel mileage and more power. > > Anybody into this? I am considering putting propane injection on my 90SP in the future. > Regards, > Hank Hannigan > 90SP36 > In Illinois > |
09-29-2009, 22:49
GREG:
You are correct on the UNDERPOWER of the SP....TOO bad BB did not put a 400 Cummins in the SP...OH well.....not sure the MAX HP for the ZF....I doubt if I'd be spinnng the wheels though! Regards, Hank Hannigan --- In WanderlodgeForum@yahoogroups.com, "TimV" > > Propane injection wont hurt the engine but it adds more hp to the equation and may tax the trans. the zf was used because the allison wouldnt hang with 300hp, could be that the zf is set up for 500 hp and things would be ok?????. the short drive shaft wont absorb any twist so all the torque added is at the ring gear and the transmission. I tuned down the hp in a dump truck because I twisted a drive shaft when spinning tires caught traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, just go with the best and save the money trying to make your underpower rig run like a pt > > Greg of Tim&Greg > or 'Same' as you refer to me. > 94ptca- > > > -- In WanderlodgeForum@yahoogroups.com, "HANK" > > > > Forum members: > > Oneof our 89SP owners added propane injection to his CAT and loves it! > > Cost about $1200 before labor....... > > better fuel mileage and more power. > > > > Anybody into this? I am considering putting propane injection on my 90SP in the future. > > Regards, > > Hank Hannigan > > 90SP36 > > In Illinois > > > |
09-30-2009, 00:02
I'm sure many folks would consider the FC35 with a non-turbo 3208 to be
grossly underpowered, but personally I'm pretty happy with mine. It will run 72 all day on level interstate. Ok, so climbing hills is a chore, but I just try and get a running start coming down the hill before ![]() found a hill yet it won't go up if I'm patient enough, and getting 9MPG makes me really love it ![]() Dorn Hetzel 77FC35 Hogansville, GA On Wed, Sep 30, 2009 at 6:49 AM, HANK <"hank_87us@yahoo.com"> wrote:
09-30-2009, 00:38
--- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel
> I'm sure many folks would consider the FC35 with a non-turbo 3208 > to be grossly underpowered, but personally I'm pretty happy with > mine. ..... > and getting 9MPG makes me really love it ![]() downhill long enough to coast far enough on, we might get 9mph (momentarily) on the downhill. Any day I break 5 is a great day with the 8V92! <sigh> ;^) Mike Bulriss 1991 WB40 "Texas Minivan" - passing FCs going uphill! San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel > > I'm sure many folks would consider the FC35 with a non-turbo 3208 to be > grossly underpowered, but personally I'm pretty happy with mine. It will > run 72 all day on level interstate. Ok, so climbing hills is a chore, but I > > just try and get a running start coming down the hill before ![]() > found a hill yet it won't go up if I'm patient enough, and getting 9MPG > makes me really love it ![]() > > Dorn Hetzel > 77FC35 > Hogansville, GA > > On Wed, Sep 30, 2009 at 6:49 AM, HANK > > > > > > > GREG: > > You are correct on the UNDERPOWER of the SP....TOO bad BB did not put a 400 > > Cummins in the SP...OH well.....not sure the MAX HP for the ZF....I doubt if > > I'd be spinnng the wheels though! > > Regards, > > Hank Hannigan > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "TimV" > > > > > > Propane injection wont hurt the engine but it adds more hp to the > > equation and may tax the trans. the zf was used because the allison wouldnt > > hang with 300hp, could be that the zf is set up for 500 hp and things would > > be ok?????. the short drive shaft wont absorb any twist so all the torque > > added is at the ring gear and the transmission. I tuned down the hp in a > > dump truck because I twisted a drive shaft when spinning tires caught > > traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, > > just go with the best and save the money trying to make your underpower rig > > run like a pt > > > > > > Greg of Tim&Greg > > > or 'Same' as you refer to me. > > > 94ptca- > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com > > "HANK" > > > > > > > > Forum members: > > > > Oneof our 89SP owners added propane injection to his CAT and loves it! > > > > Cost about $1200 before labor....... > > > > better fuel mileage and more power. > > > > > > > > Anybody into this? I am considering putting propane injection on my > > 90SP in the future. > > > > Regards, > > > > Hank Hannigan > > > > 90SP36 > > > > In Illinois > > > > > > > > > > > > > > |
09-30-2009, 01:05
I'm confused by the below statements.....as the Allison transmissions are used in the PTs which put out well over 300hp, closer to 500hp?
Markus To: WanderlodgeForum@yahoogroups.com From: hank_87us@... Date: Wed, 30 Sep 2009 10:49:53 +0000 Subject: [WanderlodgeForum] Re: ADDING PROPANE INJECTION TO THE CAT 3208 TURBO SP > Propane injection wont hurt the engine but it adds more hp to the equation and may tax the trans. the zf was used because the allison wouldnt hang with 300hp, could be that the zf is set up for 500 hp and things would be ok?????. the short drive shaft wont absorb any twist so all the torque added is at the ring gear and the transmission. I tuned down the hp in a dump truck because I twisted a drive shaft when spinning tires caught traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, just go with the best and save the money trying to make your underpower rig run like a pt > > Greg of Tim&Greg > or 'Same' as you refer to me. > 94ptca- > > ![]() Change settings via the Web (Yahoo! ID required) Change settings via email: "WanderlodgeForum-digest@yahoogroups.com?subject=EmailDelivery:Digest" | "WanderlodgeForum-traditional@yahoogroups.com?subject=ChangeDeliveryFormat:Traditional" Visit Your Group | Yahoo! Groups Terms of Use | "WanderlodgeForum-unsubscribe@yahoogroups.com?subject=" . Hotmail® has ever-growing storage! Donât worry about storage limits. Check it out. |
09-30-2009, 02:09
They are different models of transmissions and are rated at different
horsepowers and torque. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Markus Meyer > > > > I'm confused by the below statements.....as the Allison transmissions are used in the PTs which put out well over 300hp, closer to 500hp? > > > > Markus > > > > > > > > To: WanderlodgeForum@yahoogroups.com > From: hank_87us@... > Date: Wed, 30 Sep 2009 10:49:53 +0000 > Subject: [WanderlodgeForum] Re: ADDING PROPANE INJECTION TO THE CAT 3208 TURBO SP > > > > > > > > > > Propane injection wont hurt the engine but it adds more hp to the equation and may tax the trans. the zf was used because the allison wouldnt hang with 300hp, could be that the zf is set up for 500 hp and things would be ok?????. the short drive shaft wont absorb any twist so all the torque added is at the ring gear and the transmission. I tuned down the hp in a dump truck because I twisted a drive shaft when spinning tires caught traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, just go with the best and save the money trying to make your underpower rig run like a pt > > > > Greg of Tim&Greg > > or 'Same' as you refer to me. > > 94ptca- > > > > > > > Change settings via the Web (Yahoo! ID required) > Change settings via email: Switch delivery to Daily Digest | Switch format to Traditional > Visit Your Group | Yahoo! Groups Terms of Use | Unsubscribe > . > > > > > > > > > > _________________________________________________________________ > Hotmail® has ever-growing storage! Don't worry about storage limits. > http://windowslive.com/Tutorial/Hotmail/...al_St\ orage_062009 > |
09-30-2009, 02:28
Ron is correct.................in 89, BB put the ZF tranny in the SP because it
was rated at a higher horsepower than the allison tranny..I guess they could have installed ahigher horsepower rated alison tranny but chose the ZF instead...The ZF company makes BMW & Mercedes trannys..It is a bulltproof tranny.many garbage trucks use th ZF............I'm just not sure the top HP rating of our ZF in the SP/.......I was hoping GREG would answer with that data............he seems to know a lot of stuff......... I am very interested in adding the PROPANE INJECTION to my SP wihin the next year or two...I may as well keep my SP and enjoy it as the price bottomed out so I cant sell it and I aint giving it away..........take care.. Hank Hannigan 90SP36 In Chicago 4 now --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > They are different models of transmissions and are rated at different horsepowers and torque. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, Markus Meyer > > > > > > > > I'm confused by the below statements.....as the Allison transmissions are used in the PTs which put out well over 300hp, closer to 500hp? > > > > > > > > Markus > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > From: hank_87us@ > > Date: Wed, 30 Sep 2009 10:49:53 +0000 > > Subject: [WanderlodgeForum] Re: ADDING PROPANE INJECTION TO THE CAT 3208 TURBO SP > > > > > > > > > > > > > > > > > > > Propane injection wont hurt the engine but it adds more hp to the equation and may tax the trans. the zf was used because the allison wouldnt hang with 300hp, could be that the zf is set up for 500 hp and things would be ok?????. the short drive shaft wont absorb any twist so all the torque added is at the ring gear and the transmission. I tuned down the hp in a dump truck because I twisted a drive shaft when spinning tires caught traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, just go with the best and save the money trying to make your underpower rig run like a pt > > > > > > Greg of Tim&Greg > > > or 'Same' as you refer to me. > > > 94ptca- > > > > > > > > > > > > Change settings via the Web (Yahoo! ID required) > > Change settings via email: Switch delivery to Daily Digest | Switch format to Traditional > > Visit Your Group | Yahoo! Groups Terms of Use | Unsubscribe > > . > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ > > Hotmail® has ever-growing storage! Don't worry about storage limits. > > http://windowslive.com/Tutorial/Hotmail/...al_St\ orage_062009 > > > |
09-30-2009, 02:34
Dorn:
From what I've heard.....a diesel only burns 75% of its fuel...HOWEVER with the propane injection, the diesel burns 100 of its fuel AND gets extra horsepower from the propane...that is abig deal to me...fuel saving AND more power...NO MORE crawling up he hills...................$1200 could be recovered in a year or so of travels plus passing those semi's might be fun!!!! Regards, Hank Hannigan slo SP36 for now --- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel > > I'm sure many folks would consider the FC35 with a non-turbo 3208 to be > grossly underpowered, but personally I'm pretty happy with mine. It will > run 72 all day on level interstate. Ok, so climbing hills is a chore, but I > > just try and get a running start coming down the hill before ![]() > found a hill yet it won't go up if I'm patient enough, and getting 9MPG > makes me really love it ![]() > > Dorn Hetzel > 77FC35 > Hogansville, GA > > On Wed, Sep 30, 2009 at 6:49 AM, HANK > > > > > > > GREG: > > You are correct on the UNDERPOWER of the SP....TOO bad BB did not put a 400 > > Cummins in the SP...OH well.....not sure the MAX HP for the ZF....I doubt if > > I'd be spinnng the wheels though! > > Regards, > > Hank Hannigan > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "TimV" > > > > > > Propane injection wont hurt the engine but it adds more hp to the > > equation and may tax the trans. the zf was used because the allison wouldnt > > hang with 300hp, could be that the zf is set up for 500 hp and things would > > be ok?????. the short drive shaft wont absorb any twist so all the torque > > added is at the ring gear and the transmission. I tuned down the hp in a > > dump truck because I twisted a drive shaft when spinning tires caught > > traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, > > just go with the best and save the money trying to make your underpower rig > > run like a pt > > > > > > Greg of Tim&Greg > > > or 'Same' as you refer to me. > > > 94ptca- > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com > > "HANK" > > > > > > > > Forum members: > > > > Oneof our 89SP owners added propane injection to his CAT and loves it! > > > > Cost about $1200 before labor....... > > > > better fuel mileage and more power. > > > > > > > > Anybody into this? I am considering putting propane injection on my > > 90SP in the future. > > > > Regards, > > > > Hank Hannigan > > > > 90SP36 > > > > In Illinois > > > > > > > > > > > > > > |
09-30-2009, 03:50
I actually think the sp is powered better than the v8 pt pound per pound. the
tire spinning is a issue on dirt roads and wet grass. Since motorhomes run fully loaded all the time they never spinnout on good traction sufaces. but surfaces with ;sand or 1/8in rock on top of asphalt ;wet grass or ;ice they spinn away . in a fc when the spinning tires hit good traction surface the long driveline takes the abrupt force and may twist. with the 2 foot driveline of a pusher, the ring gear in the rearend where the drive force takes a 90 deg turn takes the hit and proves to be the weakest part. I suppose there is a hydrolic blowoff valve in the transmission to take the hit but all the lowend torque demand cant be good. Dodge had a big problem when they put a cummins in a pickup truck in 84 and matched it with a gas engine proven transmission. operator driving demands proved the transmission to not be able to hang with the extra power and torque. I have a 96 Dodge cummins with 200Kmiles and am working on the 4th trans. Greg of Tim&Greg 94ptca Pismo Beach --- In WanderlodgeForum@yahoogroups.com, "HANK" > > GREG: > You are correct on the UNDERPOWER of the SP....TOO bad BB did not put a 400 Cummins in the SP...OH well.....not sure the MAX HP for the ZF....I doubt if I'd be spinnng the wheels though! > Regards, > Hank Hannigan > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "TimV" > > > > Propane injection wont hurt the engine but it adds more hp to the equation and may tax the trans. the zf was used because the allison wouldnt hang with 300hp, could be that the zf is set up for 500 hp and things would be ok?????. the short drive shaft wont absorb any twist so all the torque added is at the ring gear and the transmission. I tuned down the hp in a dump truck because I twisted a drive shaft when spinning tires caught traction. went from 500 hp to 315. The 94pt is the best bluebird ever built, just go with the best and save the money trying to make your underpower rig run like a pt > > > > Greg of Tim&Greg > > or 'Same' as you refer to me. > > 94ptca- > > > > > > -- In WanderlodgeForum@yahoogroups.com, "HANK" > > > > > > Forum members: > > > Oneof our 89SP owners added propane injection to his CAT and loves it! > > > Cost about $1200 before labor....... > > > better fuel mileage and more power. > > > > > > Anybody into this? I am considering putting propane injection on my 90SP in the future. > > > Regards, > > > Hank Hannigan > > > 90SP36 > > > In Illinois > > > > > > |
