Painting Radome
10-03-2009, 03:17
Painting Radome
Goodmoring all, I want to paint the radome used with the satalite system on top
of the coach. It's the origional factory white and I would like to paint it to
match the A/c's on top. I understand you cannot use a metalic paint or primer,
anything else I should consider. Thanks, Bob 99LX..Illinois
10-03-2009, 03:27
Painting Radome
Paint Additives To Avoid on Radomes
In general, the objective is to provide an electromagnetically transparent coating which will not affect the
radiation properties of the antenna. In order to prevent problems, the paint manufacturer should be
advised to only provide products which do “NOT” contain any electrically conductive or metallic (either
ferrous or non ferrous) materials. Examples of these materials typically used in paints are; graphite,
carbon, red oxide, metallic flakes, etc ...
Curt Sprenger
Anaheim Hills, CA
On Sat, Oct 3, 2009 at 8:17 AM, contrail Bob <"rhowald@frontiernet.net"> wrote:
Goodmoring all, I want to paint the radome used with the satalite system on top of the coach. It's the origional factory white and I would like to paint it to match the A/c's on top. I understand you cannot use a metalic paint or primer, anything else I should consider. Thanks, Bob 99LX..Illinois
10-05-2009, 08:40
Painting Radome
Curt is right but you can NEVER know what paints will have traces of metals, any metals and your shiny new antler becomes deaf as a post or stupid. This is a common problem in Broadcast antenna work. People buy the cheap paint and wonder why the radome caught fire.
Gary
85 PT-40
--- On Sat, 10/3/09, Curt Sprenger wrote:
Subject: Re: [WanderlodgeForum] Painting Radome
Date: Saturday, October 3, 2009, 11:27 AM
Curt Sprenger
Anaheim Hills, CA
On Sat, Oct 3, 2009 at 8:17 AM, contrail Bob <rhowald@frontiernet .net> wrote:
10-05-2009, 09:34
Painting Radome
I suspect you might be able to tell whether or not paint contained measurable metals
by microwaving a sample in a glass container and watching for sparks Smile
Dorn Hetzel
77FC35
Hogansville, GA
Gary
85 PT-40
Curt Sprenger
Anaheim Hills, CA
10-05-2009, 13:18
Painting Radome
Hi
I am afraid the only reliable ways are mass spectrometry and capacitance on a thin film surface. Mass spec I can't do, Capacitance I can but that is only partially reliable. the data sheets from the manufacturer are best but some times a poor judge of the R.F. affects. Painting radomes is never a good thing. Stains are a safer bet but not always reliable due to minerals.
Date: Monday, October 5, 2009, 5:34 PM
Dorn Hetzel
77FC35
Hogansville, GA
Gary
85 PT-40
Curt Sprenger
Anaheim Hills, CA
10-06-2009, 01:27
Painting Radome
Paint a big sheet of plastic with the paint and hold it in the beam-path of your directv dish while watching the signal meter on the setup menu of the satellite box Smile
On Mon, Oct 5, 2009 at 9:18 PM, GARY MINKER <"garym33407@yahoo.com"> wrote:
Hi
Dorn Hetzel
77FC35
Hogansville, GA
Gary
85 PT-40
Curt Sprenger
Anaheim Hills, CA
10-06-2009, 06:38
Painting Radome
That is a super idea. Make sure you try the raw plastic first so your results are accurate
Date: Tuesday, October 6, 2009, 9:27 AM
On Mon, Oct 5, 2009 at 9:18 PM, GARY MINKER <garym33407@yahoo. com> wrote:
Hi
Dorn Hetzel
77FC35
Hogansville, GA
Gary
85 PT-40
Curt Sprenger
Anaheim Hills, CA
