Coolant hoses
10-25-2009, 03:53
Coolant hoses
I was asked by Rob Robinson to post this about our coolant hoses for the compressor on the PTs
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sat, 10/24/09, Rob Robinson wrote:
Subject: Request
To: "Ernie Ekberg"
Date: Saturday, October 24, 2009, 9:18 PM
Ernie would you please consider posting the quote below on your forum and the ladies, especially the ladies. This crap should not be happening. We know better. I realize we can't help the Rahn's now but if they had been on your or our forum we might have been able to. I know there are still a lot of people out there that need a wake up call. Birds may be owned but they are a finite entity and as such each owner has a responsibility for reasonable care of a scare resource. Thanks
Quote"For a couple of years now various Wanderlodge forums have preached and preached for the replacement of the two 8V92 compressor hoses. All you 8V92 owners need to change these hoses. Not just the early models. Every owner of this engine needs to either replace these hoses or insure that it has been done previously. 1994/95 was the last year they were installed. That’s old enough. I can't believe this problem is still occurring and I'm asking all Bluebird forums to repeat this thread. There is no reason what-so-ever for an engine failure due to failed compressor hoses. Tomorrow an investigation will begin to determine if there is any concern regarding the 6V92 compressor coolant hoses. All forums will be kept in the loop."UNQUOTE
Rob Robinson
94 WL
Rob, Sue and Joey Robinson
94 WLWB
10-25-2009, 04:51
Coolant hoses
if he blew a hose and it lost coolant the bus would have shut down when the
expansion tank lost its fill and sent the detroit computer in to
crawl-low-r-mode. more to it than just a blown coolant hose.
Does he need a rebuild?
One more test would be to run the bus then screw off the expansion tank sight
window and see if draining coolant prompts a shut down????? this would shut
him down wit a blown hose assuming the expansion tank also loowes coolant as a
result............
a good test to prove that the expansion tank shut down sender proves a shut down
when the coolant hose pops is to run the bus then pop the hose and see what
happens.
BUT........if the t stats are not open, it may be that the expansion tank may
retain fluid. and without hot fluid, the t stats wont open????? in that
instance the expansion tank shut down prompt should then be duplicated to a
block location. where the water should be to cool?????????????
one problem with temp gauges on coolant is they do not measure air temp. if the
coolant is lost, you may not see the temp rise. this is where the oil temp I
guess is your second chance to see the condition. noise is usually a good second
chance indication of a problem but lost chance in a pusher. I am sure someone
will come up with a digital reader to define the sounds reference index then
factor that to ;speed, ;demand, ;rpm ;etc... then take that value and compare it
to good running like noise at the same factor conditions.
I bet sound is one of the first prompt of issues with most mechanical devices. I
even use communication sound changes to avoid breakdowns expensive overhauls in
social issues with Tim.
Greg
94ptca
> Ernie Ekberg
> 83PT40
> Wanderlodge
> http://autos.groups.yahoo.com/group/erni...gandrepair
> From: Rob Robinson
> Subject: Request
> To: "Ernie Ekberg"
resource. ThanksÂ
> Rob Robinson
> 94 WLÂ
> 94 WLWB
10-25-2009, 05:41
Coolant hoses
Too many anecdotal examples of engine damage from explosive coolant loss to
accept that. Whether it is due to the coolant-low sensor not working (I don't
know if mine works, do you?) or just not responding fast enough is impossible to
say. The compressor hoses have been implicated in more than a few.
I considered the hoses a critical preventive maintenance item, and had mine
replaced last year. The old ones were like glass - shatter on impact, snap on
bend. I may lose my engine to something else, but it won't be that one!
Don Bradner
90 PT40 "Blue Thunder"
>the expansion tank lost its fill and sent the detroit computer in to
10-25-2009, 05:55
Coolant hoses
I had the radiator off my 77FC35 earlier this year to replace a failed belt.
We went ahead and replaced all the belts, the water pump, and every hose behind the radiator while we were in there just to be on the safe side.
I also rebuilt the front AC lines and replaced the dryer and switch to modern oil and refrigerant and now have working front AC Smile
Dorn Hetzel
77FC35
Hogansville, GA
On Sun, Oct 25, 2009 at 12:41 PM, Don Bradner <"bluethunder@arcatapet.com"> wrote:
Too many anecdotal examples of engine damage from explosive coolant loss to accept that. Whether it is due to the coolant-low sensor not working (I don't know if mine works, do you?) or just not responding fast enough is impossible to say. The compressor hoses have been implicated in more than a few.
I considered the hoses a critical preventive maintenance item, and had mine replaced last year. The old ones were like glass - shatter on impact, snap on bend. I may lose my engine to something else, but it won't be that one!
Don Bradner
My location: www.bbirdmaps.com/user2.cfm?user=1
10-25-2009, 09:31
Coolant hoses
yes my coolant low sensor works. I tested it by draining the tank thew the sight
glass while running.
MarkD 88pt blew a coolant hose and the ddec shut him down. Age of hose and
condition was the cause of the burst so the repair was limited to a tow and
$700. 'hose job'.
when an engine spins a bearing the heat is quick. expansion not relieved by the
r cap builds to burst a hose. the weakest link hose bursting is then a result,
not cause.
When someone gets shot, sometimes they bleed to death. what then would be the
cause of death?
Greg
94ptca
> Don Bradner
10-25-2009, 13:51
Coolant hoses
The point with the brittle hoses is that they break from impact on the OUTSIDE,
not expansion causing bursting. Kick up a rock, for example.
My sensor is way below my sight glass - would have to go down a gallon or more
to reach it from that point.
>the sight glass while running.
>and condition was the cause of the burst so the repair was limited to a
>tow and $700. 'hose job'.
>by the r cap builds to burst a hose. the weakest link hose bursting is
>then a result, not cause.
>the cause of death?
>Greg
>94ptca
>a few.
>one!
>> Don Bradner
>Yahoo! Groups Links
10-26-2009, 03:04
Coolant hoses
LeroyE has a post here some place on how he tested his warning shutdown device
89?pt. its easy to test. shouldn't be difficult to figure a way to drain the
tank to that point. I guess a better way is to use the radiator tank drain valve
so the leak is proven to quickly show up in the E tank. my fear with using r
tank drains are making them close off when finished . my sensor is below the
glass also so I must have also removed a line.
on the 94 there is a extra vent 3/8 hose between radiator tank and expansion
tank that I can only figure vents air from atop of the radiator or additional
equalizes the two tanks?????? I wonder if this is a model year add-on or is it
part of prior year coolant system?
like the looming danger in the prior air leak post, 'poking around' looking to
fix a PO added Wabasto on Marks pt'88 was the pre trip mechanism that damaged
the past life hose. once there is pressure in the hose a crack that appeared but
didnt cause visible leak, we can only figure let loose.
radiator cap replacement and radiator rodding are also overlooked maintenance
procedures.
OUTSIDE, not expansion causing bursting. Kick up a rock, for example.
> >the cause of death?
> >Greg
> >94ptca
> >a few.
> >one!
> >> Don Bradner
> >Yahoo! Groups Links
10-26-2009, 05:38
Coolant hoses
I can confirm the same potential exist on 6V92s. One of my hoses broke during a
10 mile run. Parked the coach and saw the coolantm leaking.
Very little had leaked at that point and was able to replace hoses
w/no damage to engine. I really dodged a bullet.
Art Weatherly
Riverside Ca.
'85 PT36
> Ernie Ekberg
> 83PT40
> Wanderlodge
10-26-2009, 05:42
Coolant hoses
Art I believe you are the third person in the last two days that I have heard confirm this issue is 6V92 as well as 8V92. Information based on personal experience is exactly what we're looking for. Thank you
2009/10/26 artw <"amweatherly@att.net">
I can confirm the same potential exist on 6V92s. One of my hoses broke during a 10 mile run. Parked the coach and saw the coolantm leaking.
Art Weatherly
Riverside Ca.
'85 PT36
> Ernie Ekberg
> 83PT40
> Wanderlodge
94 WLWB
10-26-2009, 05:47
Coolant hoses
When this issue came up awhile back I got all exercised and talked to my mechanic about it. He told to relax as he changed them a couple of years before when doing other work on the compressor.
Sent: Monday, October 26, 2009 9:42 AM
Subject: Re: [WanderlodgeForum] Re: Coolant hoses
Art Weatherly
Riverside Ca.
'85 PT36
> Ernie Ekberg
> 83PT40
> Wanderlodge
> http://autos.groups.yahoo.com/group/erniesremodelingandrepair
94 WLWB
