Painting Radome
10-03-2009, 03:17
Painting Radome
Goodmoring all, I want to paint the radome used with the satalite system on top
of the coach. It's the origional factory white and I would like to paint it to match the A/c's on top. I understand you cannot use a metalic paint or primer, anything else I should consider. Thanks, Bob 99LX..Illinois |
10-03-2009, 03:27
Painting Radome
Paint Additives To Avoid on Radomes
In general, the objective is to provide an electromagnetically transparent coating which will not affect the radiation properties of the antenna. In order to prevent problems, the paint manufacturer should be advised to only provide products which do ââ¬ÅNOTââ¬Â contain any electrically conductive or metallic (either ferrous or non ferrous) materials. Examples of these materials typically used in paints are; graphite, carbon, red oxide, metallic flakes, etc ... Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Sat, Oct 3, 2009 at 8:17 AM, contrail Bob <"rhowald@frontiernet.net"> wrote:
10-05-2009, 08:40
Painting Radome
10-05-2009, 09:34
Painting Radome
I suspect you might be able to tell whether or not paint contained measurable metals
by microwaving a sample in a glass container and watching for sparks ![]() Dorn Hetzel 77FC35
Hogansville, GA
On Mon, Oct 5, 2009 at 4:40 PM, GARY MINKER <"garym33407@yahoo.com"> wrote:
10-05-2009, 13:18
Painting Radome
10-06-2009, 01:27
Painting Radome
Paint a big sheet of plastic with the paint and hold it in the beam-path of your directv dish while watching the signal meter on the setup menu of the satellite box
![]() On Mon, Oct 5, 2009 at 9:18 PM, GARY MINKER <"garym33407@yahoo.com"> wrote:
10-06-2009, 06:38
Painting Radome
