PT hydraulic reservoir
06-11-2005, 05:21
I WOULD SAY, IT WOULD JUST THIN OUT THE OIL, AND NOT HURT TOO
MUCH FOR A SHORT WHILE,,, AFTER ALL, IT IS A FORM OF OIL. HOW MUCH DID YOU PUT
IN THERE?? DAY,,,,
06-11-2005, 05:28
this was done by another owner. they had their radiator fan rebuilt and
their mechanic added a full reservoir of ATF. ernie-83pt40 in texas- 30 weight
in mine
06-11-2005, 09:00
AND WE PAY THESE FOLKS 80 - 90 BUCKS AN HOUR TO REPAIR OUR
VEHICLES?????? THAT IS WHY I LIKE TO BE CLOSE ENOUGH TO SEE WHAT THESE FOLKS
ARE DOING
TO MY VEHICLES. ONE SHOP WOULD HAVE DROPPED MY FRIENDS GAS TANK AND CHANGED
HIS IN-TANK FUEL PUMP, IF I HAD NOT BEEN THERE,, IT WAS THE FUEL PRESSURE
REGULATOR THAT WAS BAD.
I GUESS THAT MUCH COULD DAMAGE SOME SEALS, THAT WEREN'T MADE TO HANDLE
THAT BLEND OF THIN, CAUSTIC OILS,,,AFTER ALL, I ADD SOME TRANSMISSION FLUID
TO MY ENGINE AND RUN FOR 5 MINUTES TO HELP DISOLVE AND FLUSH OUT SOME OF THE
GUNK IN MY CAR ENGINES BEFORE I CHANGE THE OIL,,,SO IT ISN'T EXACTLY GOOD FOR A
PURELY THICKER BASED OIL SYSTEM.
I WOULD FLUSH IT OUT, BY CHANGING IT A COUPLE OF TIMES, AFTER RUNNING IT
A LITTLE EACH CHANGE, AND THEN WATCH FOR LEAKS. IF IT WASN'T LEAKING AFTER
THAT, IT MAY BE OK,,, MINE USED 10W-40WT ,,,,GOOD LUCK,,, DAY, IN RAINY JAX
FLA,,,83 PT-40
06-11-2005, 09:08
what happens, if anything, if ATF was added to a hydraulic reservoir in
place of 30 weight oil? ernie- 83pt40 in texas
06-12-2005, 23:19
Hi Ernie,
Our WL manual recommends Dextron II (now III) for the hydralic jacks.
Bill & Rita in Roanoke, VA
1987 FC-35
06-13-2005, 05:24
Hi Bill- I guess I should have been a little more specific. On PTs there is a
separate canister for the hydraulics- which is to control the fan motor and
power steering. It seems that the couple I was mentioning had a mechanic put
the Dextron in that canister where it should have been 30 weight oil. My
question- will it hurt that particular hydraulic application?
I would think that the Dextron would be a lot lighter weight oil and it may
not adversley affect that pump. Just in my opinion- which I can be dead wrong.
Ernie- 83PT40- in Texas- Dextron in the jacks, 30 weight in the power steering
06-13-2005, 06:58
Ernie. My information says to use 10W30 in the p/s and fan reservoir.
Paul in Ky
83PT35
06-13-2005, 07:08
Thanks, Paul. The folks that had the wrong fluid installed are in the process
of having it drained and new oil added. Ernie-83PT40 in Texas
06-13-2005, 11:59
I use 10w30 for the power steering/fan oil, werks great ;~}
Jay Darst
85PT40
SpringfieldIL where I just attended a Midwest Bus Nuts(FMCA club)rally
just 7 miles from my store. Mostly Prevost, but many old GMC's, MCI's,
a couple Eagles, etc. 27 coaches. I know now who owns the $1.6M rigs I
have dreamed about...
the process
06-13-2005, 12:08
we just went through this with jack jones coach,he blew a hose,and i told him
30w oil.which is what i'd read somewhere.then he found in his manual to use
10w30..i think either one is fine,i ran 30w in my 84 for years,no
problems..randydupree93wb
Sent: Monday, June 13, 2005 6:58 PM
Subject: Re: [WanderlodgeForum] PT hydraulic reservoir
Paul in Ky
83PT35
Yahoo! Groups Links
