PT hydraulic reservoir
06-11-2005, 05:21
I WOULD SAY, IT WOULD JUST THIN OUT THE OIL, AND NOT HURT TOO
MUCH FOR A SHORT WHILE,,, AFTER ALL, IT IS A FORM OF OIL. HOW MUCH DID YOU PUT IN THERE?? DAY,,,, [Non-text portions of this message have been removed] |
06-11-2005, 05:28
this was done by another owner. they had their radiator fan rebuilt and
their mechanic added a full reservoir of ATF. ernie-83pt40 in texas- 30 weight in mine [Non-text portions of this message have been removed] |
06-11-2005, 09:00
AND WE PAY THESE FOLKS 80 - 90 BUCKS AN HOUR TO REPAIR OUR
VEHICLES?????? THAT IS WHY I LIKE TO BE CLOSE ENOUGH TO SEE WHAT THESE FOLKS ARE DOING TO MY VEHICLES. ONE SHOP WOULD HAVE DROPPED MY FRIENDS GAS TANK AND CHANGED HIS IN-TANK FUEL PUMP, IF I HAD NOT BEEN THERE,, IT WAS THE FUEL PRESSURE REGULATOR THAT WAS BAD. I GUESS THAT MUCH COULD DAMAGE SOME SEALS, THAT WEREN'T MADE TO HANDLE THAT BLEND OF THIN, CAUSTIC OILS,,,AFTER ALL, I ADD SOME TRANSMISSION FLUID TO MY ENGINE AND RUN FOR 5 MINUTES TO HELP DISOLVE AND FLUSH OUT SOME OF THE GUNK IN MY CAR ENGINES BEFORE I CHANGE THE OIL,,,SO IT ISN'T EXACTLY GOOD FOR A PURELY THICKER BASED OIL SYSTEM. I WOULD FLUSH IT OUT, BY CHANGING IT A COUPLE OF TIMES, AFTER RUNNING IT A LITTLE EACH CHANGE, AND THEN WATCH FOR LEAKS. IF IT WASN'T LEAKING AFTER THAT, IT MAY BE OK,,, MINE USED 10W-40WT ,,,,GOOD LUCK,,, DAY, IN RAINY JAX FLA,,,83 PT-40 [Non-text portions of this message have been removed] |
06-11-2005, 09:08
what happens, if anything, if ATF was added to a hydraulic reservoir in
place of 30 weight oil? ernie- 83pt40 in texas |
06-12-2005, 23:19
Hi Ernie,
Our WL manual recommends Dextron II (now III) for the hydralic jacks. Bill & Rita in Roanoke, VA 1987 FC-35 [Non-text portions of this message have been removed] |
06-13-2005, 05:24
Hi Bill- I guess I should have been a little more specific. On PTs there is a
separate canister for the hydraulics- which is to control the fan motor and power steering. It seems that the couple I was mentioning had a mechanic put the Dextron in that canister where it should have been 30 weight oil. My question- will it hurt that particular hydraulic application? I would think that the Dextron would be a lot lighter weight oil and it may not adversley affect that pump. Just in my opinion- which I can be dead wrong. Ernie- 83PT40- in Texas- Dextron in the jacks, 30 weight in the power steering [Non-text portions of this message have been removed] |
06-13-2005, 06:58
Ernie. My information says to use 10W30 in the p/s and fan reservoir.
Paul in Ky 83PT35 [Non-text portions of this message have been removed] |
06-13-2005, 07:08
Thanks, Paul. The folks that had the wrong fluid installed are in the process
of having it drained and new oil added. Ernie-83PT40 in Texas [Non-text portions of this message have been removed] |
06-13-2005, 11:59
I use 10w30 for the power steering/fan oil, werks great ;~}
Jay Darst 85PT40 SpringfieldIL where I just attended a Midwest Bus Nuts(FMCA club)rally just 7 miles from my store. Mostly Prevost, but many old GMC's, MCI's, a couple Eagles, etc. 27 coaches. I know now who owns the $1.6M rigs I have dreamed about... --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Thanks, Paul. The folks that had the wrong fluid installed are in the process > of having it drained and new oil added. Ernie-83PT40 in Texas > > > [Non-text portions of this message have been removed] |
06-13-2005, 12:08
we just went through this with jack jones coach,he blew a hose,and i told him
30w oil.which is what i'd read somewhere.then he found in his manual to use 10w30..i think either one is fine,i ran 30w in my 84 for years,no problems..randydupree93wb ----- Original Message ----- From: antique405@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 13, 2005 6:58 PM Subject: Re: [WanderlodgeForum] PT hydraulic reservoir Ernie. My information says to use 10W30 in the p/s and fan reservoir. Paul in Ky 83PT35 [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
