Intertherm a/c blower, turbo boost indicator
06-13-2005, 07:33
Help.
The a/c blower fan on my 90 wlsp starts to slow down after about 15 minutes and finally stalls. I have not been able to locate a replacement motor following the manufacturer's trail. Does anyone know where I can get one? Also, the turbo boost indicator does not appear to work (if the turbo was really not working what would be the main symptom?). Thanks in advance for any help. |
06-13-2005, 12:12
The chassis a/c fan on the drivers side of my 85PT had the same
symptoms. Didn't get around to fixin it right away. Ran the fan till it stopped and then turned off the fan switch. Then turn back on after a while. then the same procedure. Thought the fan motor was going out, noticed the fan switch looked a bit burnt on the back side. Replaced the fan switch for the drivers side. Werks Grate!(again) $6.61 at big truck parts room. The parts ticket reads as follows: ABP N83 322150 SWITCH LIST $12.17 JOBBER $6.61 Might take a look, maybe get lucky on this fix! Jay Darst 85PT40 SpringfieldIL --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > Help. > The a/c blower fan on my 90 wlsp starts to slow down after about 15 > minutes and finally stalls. I have not been able to locate a > replacement motor following the manufacturer's trail. Does > anyone know where I can get one? > > Also, the turbo boost indicator does not appear to work (if the > turbo was really not working what would be the main symptom?). > > Thanks in advance for any help. |
06-13-2005, 12:15
Sorry missed the SUBJECT: INTERTHERM A/C BLOWER
like gilda radner said, "Never Mind".... Jay --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > The chassis a/c fan on the drivers side of my 85PT had the same > symptoms. Didn't get around to fixin it right away. Ran the fan till > it stopped and then turned off the fan switch. Then turn back on > after a while. then the same procedure. > > Thought the fan motor was going out, noticed the fan switch looked a > bit burnt on the back side. Replaced the fan switch for the drivers > side. Werks Grate!(again) $6.61 at big truck parts room. > > The parts ticket reads as follows: > ABP N83 322150 SWITCH LIST $12.17 JOBBER $6.61 > > Might take a look, maybe get lucky on this fix! > > Jay Darst > 85PT40 > SpringfieldIL > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > Help. > > The a/c blower fan on my 90 wlsp starts to slow down after about 15 > > minutes and finally stalls. I have not been able to locate a > > replacement motor following the manufacturer's trail. Does > > anyone know where I can get one? > > > > Also, the turbo boost indicator does not appear to work (if the > > turbo was really not working what would be the main symptom?). > > > > Thanks in advance for any help. |
06-14-2005, 01:33
J,
The fan I am referring to is in the front roof air unit (an Intertherm AVI model). --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > The chassis a/c fan on the drivers side of my 85PT had the same > symptoms. Didn't get around to fixin it right away. Ran the fan till > it stopped and then turned off the fan switch. Then turn back on > after a while. then the same procedure. > > Thought the fan motor was going out, noticed the fan switch looked a > bit burnt on the back side. Replaced the fan switch for the drivers > side. Werks Grate!(again) $6.61 at big truck parts room. > > The parts ticket reads as follows: > ABP N83 322150 SWITCH LIST $12.17 JOBBER $6.61 > > Might take a look, maybe get lucky on this fix! > > Jay Darst > 85PT40 > SpringfieldIL > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > Help. > > The a/c blower fan on my 90 wlsp starts to slow down after about 15 > > minutes and finally stalls. I have not been able to locate a > > replacement motor following the manufacturer's trail. Does > > anyone know where I can get one? > > > > Also, the turbo boost indicator does not appear to work (if the > > turbo was really not working what would be the main symptom?). > > > > Thanks in advance for any help. |
